Force visu update
Hi!
I have a public mounted iPad with a LM vizu in a browser app on a project. When I make changes in the vizu I have to "hard" close the app and open it again for the change to take action. Are there any script or workaround to force the vizu to update?
P
In the User access settings there is parameter 'User cookie expiration days:' but still the minimum value is 1day.
OK! No way to do this on event?
Yes that is possible, add this to your custom JS (you have to refresh browser once to make it active)
$(function(){ if (typeof grp != 'undefined') {    grp.listen('1/1/1', function(object, state) {      var value = object.value;      if (state == 'value') {        if (value == true) {          location.reload(true);        }      }    });   } });
(15.11.2019, 08:59)permar Wrote: Hi!
P
Can I ask you how did you solve the "battery issue"? I mean did you leave the battery in the iPad?
