Waterkotte Ecotouch Heatpump
Hi @all,
I want to connect my Waterkotte Ecotouch heatpump to LM/W4k. I have a working .php script what is running on my Raspberry. This script I want to transfer to LM.
To start with: My goal is to read "TEMPERATURE_OUTSIDE" and write it to a group address and write "ENABLE_HEATING" from a group address.
Is this possible? Has anybody an idea how to start?
Many thanks for your help!
Best Regards
Steffen
.zip   Waterkotte.zip (Size: 7.61 KB / Downloads: 7)
Try running this code and post what you get in Logs. Change ip, user and pwd variables as needed.
http = require('socket.http') ip = '192.168.178.100' -- ip address of Waterkotte heat pump user = 'XXX' -- username of web interface pwd = 'XXX' -- password of web interface url = 'http://' .. ip .. '/cgi/login?username=' .. user .. '&password=' .. pwd res, code = http.request(url) log('login request', res, code) if res and code == 200 then   token = res:match('%x+')   log('token', token)   if type(token) == 'string' and #token == 32 then     storage.set('ecotouch-token', token)   end end if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A1'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) end
@admin: Many thanks for your help.
I getting a login failure, here is the log:
Waterkotte 07.03.2022 16:22:21 * arg: 1   * string: login request * arg: 2   * string: 1 #S_OK IDALToken=d98d4aa1b188273a90c0440da3f3f9d0 * arg: 3   * number: 200 Waterkotte 07.03.2022 16:22:21 * arg: 1   * string: token * arg: 2   * string: 1 Waterkotte 07.03.2022 16:22:21 * arg: 1   * string: read request * arg: 2   * string: #E_NEED_LOGIN * arg: 3   * number: 500
If I do the steps manual via Firefox browser:
1.)
http://192.168.XXX.XX/cgi/login?username=XXX&password=XXX
[url=http://192.168.178.35/cgi/readTags?n=1&t1=A1][/url]
2.)
http://192.168.XXX.XX/cgi/readTags?n=1&t1=A1
the return is:
#A1    S_OK 192    80
The failure "E_NEED_LOGIN" I getting also in the browser when I don't do step 1 before step 2.
Change line 14 to this and try again:
token = res:match('IDALToken=(%x+)')
@admin: Many thanks, now the login works successful!
Waterkotte 08.03.2022 10:01:43 * arg: 1   * string: login request * arg: 2   * string: 1 #S_OK IDALToken=d09570725af35fbaf13ba699ed6c2a0e * arg: 3   * number: 200 Waterkotte 08.03.2022 10:01:43 * arg: 1   * string: token * arg: 2   * string: d09570725af35fbaf13ba699ed6c2a0e Waterkotte 08.03.2022 10:01:43 * arg: 1   * string: read request * arg: 2   * string: #A19    S_OK 192    363 * arg: 3   * number: 200
„363“ is the value I want to parse and write it to a group address.
@admin: Do you have an idea how to do that?
Add after log('read request', res, code), if it works then you can replace log(value) with grp.checkwrite or grp.checkupdate.
value = res:match('S_OK%s+%d+%s+(%d+)') if value then   value = tonumber(value)   log(value) end
@admin: Many thanks again for your big help! Highly appreciated!
I made two script sets out of it.
The first one is to read the actual values I'm interested in:
http = require('socket.http') ip = 'xxx' -- ip address of Waterkotte heat pump user = 'xxx' -- username of web interface pwd = 'xxx' -- password of web interface url = 'http://' .. ip .. '/cgi/login?username=' .. user .. '&password=' .. pwd res, code = http.request(url) log('login request', res, code) if res and code == 200 then   token = res:match('IDALToken=(%x+)')   log('token', token)   if type(token) == 'string' and #token == 32 then     storage.set('ecotouch-token', token)   end end -- Read actual hot water temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A19'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/1', value/10)    end end os.sleep(1)      -- Read actual source in temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A4'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/2', value/10)    end end os.sleep(1)      -- Read actual source out temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A5'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/3', value/10)    end end os.sleep(1)      -- ************************************************************ -- Read actual return temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A11'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/4', value/10)    end end os.sleep(1)      -- Read actual flow temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A12'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/5', value/10)    end end os.sleep(1)      -- ************************************************************ -- Read actual power compressor **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A25'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/6', value/10)    end end os.sleep(1)      -- Read actual power heating**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A26'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/7', value/10)    end end os.sleep(1)      -- Read actual COP*************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A28'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/8', value/10)    end end -- Read desrired hot water temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A37'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/3/1', value/10)    end end os.sleep(1)    -- Read status heeting mode**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=I30'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)         if value == 1             then             value = true             elseif             value == 0             then             value = false         end       grp.checkupdate('46/3/2', value)    end end os.sleep(1)    -- Read status cooling mode**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=I31'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)         if value == 1             then             value = true             elseif             value == 0             then             value = false         end       grp.checkupdate('46/3/3', value)    end end os.sleep(1)
And the second one to write the desired values:
http = require('socket.http') ip = 'xxx' -- ip address of Waterkotte heat pump user = 'xxx' -- username of web interface pwd = 'xxx' -- password of web interface url = 'http://' .. ip .. '/cgi/login?username=' .. user .. '&password=' .. pwd res, code = http.request(url) log('login request', res, code) if res and code == 200 then   token = res:match('IDALToken=(%x+)')   log('token', token)   if type(token) == 'string' and #token == 32 then     storage.set('ecotouch-token', token)   end end os.sleep(1) -- Write enable heating mode **************************** setvalue = grp.getvalue('46/2/2') if setvalue == true then setvalue = 1     else setvalue = 0 end if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=I30&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     end os.sleep(1) -- Write enable cooling mode **************************** setvalue = grp.getvalue('46/2/3') if setvalue == true then setvalue = 1     else setvalue = 0 end if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=I31&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) end os.sleep(1) -- Write water temperature**************************** setvalue = grp.getvalue('46/2/1') setvalue = setvalue *10 if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=A38&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) end
Generally it works fine EXCEPT when the time between two request is to short I getting the following return in the log and the values are not written to the heatpump:
Waterkotte_Sollwerte 10.03.2022 20:23:55 * arg: 1   * string: login request * arg: 2   * string: -37 #E_TOO_MANY_USERS * arg: 3   * number: 200
@admin: Do you have an idea how to control the situation? Do I need to detect: "#E_TOO_MANY_USERS" and then wait some second and resend? How would this look like? Many thanks for your help!
The login procedure should not be performed for each request. The token is already saved into storage so it should be used in read/write requests. If the request fails with an error then the token should be refreshed.
