14.04.2022, 16:09
(This post was last modified: 14.04.2022, 16:10 by Odd Egil Aasheim.)
Hi.
Just bought this outdoor sensor from Philips, but struggeling to get some data out where it can be used.
I don't want to do something directly inside the Hue system, but to extract data.
The device does not come up in http://<ipadress>/api/<userid>/lights along with my other lamps/led's.
Instead it is visible http://<ipadress>/api/<userid>/sensors
Therefore I tried to modify the user.hue script by adding a section for sensors to search and get data from them.
So far so good.
This is a snippet from the user.hue script where I have duplicated the code, but renamed the original code from i.e function searchHueLights() to function searchHueSensors() and so on.
So "function" 2 and 4 below is new regarding the sensors
By using this code I then can make a new script for searching
the log showing that the search is started.
And a new script for reading data
I get a looooong string, but how can i break it up into the pieces that I want?
Output from Log window, (it all comes in one long line in the log window starting with * string: {... )
Let's say that I'm interested in the lightlevel and temperature
I can't find the fomat to extract the data for now.
Any thoughts how to extract?
So far so good.
-- function 1 existing huesearch
local response = {}
body_searchHueLights= ''
-- Set username for LogicMachine
socket.http.request({
url = "http://"..ip_add.."/api/"..user.."/lights",
method = 'POST',
sink = ltn12.sink.table(response),
headers = {
['content-length'] = #body_searchHueLights,
['content-type'] = 'application/json',
source = ltn12.source.string(body_searchHueLights),
return response
-- function 2 new huesearch
local response = {}
body_searchHueSensors= ''
url = "http://"..ip_add.."/api/"..user.."/sensors",
method = 'POST',
headers = {
['content-length'] = #body_searchHueSensors,
source = ltn12.source.string(body_searchHueSensors),
return response
-- function 3 existing hue datacollection
function getHueLights()
local response = {}
method = 'GET',
headers = {
return response
-- function 4 new hue datacollection
function getHueSensors()
local response = {}
method = 'GET',
headers = {
return response
endBy using this code I then can make a new script for searching
require('user.hue')
-- get bridge to search for new lights
result = searchHueLights()
log(result)And a new script for reading data
require('user.hue')
-- get all sensordata from bridge
result = getHueSensors()
log(result)Output from Log window, (it all comes in one long line in the log window starting with * string: {... )
Read Hue devices 14.04.2022 17:50:36
* table:
[1]
* string: {"1":{"state":{"daylight":null,"lastupdated":"none"},"config":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Signify Netherlands B.V.","swversion":"1.0"},"2":{"state":{"presence":false,"lastupdated":"2022-04-14T15:29:10"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","sensitivity":2,"sensitivitymax":4,"ledindication":false,"usertest":false,"pending":[]},"name":"OutdoorSensor","type":"ZLLPresence","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor motion sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0406","capabilities":{"certified":true,"primary":true}},"3":{"state":{"lightlevel":7186,"dark":true,"daylight":false,"lastupdated":"2022-04-14T15:50:23"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","tholddark":16000,"tholdoffset":7000,"ledindication":false,"usertest":false,"pending":[]},"name":"Hue outdoor light sensor 1","type":"ZLLLightLevel","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor light sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0400","capabilities":{"certified":true,"primary":false}},"4":{"state":{"temperature":2410,"lastupdated":"2022-04-14T15:48:19"},"swupdate":{"state":"noupdates","lastinstall":"2022-04-13T18:57:32"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"pending":[]},"name":"Hue outdoor temp. sensor 1","type":"ZLLTemperature","modelid":"SML004","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor temp. sensor","swversion":"2.53.6","uniqueid":"00:17:88:01:0b:d1:3a:b5-02-0402","capabilities":{"certified":true,"primary":false}}}Let's say that I'm interested in the lightlevel and temperature
