Get group address from event script
Is it possible to obtain the group adress of an object from which an event script was triggered?
I have a number of objects that have the same tag and an event script triggered by the tag. When the scripts executes, I now check each object with an if ... elseif until I find the object.
It would be more elegant and possibly quicker if I could determine the object directly.
Use event.dst
(04.01.2017, 13:03)Erwin van der Zwart Wrote: Hi,
Use event.dst
Hello Erwin,
Is this documented somewhere? I looked at the documentation mentioned in the first post of this section but could not find it...
Thx
EDIT: OK, this was a case of just RTFM... Blush
