Bose Processor
Hello
trying to control a bose processor ESP 880A via http request to set an input and change volume,
https://firstandsecondhomes.com/assets/u...v1.1.0.pdf
i used this exemple found and i still get "connexion failed"
http = require('socket.http')
IP = '192.168.5.160'
url = 'http://' .. IP .. ':8090/volume>$20'
res, err = http.request(url)
log(res, err)
any insights ?
Can you ping this IP from LM (System config > Status > Network utilities)? Can you access this URL from your browser?
The code for setting the volume is incorrect, use this:
http = require('socket.http') volume = 20 data = '<volume>' .. volume .. '</volume>' IP = '192.168.5.160' url = 'http://' .. IP .. ':8090/volume' res, err = http.request(url, data) log(res, err)
