3 hours ago
I'd like to SSH into our Unifi Switches to run a 1 line command to turn on/off a POE connected device.
While a POE reboot is is possible with the Unifi API, switching a port off for an extenede period of time is not - so SSH seems like a simple solution. This is the command that need to be executed
How does one SSH to the switch at 192.168.1.100 from a lua script?
If it helps, one can connect to the Unifi switch with a SSH key instead of a password.
Many thanks in advance
Kind Regards
James
ssh admin@192.168.1.100
<enter password as prompted>
swctrl poe set off id 45
Kind Regards
James
