script for scene change
I need a script for changing scene’s in a sequence ( scene1 … scene10 ) when we do a short “press-up” or “press-down” on a knx keypad.
 Example when we short “press-up”  the first time scene1 is triggered and it progresses to scene10 on the 10th short press. On the 11th short press scene1 is triggered again .
Similarly, when we do a short “press-down” the scene10 to scene9 and so on. In this case when we reach scene1 we jump scene10 after the short “press-down”.
thnx
vik
Attach your scenes to 1 byte unsigned object with trigger value from 1 to 10. Create an event script for scene up/down (1 bit). Change scene trigger object (32/1/17) as needed.
out = '32/1/17' up = event.getvalue() nr = grp.getvalue(out) if up then   nr = nr + 1   if nr > 10 then     nr = 1   end else   nr = nr - 1   if nr < 1 then     nr = 10   end end grp.update(out, nr)
(26.04.2022, 11:25)Vik Wrote: Hi,
thnx
vik
Thanks I will try this script
We need your hrlp on another script.
We would like to disable a ceiling mount motion sensors whenever we do a "long-press" ( relative dimm).
To disable the sensor we need a 1-bit data while the relative dimm is a 4bit data type.
We need a script which can disable the sensor whenever a long press is done.
regards,
vik
Just create event script on the dim object, change group as needed and if the disable value is 0 then change true to false
-- write value (e.g. boolean 'true') to object with group address 1/1/1, datatype must be set for this object grp.write('1/1/1', true)
(26.04.2022, 11:35)admin Wrote: Attach your scenes to 1 byte unsigned object with trigger value from 1 to 10. Create an event script for scene up/down (1 bit). Change scene trigger object (32/1/17) as needed.
Thank you for this. it worked fine.
(26.04.2022, 14:20)Daniel Wrote: Just create event script on the dim object, change group as needed and if the disable value is 0 then change true to false
Thanks a lot for this. This worked fine too.
