14.06.2017, 07:30
Ok so I have a resident script using a copas udp server on the localhost to receive commands from knx objects (event script) , then there is a copas tcp client connecting to an tcp server on the local network. I did it this way so they don't block each other. The issue I am experiencing is that when the tcp server sends out an percentage character the tcp client stops receiving anything else from the server.
Does someone have an idea?
Thanks,
Roger
Thanks,
Roger
if not ready then
socket = require("socket")
copas = require("copas")
alert('not Ready')
ready=true
function parse(data)
alert('parsing... '..data)
function fromKNX(command)
alert('from KNX.. '..command)
local server = socket.udp()
server:setsockname("127.0.0.1",23456)
function handler(skts)
skts = copas.wrap(skts)
alert("UDP connection handler")
while true do
local s, err
alert("UDP receiving...")
s, erro = skts:receive(2048)
if not s then
alert("UDP Receive error: ", erro)
break
alert("Received data, bytes: "..s)
fromKNX(s)
copas.addserver(server, handler, 1)
if not skt then
alert('not socket')
if skt then
skt:close()
skt = nil
-- create tcp client
skt, err = socket.connect('10.10.10.41', 4999)
skt:settimeout(0)
copas.addthread(function()
while true do
local resp,err = copas.receive(skt)
if not resp then
alert("TCP Receive error: ", err)
break
parse(resp)
end)
-- connect ok, reset buffer
if skt then
alert('[tcp-client] connection ok')
warningfailed = true
init()
-- error while connecting,
if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end
warningfailed = false
copas.loop()
