websocket library help
Referring to post Websocket post we are able to connect to websocket.  Now when I try to connect to a secure websocket using copas and the url includes a query string then the query string is dropped. for example.  How can we solve this?
if not skt then  --add receive thread  copas.addthread(function()      local reconnect = function()        local url= "wss://192.168.0.54:8002/api/v2/channels/remote.control?name=MTUyNjQ1MTQ="        skt,err = ws.client('copas',0)        local noerr,a = skt:connect(url)        if(noerr==true) then                  init()        else          alert('[tcp-client] error connecting %s',a)          return        end            end      if not skt or skt==nil or skt.state=='CLOSED' then        reconnect()              end      if(skt) then        while true do          local resp,err = copas.receive(skt)          -- if theres no connection start a new connection          if(skt.state=='CLOSED')then            if not resp then              alert("[tcp-client] Receive error: %s", err)              copas.removeserver(skt)              skt = nil              break            end          else            local fd,prtd = pcall(parse,resp)            if(fd==false)then              alert("Error with parsemsg %s ",prtd)            end          end        end            end    end)   end
Replace upgrade_request function:
local upgrade_request = function(req, key)   local format = string.format   local uri = req.path or ''   local query = req.query   if type(query) == 'string' and #query > 0 then     uri = uri .. '?' .. query   end   local lines = {     format('GET %s HTTP/1.1', uri),     format('Host: %s', req.host),     'Upgrade: websocket',     'Connection: Upgrade',     format('Sec-WebSocket-Key: %s',key),     'Sec-WebSocket-Version: 13',   }   if req.port and req.port ~= 80 then     lines[2] = format('Host: %s:%d', req.host, req.port)   end   if req.userinfo then     local auth = format('Authorization: Basic %s', base64enc(req.userinfo))     tinsert(lines, auth)   end   tinsert(lines,'\r\n')   return tconcat(lines,'\r\n') end
