Logicmachine + Neato JS SDK
I have problem with combining logicmachine and neato robot sdk. I have developed my sdk website which must control my robot.
For example:
If i write https://mywebsite.com/robot.php?start_robot=2 then my robot should start and
https://mywebsite.com/robot.php?start_robot=1 should stop.
When website fully loaded then need 3-4 more seconds to start robot script. I tried to implement this url to logicmachine http request, but its not working.
For example(logicmachine script):
local http = require('socket.http')
value = event.getvalue()
if(value == true) then
    body = http.request('https://mywebsite.com/robot.php?start_robot=2')
    body = http.request('https://mywebsite.com/robot.php?start_robot=1')
How i should deal with this situation?
Hi try this
robot = '2' https = require('ssl.https') escape = require('socket.url').escape url = 'https://mywebsite.com/robot.php?start_robot=%s' url = string.format(url, escape(robot)) res = https.request(url) log(res)
(14.03.2019, 13:33)Daniel. Wrote: Hi try this
* string: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>400 Bad Request</title> </head><body> <h1>Bad Request</h1> <p>Your browser sent a request that this server could not understand.<br /> </p> <p>Additionally, a 400 Bad Request error was encountered while trying to use an ErrorDocument to handle the request.</p> </body></html>
Maybe should i try implement some header?
Quote:Additionally, a 400 Bad Request error was encountered while trying to use an ErrorDocument to handle the request
This means that something is wrong with your Apache configuration.
