[?] random alert via mail
HI
sceneario:
one of the group adresses formated as 1.005 is giving 'alert'
problem:
send goup adress(es) via mail.
question:
is there any posible fitler integrated apart form a huge script?
(Mailing part is solved)
Can you explain what filter do you want?
The easiest way to send multiple group address values is to assign a tag.
This example will output one name = value pair per line for all objects with alert tag:
values = {} objects = grp.tag('alert') for _, obj in ipairs(objects) do   value = string.format('%s = %s', tostring(obj.name), tostring(obj.value))   values[ #values + 1 ] = value end result = table.concat(values, '\r\n') log(result)
(24.06.2019, 08:24)admin Wrote: The easiest way to send multiple group address values is to assign a tag.
THX!
its close to my target. I didnt want need to tagging before, but its fine.
My aim was to filter groups in format 1.005 set to 'true' to create a alert mail including all alerts in case of alarts only.
Best
