HELP luasocket changed in build 31
Please help.  I have the LM5 running RC1 firmware.  Luasocket is upgraded to luasocket_2.0.2-31_imx6.ipk  it was working in the 29 build.  This particular LM5 is running resident scripts for a websocket client which is working.  I really don't want to break that.
The UDP server does not receive when I have the TCP client active.  I can comment out the TCP client then it works.  The event script can send to the resident script fine.  I have tried changing the timeout value for both TCP client and the UDP server.  Makes no difference.  I need to use copas because I have delay commands sent out to the TCP device.
Does anyone have an idea.
Resident script on 0 seconds
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162636465666768697071727374757677787980818283
if not ready then   copas = require("copas")   socket = require("socket")   server = socket.udp()   server:setsockname("127.0.0.1",51034)   function handler(uskt)     uskt = copas.wrap(uskt)     log("UDP connection handler")     while true do       local s, err       log("receiving...")       s, err = uskt:receive(1024)       if not s then         log("Receive error: ")         log(err)         return       end       log("Received data, bytes:")       log(s)     end   end   copas.addserver(server, handler, 0)     function parse(data)     log(data)   end     function sendtcp(command)     skt:send(command)     sleep(0.5)      end       function init()     log('in init')     sendtcp('#COSMSGS=false\r')        sendtcp('#MODEL?\r')     end   ready=true end if not skt then   --add receive thread   copas.addthread(function()       local reconnect = function()         skt, err = socket.connect('192.168.0.175', 4999)         skt:settimeout(1)         if(not err) then                  init()         else           log('[tcp-client] error connecting ')           return         end            end       if not skt or skt==nil or skt.state=='CLOSED' then         reconnect()       end       if(skt)then         while true do           local resp,err = skt:receive('*r')           -- if theres no connection start a new connection           if(skt.state=='CLOSED')then             if not resp then               log("[tcp-client] Receive error: ")               copas.removethread(skt)               skt = nil               break             end           else             if(resp~=nil) then               local fd,prtd = pcall(parse,resp)               if(fd==false)then                 log("Error with parsemsg")               end             end           end         end            end     endend copas.loop()
Event script
if event.type=='groupwrite' then   local socket = require('socket')   local client = socket.udp()   local evt = event.dst..','..tostring(grp.getvalue(event.dst))   log(evt)   if client then     client:sendto(evt, '127.0.0.1', 51034)     client:close()   end elseif event.type =='groupread' then   grp.response(event.dst,grp.getvalue(event.dst)) end
I'll check this more thoroughly but there are some issues with your script:
1. Do not use socket.connect() because it is blocking, use copas.connect()
2. There's no need to pass any length to UDP receive. Without any length it will return one datagram (or error on timeout) per call
3. Your reconnect procedure seems wrong, you don't have to call removethread and sockets do not have state field
4. sendtcp does not check if socket is connected/available
copas.connect is blocking also. is there a working example with copas?
Roger
From docs:
copas.connect(skt, address, port)
Connects and transforms a master socket to a client just like LuaSocket socket:connect(). The Copas version does not block and allows the multitasking of the other handlers and threads.
That's what I did  and removed the bad stuff.  Still blocks out.  tried with or without timeout and timeout of 0 and 1.
if not skt then   --add receive thread   copas.addthread(function()      skt = socket.tcp()               err = copas.connect(skt,'192.168.0.175', 4999)        skt:settimeout(1)        log(skt)        log(err)       if(skt)then         init()         while true do           local resp,err = skt:receive('*r')             if(resp~=nil) then               local fd,prtd = pcall(parse,resp)               if(fd==false)then                 log("Error with parsemsg")               end             end         end            end     end) end
Working example:
if not ready then   copas = require('copas')   socket = require('socket')   udpserver = socket.udp()   udpserver:setsockname('127.0.0.1', 51034)   function udphandler(udpsock)     udpsock = copas.wrap(udpsock)     log('udp connection handler')     while true do       local data, err = udpsock:receive()       if data then         log('received data', data)       end     end   end   function parse(data)     log(data)   end   function sendtcp(command)     if connected then       tcpsock:send(command)       copas.sleep(0.5)     end   end   ready = true   function tcpconnect()     local sock = socket.tcp()     tcpsock = copas.wrap(sock)     tcpsock:settimeout(1)     connected, err = tcpsock:connect('192.168.0.175', 4999)     if connected then       log('connect ok')       sendtcp('#COSMSGS=false\r')       sendtcp('#MODEL?\r')     else       log('connect failed', err)       copas.sleep(1)     end   end   function tcphandler()     while true do       if connected then         local resp, err = tcpsock:receive('*r')         if resp then           local status, data = pcall(parse, resp)           if not status then             log('parse failed', data)           end         elseif err == 'closed' then           log('disconnected')           connected = false           tcpsock:close()           tcpsock = nil           collectgarbage('step')           copas.sleep(1)         end       end       if not connected then         tcpconnect()       end     end   end   copas.addserver(udpserver, udphandler, 0)   copas.addthread(tcphandler) end copas.loop()
Yes it works, BIG thank you. Perfect. Have a great day.
Thanks,
Roger
