21.10.2019, 05:15
(This post was last modified: 21.10.2019, 05:23 by josemabera.)
Good morning:
I made a script so that when a window of a room is opened, the thermostat goes into protection mode.
Once the summer is over, when the heating is switched on and the system is in heating mode the thermostat is put in protection mode even when all the windows are closed, I have no remote connection to the installation but I imagine that the problem is that since LM does not perform the Change from cooling mode to heating mode, any suggestions?
The script is as follows
local ModoCalefaccion = grp.getvalue ("0/1/0")
local ModoTermostato = "6/7/1"
local tagname = 'ContatosVentanacocinasaloncomedor'
if ModoCalefaccion then
for _, obj in ipairs(grp.tag(tagname)) do --lee todos los objetos si se cumple la condicion (ventana abierta) pone el termostato en modo proteccion
--si una vez leidos todos no se ha cumplido la condicion escribe en el modo false
if obj.value then --Al menos una ventana esta abierta
grp.checkwrite(ModoTermostato ,true)
return
grp.checkwrite(ModoTermostato,false) -- Todas las ventanas estan cerrada
return
