Creat logs in txt file
Good day!
Can you help me with such question:
I need to create regular log files *txt type. Each day it will be a new file with a name like date. It is necessary to save it on any shared local net folder
thank you
Here is a part of my daily report script. It runs in a scheduled script every day at 00:00 and creates a csv file in /tmp folder for object logs of previous day.
PS: Credit for parts of the script goes to Edgars  Wink
-- Set logtime start-end and date to get past day data date = os.date('*t') date.hour=0 date.min=0 date.sec=0 log_end=os.time(date)-1 date.day = date.day - 1 log_start=os.time(date) dates = {  ['start'] = date,  ['end'] = os.date('*t'), } -- Log filename logfile=string.format('DailyLog_%s.csv', os.date('%d-%m-%Y',log_start)) -- list of objects by id objects = {} -- Select objects address and datatype query = 'SELECT address, datatype, name FROM objects' for _, object in ipairs(db:getall(query)) do objects[ tonumber(object.address) ] = { datatype = tonumber(object.datatype), name = tostring(object.name or ''), } end -- csv buffer buffer = { '"date","address","name","value"' } -- get object logs -- query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC' query = 'SELECT * FROM objectlog WHERE logtime >='..log_start.. ' and logtime<=' .. log_end.. ' ORDER BY id' for _, row in ipairs(db:getall(query)) do object = objects[ tonumber(row.address) ] -- found matching object and event type is group write if object and row.eventtype == 'write' then datatype = object.datatype -- check that object datatype is set if datatype then -- decode data data = knxdatatype.decode(row.datahex, datatype) -- remove null chars from char/string datatype if datatype == dt.char or datatype == dt.string then data = data:gsub('%z+', '') -- date to DD.MM.YYYY elseif datatype == dt.date then data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year) -- time to HH:MM:SS elseif datatype == dt.time then data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second) end else data = '' end -- format csv row logdate = os.date('%d/%m/%Y %H:%M:%S', row.logtime) csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data)) -- add to buffer table.insert(buffer, csv) end end -- write file only when there's data in buffer if #buffer > 1 then result, err = io.writefile ('/tmp/'..logfile, table.concat(buffer, '\r\n')) log('Created log file '..logfile) end -- error while writing if err then alert('File write error: %s', tostring(err)) end
(27.04.2017, 21:55)gtsamis Wrote: Here is a part of my daily report script. It runs in a scheduled script every day at 00:00 and creates a csv file in /tmp folder for object logs of previous day.
Sorry, but it is necessary to create only txt files
You just need to change the extension to txt on logfile=string.format('DailyLog_%s.csv', os.date('%d-%m-%Y',log_start)) to
logfile=string.format('DailyLog_%s.txt', os.date('%d-%m-%Y',log_start))
the structure although will be the same.
I "stole" this script (thank you). It runs perfect, but how can I access (download to PC) the CSV file produced?
I have tried Filezilla and can access the Wiser/SL successfully, but neither the user "ftp" nor the user "app" display anything that resembles "/tmp/......" which is the path used above in the following line: result, err = io.writefile ('/tmp/'..logfile, table.concat(buffer, '\r\n'))
Thanks in advance
FTP path is /home/ftp, just make sure that you have some algorithm to delete old files. Otherwise you can run out of free space at some point.
(02.04.2020, 11:20)admin Wrote: FTP path is /home/ftp, just make sure that you have some algorithm to delete old files. Otherwise you can run out of free space at some point.
I'm still confused on this point. I used Filezilla to connect and placed a doorbell sound file (at what I'm taking from your post above is /home/ftp). My ftp login was user ftp (can choose from ftp or apps). But my Custom Javascript file appears not to see the copied file. For example, in the following file if I uncomment and use the mozilla file, the sound plays fine. But when written as shown here with the local file, the code does not work. Is it a linux permissions thing?
// the following function plays a sound when the doorbell is pressed (Object 0/250/72 is set true) // FTP path is /home/ftp (use Filezilla to put sound file there) $(function(){    grp.listen('0/250/72', function(object) {       if (object.value == true ) { //        var audio = new Audio('https://interactive-examples.mdn.mozilla.net/media/examples/t-rex-roar.mp3');         var audio = new Audio('/home/ftp/Doorbell.mp3');         audio.play();       }    }); });
Can you help me?
Thanks!
See this thread: https://forum.logicmachine.net/showthrea...20#pid7920
You need to use apps ftp username and upload to user directory.
Thanks! That is very well explained there and now works fine for me.
As always, thanks for your quick and helpful replies. Much appreciated.
I am not able to find this file...
I log in with FileZilla with both "apps" and "ftp", but cannot find this folder. I have neihter the folder /home/ftp
In the script I log the err, result, and get true for result and nil for err.
The example script writes to /tmp/, which cannot be accessed via FTP. /home/ftp/ is the absolute path for writing from scripts. If you access FTP using ftp user then any file placed into /home/ftp/ will be visible in the base directory.
result, err = io.writefile('/home/ftp/' .. logfile, table.concat(buffer, '\r\n'))
How can old files be deleted?
For writing to new file one will use io.writefile, is there a similar for delete? I have tried to find it, but no luck...
os.remove is what you need
"I am not able to find this file...
I log in with FileZilla with both "apps" and "ftp", but cannot find this folder. I have neihter the folder /home/ftp" . I changed
if #buffer > 1 then
result, err = io.writefile ('/home/ftp/'..logfile, table.concat(buffer, '\r\n'))
Can anyone see where that file is saved? Sad I can't see where that file is
Help me !!  Can you explain more clearly how to do it, where to put this script, how to get the saved file? Because I don't see it Sad
Use ftp login and check base (top level) directory, the one that is marked as /
(18.06.2024, 08:14)admin Wrote: Use ftp login and check base (top level) directory, the one that is marked as /
The mean ! Sad
I still don't see anything.
I still don't see anything. I use version 20230612
What logs and alerts says after running the script?
hi Daniel !
I don't see anything in Alerts and Logs. Prove that the script runs well
Script from post #2 won't create a file if there are no logs in the given period.
(18.06.2024, 08:36)admin Wrote: Script from post #2 won't create a file if there are no logs in the given period.
what do you mean? I don't quite understand, do you mean this script? Sad
date.hour=0
date.min=0
date.sec=0
dates = {
['start'] = date,
-- Log filename
objects = {}
-- csv buffer
-- get object logs
if datatype then
-- decode data
-- time to HH:MM:SS
data = ''
-- format csv row
-- add to buffer
if #buffer > 1 then
if err then
