Good day!
Can you help me with such question:
I need to create regular log files *txt type. Each day it will be a new file with a name like date. It is necessary to save it on any shared local net folder
27.04.2017, 21:55 (This post was last modified: 27.04.2017, 22:13 by gtsamis.)
Here is a part of my daily report script. It runs in a scheduled script every day at 00:00 and creates a csv file in /tmp folder for object logs of previous day.
PS: Credit for parts of the script goes to Edgars
-- Set logtime start-end and date to get past day data
date = os.date('*t')
date.hour=0
date.min=0
date.sec=0
log_end=os.time(date)-1
date.day = date.day - 1
log_start=os.time(date)
-- Select objects address and datatype
query = 'SELECT address, datatype, name FROM objects'
for _, object in ipairs(db:getall(query)) do
objects[ tonumber(object.address) ] = {
datatype = tonumber(object.datatype),
name = tostring(object.name or ''),
-- get object logs
-- query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
query = 'SELECT * FROM objectlog WHERE logtime >='..log_start.. ' and logtime<=' .. log_end.. ' ORDER BY id'
for _, row in ipairs(db:getall(query)) do
object = objects[ tonumber(row.address) ]
-- found matching object and event type is group write
if object and row.eventtype == 'write' then
datatype = object.datatype
-- check that object datatype is set
if datatype then
-- decode data
data = knxdatatype.decode(row.datahex, datatype)
-- remove null chars from char/string datatype
if datatype == dt.char or datatype == dt.string then
data = data:gsub('%z+', '')
-- date to DD.MM.YYYY
elseif datatype == dt.date then
data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
-- time to HH:MM:SS
elseif datatype == dt.time then
data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
data = ''
-- add to buffer
table.insert(buffer, csv)
-- write file only when there's data in buffer
if #buffer > 1 then
result, err = io.writefile ('/tmp/'..logfile, table.concat(buffer, '\r\n'))
log('Created log file '..logfile)
-- error while writing
if err then
alert('File write error: %s', tostring(err))
02.05.2017, 14:41 (This post was last modified: 02.05.2017, 14:42 by deimostier.)
(27.04.2017, 21:55)gtsamis Wrote: Here is a part of my daily report script. It runs in a scheduled script every day at 00:00 and creates a csv file in /tmp folder for object logs of previous day.
date.hour=0
date.min=0
date.sec=0
-- get object logs
if datatype then
-- decode data
-- time to HH:MM:SS
data = ''
-- add to buffer
if #buffer > 1 then
if err then
Sorry, but it is necessary to create only txt files
date.hour=0
date.min=0
date.sec=0
-- get object logs
if datatype then
-- decode data
-- time to HH:MM:SS
data = ''
-- add to buffer
if #buffer > 1 then
if err then
You just need to change the extension to txt on logfile=string.format('DailyLog_%s.csv', os.date('%d-%m-%Y',log_start)) to logfile=string.format('DailyLog_%s.txt', os.date('%d-%m-%Y',log_start))
the structure although will be the same.
I "stole" this script (thank you). It runs perfect, but how can I access (download to PC) the CSV file produced?
I have tried Filezilla and can access the Wiser/SL successfully, but neither the user "ftp" nor the user "app" display anything that resembles "/tmp/......" which is the path used above in the following line: result, err = io.writefile ('/tmp/'..logfile, table.concat(buffer, '\r\n'))
(02.04.2020, 11:20)admin Wrote: FTP path is /home/ftp, just make sure that you have some algorithm to delete old files. Otherwise you can run out of free space at some point.
I'm still confused on this point. I used Filezilla to connect and placed a doorbell sound file (at what I'm taking from your post above is /home/ftp). My ftp login was user ftp (can choose from ftp or apps). But my Custom Javascript file appears not to see the copied file. For example, in the following file if I uncomment and use the mozilla file, the sound plays fine. But when written as shown here with the local file, the code does not work. Is it a linux permissions thing?
// the following function plays a sound when the doorbell is pressed (Object 0/250/72 is set true)
// FTP path is /home/ftp (use Filezilla to put sound file there)
$(function(){
grp.listen('0/250/72', function(object) {
if (object.value == true ) {
// var audio = new Audio('https://interactive-examples.mdn.mozilla.net/media/examples/t-rex-roar.mp3');
var audio = new Audio('/home/ftp/Doorbell.mp3');
audio.play();
I am not able to find this file...
I log in with FileZilla with both "apps" and "ftp", but cannot find this folder. I have neihter the folder /home/ftp
In the script I log the err, result, and get true for result and nil for err.
The example script writes to /tmp/, which cannot be accessed via FTP. /home/ftp/ is the absolute path for writing from scripts. If you access FTP using ftp user then any file placed into /home/ftp/ will be visible in the base directory.
How can old files be deleted?
For writing to new file one will use io.writefile, is there a similar for delete? I have tried to find it, but no luck...
18.06.2024, 08:03 (This post was last modified: 18.06.2024, 08:12 by phongvucba.)
"I am not able to find this file...
I log in with FileZilla with both "apps" and "ftp", but cannot find this folder. I have neihter the folder /home/ftp" . I changed
if #buffer > 1 then
result, err = io.writefile ('/home/ftp/'..logfile, table.concat(buffer, '\r\n'))
Can anyone see where that file is saved? I can't see where that file is
date.hour=0
date.min=0
date.sec=0
-- get object logs
if datatype then
-- decode data
-- time to HH:MM:SS
data = ''
-- add to buffer
if #buffer > 1 then
if err then
Help me !! Can you explain more clearly how to do it, where to put this script, how to get the saved file? Because I don't see it
18.06.2024, 08:44 (This post was last modified: 18.06.2024, 08:45 by phongvucba.)
(18.06.2024, 08:36)admin Wrote: Script from post #2 won't create a file if there are no logs in the given period.
what do you mean? I don't quite understand, do you mean this script?
date.hour=0
date.min=0
date.sec=0
-- get object logs
if datatype then
-- decode data
-- time to HH:MM:SS
data = ''
-- add to buffer
if #buffer > 1 then
if err then
