Sending email
Big Grin
After some testing I discovered that when sending an email to multiple recipients the 'to' variable wasn't being converted to an table.  It would create a table but only contained one row.  Below is a revised version of the send email script.  Make sure that each recipient is separated with a comma,  ie...  mail('your@first.com, your@second.com, your@third.com', 'some subject', 'some message')
In addition to this, when you want to send via an email server that does not require ssl, just comment out the line, secure='sslv23'
Thanks,
Roger
-- send an e-mail function mail(to, subject, message)  -- make sure these settings are correct  local settings = {    -- "from" field, only e-mail must be specified here    from = 'example@gmail.com',    -- smtp username    user = 'example@gmail.com',    -- smtp password    password = 'mypassword',    -- smtp server    server = 'smtp.gmail.com',    -- smtp server port    port = 465,    -- enable ssl, required for gmail smtp    secure = 'sslv23',  }  local smtp = require('socket.smtp')  if type(to) ~= 'table' then     to = string.split(to,', ')  end  for index, email in ipairs(to) do    to[ index ] = '<' .. tostring(email) .. '>'  end  -- message headers and body  settings.source = smtp.message({    headers = {      to = table.concat(to, ', '),      subject = subject,      ['Content-type'] = 'text/html; charset=utf-8',    },    body = message  })  -- fixup from field  settings.from = '<' .. tostring(settings.from) .. '>'  settings.rcpt = to  return smtp.send(settings) end
