irrigazione con sensore pioggi
Good morning everyone,
I ask you top experts if there is a preconfigured script (macro) for the management of 4/8 irrigation areas that provides the possibility of:
- schedule the start of the irrigation cycle for each zone and for a defined time for each individual zone, a sort of sequence scenario that starts the zones active in the cycle successively one after the other,
- insert a block for each zone to allow one or more specific zones to be blocked in the cycle,
- activate the irrigation block according to the rain sensor (1bit from a digital input),
- insert a filter for each zone that brings a reduction in the preset irrigation time based on comparison with a soil humidity sensor (example: zone 1 - time 10 'if soil moisture value> 40% 20% reduction .. then will be 8 '),
I await kind support and feedback, thank you
Here's a similar script that has configurable enable and timer value via objects:
https://forum.logicmachine.net/showthrea...61#pid8161
Hi Hosutech,
I once made a very simple script for this. Please find a copy below. It's a start of what you need but you need to extend it with some extra functionality but that al are simple conditions i would say..
start_stop = grp.getvalue('15/2/0') -- start stop
minuten = grp.getvalue('15/2/1') -- time per section (minutes, byte value)
sectie_1 = grp.getvalue('15/2/3') -- section 1
sectie_2 = grp.getvalue('15/2/4') -- section 2
sectie_3 = grp.getvalue('15/2/5') -- section 3
sectie_4 = grp.getvalue('15/2/7') -- section 4
minuten = minuten * 60 -- time calculation to minutes
stored_pomp_pid = storage.get('storage_pomp_pid')
if stored_pomp_pid == nil then
pid = os.getpid()
storage.set('storage_pomp_pid', pid)
pid = os.getpid()
os.kill(stored_pomp_pid, signal.SIGKILL)
if start_stop == true then
if sectie_1 == true then
grp.write('0/2/3', true) -- section 1
os.sleep(minuten) -- time per section
grp.write('0/2/3', false) -- section 1
if sectie_2 == true then
grp.write('0/2/4', true) -- section 2
grp.write('0/2/4', false) -- section 2
if sectie_3 == true then
grp.write('0/2/5', true) -- section 3
grp.write('0/2/5', false) -- section 3
if sectie_4 == true then
grp.write('0/2/7', true) -- section 4
grp.write('0/2/7', false) -- section 4
(23.04.2020, 14:45)Joep Wrote: Hi Hosutech,
    pid = os.getpid()
    pid = os.getpid()
Thanks JOEP
I try your script and let you know.
To make good
(23.04.2020, 14:42)admin Wrote: Here's a similar script that has configurable enable and timer value via objects:
well thanks, I try it and let you know
