4-bit to 1-byte conversion script for DALI, DMX512 etc.
Resident script (sleep interval = 0), which is doing conversion from 4-bit to 1-byte
4-bit dimmer object adress is 1/1/1
1-byte output object adress is 1/1/2
By default, script will change value by 10% every 0.2 seconds when any kind of up/down telegram is received.
123456789101112131415161718192021222324
dimmer = grp.getvalue('1/1/1') step = bit.band(dimmer, 0x07) if step ~= 0 then  addr = '1/1/2'   up = bit.band(dimmer, 0x08) ~= 0   value = grp.getvalue(addr)   if up then     newvalue = value + 10   else     newvalue = value - 10   end   -- clamp between 0 and 100   newvalue = math.min(newvalue, 100)   newvalue = math.max(newvalue, 0)   if newvalue ~= value then     grp.write(addr, newvalue)   end end os.sleep(0.2)
(02.07.2015, 08:32)edgars Wrote: Resident script (sleep interval = 0), which is doing conversion from 4-bit to 1-byte
I just cant make this work. I get an message: Lua syntax error at line 6: '=' expected near 'up'   It might just be too late at night...
edit:
Sorry.. just found the error... When copying your code RAW, and replacing it with my group addresses, something happened with the spaces.. When I deleted all space before code.. It worked.. adding space, still works?.. anyway, some copy-problems, works superb now.. thanks
Dont underestimate the Power of KNX
Darth Paul
Hello, I've been using this script succesfully for about 2 years to be able to control the volume of my Sonos system directly from KNX Berker pushbuttons.
I now tried to do the same thing to make simulatious dimming of multiple lights from 1 button possible but for some reason I am getting an error message: "bad argument, number expected, got boolean)
I've checked in ETS and address '2/1/17' is defined as 4 bit.
Anybody an idea on what I might be doing wrong here?
Thanks, David
Check that 2/1/17 has 4-bit type in LM Objects tab, ETS settings does not matter
(06.10.2018, 12:42)admin Wrote: Check that 2/1/17 has 4-bit type in LM Objects tab, ETS settings does not matter
Yep, that did the trick. Thanks a lot. Forgot that I have to define the objects in both ETS and LM  Blush
Change the +10, -10 in the code as you need
(03.06.2021, 08:29)Daniel. Wrote: Change the +10, -10 in the code as you need
I think that I missed the os.sleep was at 5sec, so changed it to 1sec.
Havent been able to try it out, but think that this was my issue Smile
EDIT:
I found that my issu was that I had set up an event based script, so this was just executed once, now I changed it to a resident script insted.
