I am unable to perform the firmware upgrade, not sure what is wrong with my LM4 running i.MX28 CPU, looks that the logs are indicating some filesystem errors:
I have also enclosed some images with what I see after trying to upgrade the firmware on my LM4. Basically, the FW version has remained the same as before doing the upgrade.
Sep 18 16:15:42 LogicMachine kern.notice kernel: [ 20.411877] random: nonblocking pool is initialized
Sep 18 16:15:28 LogicMachine user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Sep 18 16:15:28 LogicMachine kern.info kernel: [ 6.740689] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 5.297110] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 5.295976] EXT4-fs (mmcblk0p3): recovery complete
Sep 18 16:15:26 LogicMachine user.info sysinit: /dev/mmcblk0p3: ********** WARNING: Filesystem still has errors **********
Sep 18 16:15:26 LogicMachine user.info sysinit: e2fsck: unable to set superblock flags on /dev/mmcblk0p3
Sep 18 16:15:26 LogicMachine user.info sysinit: Run journal anyway? yes
Sep 18 16:15:26 LogicMachine user.info sysinit: Superblock needs_recovery flag is clear, but journal has data.
Sep 18 16:15:26 LogicMachine user.info sysinit: /dev/mmcblk0p3: recovering journal
Sep 18 16:15:26 LogicMachine user.info sysinit: e2fsck 1.44.1 (24-Mar-2018)
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 4.743869] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Sep 18 16:15:25 LogicMachine kern.info kernel: [ 3.410789] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 3.084580] watchdog timeout 60 seconds
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.873651] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.175997] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168984] usb 2-1: SerialNumber: 12345678-9012-3456-7890-123456789012
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168946] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168884] usb 2-1: New USB device found, idVendor=0658, idProduct=0200
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.029903] usb 2-1: new full-speed USB device number 2 using ci_hdrc
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.992137] Freeing unused kernel memory: 140K
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.991353] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.991182] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.988936] EXT4-fs (mmcblk0p2): recovery complete
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.914325] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.914267] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.820560] mmcblk0: p1 p2 p3
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.817422] mmcblk0: mmc0:59b4 00000 7.48 GiB
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.815364] mmc0: new high speed SDHC card at address 59b4
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.812662] mmc0: host does not support reading read-only switch, assuming write-enable
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.807074] Waiting for root device /dev/mmcblk0p2...
Sep 18 16:15:24 LogicMachine kern.err kernel: [ 0.806907] Warning: unable to open an initial console.
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.805415] rtc-ds1307 0-006f: setting system clock to 2020-09-18 16:15:22 UTC (1600445722)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.798688] NET: Registered protocol family 17
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.774891] mxs-mmc 80010000.ssp: initialized
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.743550] 80010000.ssp supply vmmc not found, using dummy regulator
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.742421] usbcore: registered new interface driver btusb
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.737143] lirc_dev: IR Remote Control driver registered, major 248
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.735726] i2c /dev entries driver
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.734176] rtc-ds1307 0-006f: 64 bytes nvram
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.734058] rtc-ds1307 0-006f: rtc core: registered mcp7941x as rtc0
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.730119] g_ether gadget: g_ether ready
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.730064] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.729533] using random host ethernet address
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.729456] using random self ethernet address
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.729289] usb0: MAC 0a:5a:7c:dd:7e:87
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.728966] usb0: HOST MAC d6:62:69:c8:fc:b1
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.726378] using random host ethernet address
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.726290] using random self ethernet address
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.723518] hub 2-0:1.0: 1 port detectedI have also enclosed some images with what I see after trying to upgrade the firmware on my LM4. Basically, the FW version has remained the same as before doing the upgrade.
