Threads: 31
As always it all depend of all the other factors. You should be safe with 2k objects. Bacnet has two ways of syncing objects. COV subscription and pooling. Most of the time BMS support COV otherwise pooling is used. You can change the limit for COV subscriptions in settings.
Threads: 10
04.04.2024, 12:28
(This post was last modified: 04.04.2024, 12:42 by joaodaniel.pereira.)
What is the best solution for BACnet client at this momment ?
My bacnet devices are in other VLAN, it's possible to read ?
Threads: 48
You need routing between VLANs. Network device discovery (broadcast) might not work over VLAN, but using scripts in direct connection mode should work.
Threads: 2
Hello, can you send me the bacnet client app. LM lite version 20251214
Threads: 31
