motion_cm-19 connet RS485 to LM5-RIO2
Dear all.
I have a motor and a curtain controller. Please give me a guide for using over this RS485 protocol. I am using LM5-RIO2
I attach my controller's data.[/font]
https://usermanual.wiki/Coulisse/CM19
Thanks you.
.pdf   Coulisse_CM 19.pdf (Size: 3.21 MB / Downloads: 14)
Create an event script attached to a 1-byte unsigned object (valid scene number is from 1 to 15), change CM-19 address (default is 1) and port (default is /dev/RS485-1) if needed.
addr = 1 -- CM-19 address (default 1) scene = event.getvalue() if scene > 0 and scene < 16 then   value = string.format('!BR%dg%X;', addr, scene)   port = require('serial').open('/dev/RS485-1', {     baudrate = 9600,     duplex = 'half'   })   port:write(value)   port:close() end
(12.03.2021, 09:01)admin Wrote: Create an event script attached to a 1-byte unsigned object (valid scene number is from 1 to 15), change CM-19 address (default is 1) and port (default is /dev/RS485-1) if needed.
Thanks admin support.
