23.04.2021, 11:53
Is it possible to use Mosaic to activate and deactivate a schedule in LM?
Mosaic and schedules
23.04.2021, 11:53
23.04.2021, 12:13
Each schedule has Scheduler on/off object: You can use it anywhere also in Mosaic.
23.04.2021, 16:42
23.04.2021, 16:44
It is up to you if it is virtual or normal.
23.04.2021, 17:03
26.04.2021, 08:41
mosaic frame
Hello, will it be possible to view the frames with access from the cloud? I have a framework created to see the programmers, it can be seen locally but not remotely.
26.04.2021, 08:44
Frame just point to a url. If url is not accessible from cloud then it will not be visible.
26.04.2021, 09:54
(This post was last modified: 26.04.2021, 09:54 by davidchispas.)
(26.04.2021, 08:44)Daniel. Wrote: Frame just point to a url. If url is not accessible from cloud then it will not be visible. In local and ddns connection with the address '' / scada-vis / schedulers? Id = 1 '' it is enough to display it. But remotely through the CLOUD, I have tried the ddns address type: '' http://example.ddns.net:80/scada-vis/schedulers?id=1 '' '' http://user:pass@example.ddns.net:80/scada-vis/schedulers?id=1 '' and I can't visualize it, the frame comes out completely blank. When it rejects the connection it always shows some kind of error. Am I doing something wrong or is this not going to be possible ...?
26.04.2021, 10:00
You would also need to add credential in your url. This what you do is not the best/secure solution. Why don't you use ZeroTier for remote access to do such modification and cloud mosaic just as remote control?
Ctrl+F5 |
