Store and modify a data table via script in Wiser for KNX
I'm trying to make in W4K a simple booking interface that saves name, code for room unlocking, date of code activation and date of code expiration, is it possible to manage a simple database?
I've even thought about JSON but I don't know if it can be safe enough.
Any ideas?
Thank you
You can create custom tables in LM SQLite database if needed. Docs on LM database commands: https://openrb.com/docs/db.htm
Thank you, I'll check it out!
is there a way to check database tables besides LUA scripts?
You can download the backup, extract it and view the database using SQLite DB browser or similar software.
