[OLD] LogicMachine firmware 2021.05
2021 RC3: https://forum.logicmachine.net/showthread.php?tid=3632
2021 RC 1 is ready for testing. This version fixes several bugs from 2021 Beta 1. Our main focus was fixing bugs and improving usability in Mosaic30.
Video tutorials: https://forum.logicmachine.net/showthrea...9#pid21069
All recent firmware versions display which hardware is used in "HW (CPU)" form:
[Image: attachment.php?aid=1740]
Changes from 2020 RC3
2020.07.27   scripting editor:   - add save action for CTRL+S   - clear undo history on load so CTRL+Z does not clear the whole script   - fix indentation error for "e", "n", "d" characters 2020.08.19   visualization: fix layout issue on certain configurations with slider in RGBW widget 2020.08.24   trends: add automatic trend log file creation if file is missing or corrupted   visualization: fix pin code for string types 2020.08.28   bacnet: add custom device name setting 2020.09.24   modbus: add status object for slave devices 2020.09.25   storage: add mosaic keys to ignore list   localbus: add "nobuswrite" field to event table for to grp.update   visualizaion: enable top bar work-around for iOS v11+ instead of only v11   visualizaion: fix positioning for nested widgets   visualizaion: small style fix for touch/mobile visualization 2020.09.30   visualization: add option to hide home button in touch mode 2020.10.12   modbus: add support for writing values with bitmask 2020.10.15   lm: add password support to knxproj import 2020.10.23   user access:   - add enable/disable option   - add per-app access control   - cache acl instead of using db queries for each request   - add optional object access list 2020.10.27   user access: add per-room user access to mosaic 2020.10.29   modbus: fix polling sequence for longer polling times   lm: add dali test result data type   trends: change heartbeat from 120 seconds to 1 week (604800 seconds)   trends: fix yearly display for min/max/last   schedulers: add missing doctype   vis: set fixed size for navbar buttons 2020.11.02   modbus: add TCP option to read test UI 2020.11.03   user access: show apps/mosaic/advanced access 2020.11.11   user access: add cloud login field 2020.11.12   visualization: fix control scaling for webkit browsers   vis.params: fix 4-bit params not saving due to duplicate window id 2020.11.26   knx filtering (IP/per-user): allow double asterisk (1/*/*)   bacnet client: move scandevice/scandevices functions to the bacnet library   modbus: allow read_count/read_offset usage for coils as well as registers   scripting editor: show current value when running an event script   visualization: use correct decimal settings for graph element 2020.11.30   bacnet: show correct device name in object list   http: add "x-frame-options: sameorigin" header with an option to disable it   trends: fix labels not showing in certain cases   user access: add cloud user list to cached acl 2020.12.02   knxproj import: use datatype from group connection if possible   trends: show error message when trend load fails due to a missing trend file 2020.12.11   trends: do not hide export button when a single trend is displayed   modbus: cache and reuse persistent TCP connections based on IP:PORT pair 2020.12.18   user access: log/block access attempts with unknown username   objects: fix pagination display after reload when filtering is active   apps: hide core apps from the list when user has no access to this module 2021.01.05   scenes: fix scene.tagset() function 2021.01.06   security: add "X-Content-Type-Option: nosniff" header to user uploads 2021.01.18   knx/ip: fix secure mode timer and duplicate message tag after outdated frame has been received 2021.01.19   modbus: ignore devices with polling time less than zero, try writing once in 60 seconds for devices marked as offline 2021.01.21   security: disallow KNX/IP Tunneling connections from external IPs 2021.01.22   system config: fix ntp client disable not being allowed with empty peer list   modbus: fix writing address when read_offset is used   modbus: fix write_address field missing in the database   modbus: try reading only once for devices that are marked offline 2021.02.03   modbus: fix mapping sorting by type/address 2021.02.04   modbus: add NaN check for floating point values after conversion when value_nan is not set   modbus: add missing value_default field 2021.02.22   system config: add user accounts and passwords to backup/restore 2021.03.22   schedulers: fix minor layout issues, fix race condition when one scheduler sets status for another 2021.03.23   user access: allow "+" in local/cloud login 2021.03.25   flashsys: do a full backup (not partial which can skip trends) before doing the fw upgrade   visualization editor: show icon when the object value is empty, otherwise it's not possible to select/move this object 2021.03.29   user access: hide removed apps from the access list 2021.04.08   storage: memory usage optimizations for large requests 2021.04.12   trends: allow NaN value for float32 2021.04.13   security: disable remote services if default password is used 2021.04.22   apps: fix accidental web server stop after app installation 2021.04.26   modbus: fix slave ID reset to 247 when editing a TCP device with id > 247 2021.04.29   modbus: fix order for multiple mapping option
Hello
Great features in this release and keep going
I found that the Configure Apps page didn't open.
I log in as admin and I clear the cash but I still can't open the Configure Apps page
regards,
Best Regards,
Which browser, OS?
BTW, now you can do the same in user settings and allow apps per user.
(17.05.2021, 09:57)Daniel. Wrote: Which browser, OS?
Google Chrome used
I log in as Admin
Best Regards,
Anything in the browser error log (F12)?
(17.05.2021, 10:50)admin Wrote: Anything in the browser error log (F12)?
(index):1 Uncaught (in promise) {}message: (...)get message: ƒ ()arguments: (...)caller: (...)length: 0name: ""__proto__: ƒ ()[[Scopes]]: Scopes[0]__proto__: constructor: ƒ ()__proto__: Object
index.js:1 Uncaught (in promise) {}
(anonymous) @ index.js:1
apps.js.gz?v=20210413:1 Uncaught TypeError: Cannot read property 'toLowerCase' of undefined
    at sortByKey (apps.js.gz?v=20210413:1)
    at sortByTitle (apps.js.gz?v=20210413:1)
    at Array.sort (<anonymous>)
    at ne (apps.js.gz?v=20210413:1)
    at oe (apps.js.gz?v=20210413:1)
    at Object.success (apps.js.gz?v=20210413:1)
    at i (jquery.js.gz?v=20210413:2)
    at Object.fireWith [as resolveWith] (jquery.js.gz?v=20210413:2)
    at z (jquery.js.gz?v=20210413:4)
    at XMLHttpRequest.<anonymous> (jquery.js.gz?v=20210413:4)
sortByKey @ apps.js.gz?v=20210413:1
sortByTitle @ apps.js.gz?v=20210413:1
ne @ apps.js.gz?v=20210413:1
oe @ apps.js.gz?v=20210413:1
success @ apps.js.gz?v=20210413:1
i @ jquery.js.gz?v=20210413:2
fireWith @ jquery.js.gz?v=20210413:2
z @ jquery.js.gz?v=20210413:4
(anonymous) @ jquery.js.gz?v=20210413:4
load (async)
send @ jquery.js.gz?v=20210413:4
ajax @ jquery.js.gz?v=20210413:4
ie @ apps.js.gz?v=20210413:1
Config.show @ apps.js.gz?v=20210413:1
(anonymous) @ apps.js.gz?v=20210413:1
dispatch @ jquery.js.gz?v=20210413:3
r.handle @ jquery.js.gz?v=20210413:3
Best Regards,
after updating my LM Ambient, my Pm25 is empty. Is that correct?
type: LMWECO2-ZR - LogicMachine Ambient with Air Quality sensor and Enocean (Zebrano)
I have noticed that in all the machines where I have installed the latest updates (LM and Schneider wiser and Spacelynk), the remote connection ets via natted port 3671 no longer works. if i connect from lan obviously it works, but on previous port natted it doesn't work anymore.
is it a bug on the new firmware? What I have to do?
Peppe
This is blocked on purposes. Use zerotier for secure remote commissioning.
(18.05.2021, 14:48)Daniel. Wrote: This is blocked on purposes. Use zerotier for secure remote commissioning.
Sorry, I don't understand. What I have to do to keep using natted 3671 port?
https://openrb.com/zerotier-remote-maintenance-of-lm5/
ok, but how I can do with schneider spacelynk / wiser?
https://forum.logicmachine.net/showthread.php?tid=3364
ok, so, if I understood, there is no solution right now. Can I almost downgrade the firmware?
what is correct firmware for LM5Cp2-RIO2??
When you open the firmware upgrade window it will tell you which hardware model you have (as mentioned in the first post). RIO2 is LM5 Reactor IO V2.
admin,
thank you. Now all is clear Smile
Hi! Update my reactor v3, but now i cannot start the Z-wave daemon. Have tried restarting several times, tried unplugging the usb and plug it back (coming blue light) but cant start daemon.
Have you updated the app to the latest version?
#20
(23.06.2021, 08:26)admin Wrote: Have you updated the app to the latest version?
Checked now, here is the message..... Sad
