10.05.2021, 11:54
2021 RC3: https://forum.logicmachine.net/showthread.php?tid=3632
2021 RC 1 is ready for testing. This version fixes several bugs from 2021 Beta 1. Our main focus was fixing bugs and improving usability in Mosaic30.
Video tutorials: https://forum.logicmachine.net/showthrea...9#pid21069
All recent firmware versions display which hardware is used in "HW (CPU)" form:
![[Image: attachment.php?aid=1740]](https://forum.logicmachine.net/attachment.php?aid=1740)
Changes from 2020 RC3
scripting editor:
- add save action for CTRL+S
- clear undo history on load so CTRL+Z does not clear the whole script
- fix indentation error for "e", "n", "d" characters
2020.08.19
visualization: fix layout issue on certain configurations with slider in RGBW widget
2020.08.24
trends: add automatic trend log file creation if file is missing or corrupted
visualization: fix pin code for string types
2020.08.28
bacnet: add custom device name setting
2020.09.24
modbus: add status object for slave devices
2020.09.25
storage: add mosaic keys to ignore list
localbus: add "nobuswrite" field to event table for to grp.update
visualizaion: enable top bar work-around for iOS v11+ instead of only v11
visualizaion: fix positioning for nested widgets
visualizaion: small style fix for touch/mobile visualization
2020.09.30
visualization: add option to hide home button in touch mode
2020.10.12
modbus: add support for writing values with bitmask
2020.10.15
lm: add password support to knxproj import
2020.10.23
user access:
- add enable/disable option
- add per-app access control
- cache acl instead of using db queries for each request
- add optional object access list
2020.10.27
user access: add per-room user access to mosaic
2020.10.29
modbus: fix polling sequence for longer polling times
lm: add dali test result data type
trends: change heartbeat from 120 seconds to 1 week (604800 seconds)
trends: fix yearly display for min/max/last
schedulers: add missing doctype
vis: set fixed size for navbar buttons
2020.11.02
modbus: add TCP option to read test UI
2020.11.03
user access: show apps/mosaic/advanced access
2020.11.11
user access: add cloud login field
2020.11.12
visualization: fix control scaling for webkit browsers
vis.params: fix 4-bit params not saving due to duplicate window id
2020.11.26
knx filtering (IP/per-user): allow double asterisk (1/*/*)
bacnet client: move scandevice/scandevices functions to the bacnet library
modbus: allow read_count/read_offset usage for coils as well as registers
scripting editor: show current value when running an event script
visualization: use correct decimal settings for graph element
2020.11.30
bacnet: show correct device name in object list
http: add "x-frame-options: sameorigin" header with an option to disable it
trends: fix labels not showing in certain cases
user access: add cloud user list to cached acl
2020.12.02
knxproj import: use datatype from group connection if possible
trends: show error message when trend load fails due to a missing trend file
2020.12.11
trends: do not hide export button when a single trend is displayed
modbus: cache and reuse persistent TCP connections based on IP:PORT pair
2020.12.18
user access: log/block access attempts with unknown username
objects: fix pagination display after reload when filtering is active
apps: hide core apps from the list when user has no access to this module
2021.01.05
scenes: fix scene.tagset() function
2021.01.06
security: add "X-Content-Type-Option: nosniff" header to user uploads
2021.01.18
knx/ip: fix secure mode timer and duplicate message tag after outdated frame has been received
2021.01.19
modbus: ignore devices with polling time less than zero, try writing once in 60 seconds for devices marked as offline
2021.01.21
security: disallow KNX/IP Tunneling connections from external IPs
2021.01.22
system config: fix ntp client disable not being allowed with empty peer list
modbus: fix writing address when read_offset is used
modbus: fix write_address field missing in the database
modbus: try reading only once for devices that are marked offline
2021.02.03
modbus: fix mapping sorting by type/address
2021.02.04
modbus: add NaN check for floating point values after conversion when value_nan is not set
modbus: add missing value_default field
2021.02.22
system config: add user accounts and passwords to backup/restore
2021.03.22
schedulers: fix minor layout issues, fix race condition when one scheduler sets status for another
2021.03.23
user access: allow "+" in local/cloud login
2021.03.25
flashsys: do a full backup (not partial which can skip trends) before doing the fw upgrade
visualization editor: show icon when the object value is empty, otherwise it's not possible to select/move this object
2021.03.29
user access: hide removed apps from the access list
2021.04.08
storage: memory usage optimizations for large requests
2021.04.12
trends: allow NaN value for float32
2021.04.13
security: disable remote services if default password is used
2021.04.22
apps: fix accidental web server stop after app installation
2021.04.26
modbus: fix slave ID reset to 247 when editing a TCP device with id > 247
2021.04.29
modbus: fix order for multiple mapping option
