equivalent to "window.onload"
Hi all,
I'm looking for this method :
how to detect that a page (whatever this page, not a particular page) has just been loaded, with an equivalent of "window.onload" in javascript?
Someone knows the solution (Erwin for example ;-))?
Have a good day !
Can you explain what are you trying to achieve?
Hi ,
here is my need:
with custom JS, change the value of a group [JS grp.write()] each time a page of the visualization is accessed by a user.
Note: that's why I was referring to the JS instruction "window.onload".
It is necessary for this:
1. I detect the Id of the activated page
2. I write in a value in a group
Hoping you have been more accurate ...
You can do that like this:
$(function(){   $('body').on('showplan', function(e, id) {      grp.write('1/1/1', id);   }); });
I want to write an object before I close visualization window.
I think the function is "window.onbeforeunload" but witch is the equivalent?
Is there any page to see all javascript function in Logic Machine?
Thanks!!
The visualization runs in a browser not in LM. The supported functions is what the browser supports.
This can be used to switch an object off when the visualization page is exited:
window.onbeforeunload = function() {   if ($('body').hasClass('usermode')) {     grp.write('32/2/21', false);   } };
(25.06.2021, 11:48)admin Wrote: The visualization runs in a browser not in LM. The supported functions is what the browser supports.
Thanks!! It worsk perfectly.
I have another question, I want to know when a visualization is opened and I put this code:
  grp.write('32/1/152', true);     window.onbeforeunload = function() {     if ($('body').hasClass('usermode')) {       grp.write('32/1/152', false);     }   };
But doesn´t work.
What is wrong?
Thanks!
You have to wait for the WebSocket connection to be established. Use this:
if (typeof localbus === 'object') {   $(localbus).on('connect', function() {     grp.write('32/1/152', true);   }); }
