03.10.2020, 14:57
Hi everybody,
is it possible using my LM know my actual public IP and show it?
Best regards Cristian
Dinamic IP
03.10.2020, 14:57
Hi everybody,
is it possible using my LM know my actual public IP and show it? Best regards Cristian
05.10.2020, 06:23
Create a scheduled script that runs every 5 minutes:
Code: ip = require('ssl.https').request('https://openrb.com/ip/')Change 0/0/1 as needed, make sure that data type is set to "250 byte string".
05.10.2020, 06:52
23.09.2021, 09:55
(This post was last modified: 23.09.2021, 09:55 by d.r soutras.)
Hello guys!
A little bit of a help on how to set schedule. The help of w4k and the manual doesn't seems to be helpful for me. The goal was to run every 5 minutes but it doesn't work.
23.09.2021, 09:56
Does the script work when run manually? Check that you have valid gateway and DNS settings in System Config > Network > Interfaces > eth0.
23.09.2021, 10:03
grp.checkupdate will send anything only when the value changes. You can add log(ip) at the end of the script to check if it works as it should.
23.09.2021, 10:07
(This post was last modified: 23.09.2021, 10:19 by d.r soutras.)
Yes manually works fine.
I assume that it doesn't work because it doesn't update the value in the objects sector at the "Updated at" tab. (23.09.2021, 10:03)admin Wrote: grp.checkupdate will send anything only when the value changes. You can add log(ip) at the end of the script to check if it works as it should. Thank you! |
