25.11.2017, 18:06
I needed to send an email when an event with a group address occurs. Does anyone have an example?
					Send e-mail
		25.11.2017, 18:06
		26.11.2017, 00:45
Just use the build in mail function and trigger it as event based script: Code: -- make sure mail settings are set in common functions library before using this functionErwin
		27.11.2017, 10:15
		27.11.2017, 10:29
I need to send a value from storage by email, someone has an example?
		27.11.2017, 10:35
		For event value you can use an event script:
Code: value = event.getvalue()For storage value you need a scheduled script. But, if you want to send a value on each storage value change you should use a virtual object instead because you cannot attach an event script to storage changes. Code: value = storage.get('myvalue')
		27.11.2017, 10:42
		Thank you very much
		10.10.2021, 18:26
(This post was last modified: 10.10.2021, 20:02 by d.r soutras.)
		Hello guys!
A little bit of help here.. I have cycling send from a GA that comes from a generator. Can we adjust the code to send the email only if the GA changes it’s state. So an email with subject ‘Generator On’ will be sent when the GA is 1 and an email with subject ‘Generator Off’ will be sent when the GA is 0. Thank you in advance!!
		11.10.2021, 09:37
		Something like that would do, event script
		11.10.2021, 15:52
		As always… your script works like a charm!!!!
Thank you very much!!  |
