openweather ONE call API
Hi @all,
I looking around to get a weather service including for free forecasts and found out that there is a new option using openweather ONE call API:
https://openweathermap.org/api/one-call-api
Is somebody having experience with it and can help me with a working script to start with?
Many thanks for your help!
Best Regards
Steffen
See this: https://forum.logicmachine.net/showthread.php?tid=3491
Hello there
you can also look here
https://forum.logicmachine.net/showthrea...0#pid21340
Greetings
Many thanks for your help. I will try this the next days and give you a feedback if it works.
Hi @all,
due to the great hints of you guys I got the first script running for the current temperature and humidity value.
Now I want to get also the current weather description and the daily forecast for temperature min and max.
Unfortunately this values are not working. In the script log I see the following message:
User script:39: attempt to index field 'temp' (a nil value)
stack traceback:
Here is my actual script:
require('json')
http = require('socket.http')
appid = 'XXX'
lat = 'XXX'
lon ='XXX'
lang = 'en'
units = 'metric'
url = 'http://api.openweathermap.org/data/2.5/onecall?lat=%s&lon=%s&units=%s&lang=%s&appid=%s'
url = string.format(url, lat, lon, units, lang, appid)
res, code, headers, status = http.request(url)
log (code, status, headers)
data = json.pdecode(res)
--Fault messages:
if not data then
  alert('Error converting data')
  return
if not res then
  alert('Error collecting data')
  return
current = data.current
daily = data.daily
-- current temperature
grp.write('41/1/1', current.temp)
-- current Weather condition
grp.write('41/1/2', current.weather.description)
--current Humidity
grp.write('41/1/3', current.humidity)
--daily forecast Temperature min
grp.write('41/1/4', daily.temp.min)
--daily forecast Temperature max
grp.write('41/1/5', daily.temp.max)
Do you have an idea what might be wrong?
Best Regards
Steffen
Try replacing line 29 with this:
daily = data.daily[1]
Many thanks for the help!
Now the daily temperature predictions are working! Unfortunately the daily.weather group e.g. daily.weather.description is not getting a result. I played around with the datatypes (250 byte string, 14 byte string) with no effect.
Any idea what I can do?
Use daily.weather[1].description
Many thanks for the help, it works fine now!
Here is the finished script for other users to continue with it:
require('json')
appid = 'XXX'
lat = 'XXX'
lon ='XXX'
lang = 'de'
units = 'metric'
--Fault messages:
if not data then
  return
if not res then
  return
--current Humidity
--current wind speed
grp.write('41/1/6', current.wind_speed)
-- daily Weather condition
grp.write('41/1/2', daily.weather[1].description)
One last rookie question. I want to combine current.temp + current.humidity + current.wind_speed to one string and send this via a 14 byte ASCII group adress.
How would this look like?
Found the solution on my own, here is a line to combine the values:
wetterprognose = daily.temp.min.."/"..daily.temp.max
I trying to integrate the alerts as well. Unfortuantely I getting the following error:
Openweathermap 22.10.2021 19:39:38
User script:52: attempt to index global 'alerts' (a nil value)
stack traceback:
User script:52: in main chunk
Here is the complete code:
require('json')
appid = 'xxx'
lat = 'xxx'
lon ='xxx'
lang = 'de'
units = 'metric'
--Fault messages:
if not data then
  return
if not res then
  return
alerts = data.alerts
--current Humidity
--daily forecast wind gust
grp.write('41/1/7', daily.wind_gust)
--daily forecast max UV Index
grp.write('41/1/8', daily.uvi)
grp.write('41/1/9', daily.rain)
--alerts
grp.write('41/1/10', alerts.event)
wetterprognose = math.ceil(daily.temp.min).."/"..math.ceil(daily.temp.max).."/"..daily.rain.."/"..math.ceil(daily.wind_gust).."/"..math.ceil(daily.uvi)
--sending daily weather forecast to MDT Taster
grp.write('41/2/1', wetterprognose)
Best Regards
Steffen
Additional to post #10 I got a the same problem with the "rain" value today. Yesterday it worked fine due to rain = 4.31. Today there is no rain predicted. The failure is calling:
User script:54: attempt to concatenate field 'rain' (a nil value)
stack traceback:
User script:54: in main chunk
Can you help me with an idea for a solution please?
Many thanks!
Replace daily.rain with (daily.rain or 0)
Alerts might not be available so an extra check is needed:
if type(alerts) == 'table' and type(alerts[1]) == 'table' then
  alert_event = alerts[1].event
grp.write('41/1/10', alert_event or '')
Many thanks for the help! It is working now.
Here my complete script for all other users to continue with it:
require('json')
appid = 'xxxx'
lat = 'xxx'
lon ='xxx'
lang = 'de'
units = 'metric'
--Fault messages:
if not data then
  return
if not res then
  return
--current Humidity
grp.write('41/1/9', (daily.rain or 0))
--alerts
wetterprognose = math.ceil(daily.temp.min).."-"..math.ceil(daily.temp.max).."/"..(daily.rain or 0).."/"..math.ceil(daily.wind_gust).."/"..math.ceil(daily.uvi)
grp.write('7/2/3', wetterprognose)
I would change all grp.write into grp.checkupdate, this avoids all objects being updated each run when values are not changed and you have a lot of unneeded KNX telegrams on your TP bus (i assume most are for visu only), for the values you realy need on the bus you should use grp.checkwrite
Hi Erwin,
Sorry, not directly to this topic, but linked with weather data.
how better organize checking that weather data are updating (correctly)? I will install weather station first time, before I usually used different weather services. Of course I saw simply way once per hour check as example wind speed, and if data not changing - than do alert. But weather station sends data constantly and 1 hour checking period will be long? I just thing how correctly configure weather station to send data and not to overload KNX line.. Send data only if changed or cyclically every 10 minutes send them again? Script I found for data check:
I would add a check to be sure that the values from the online service are received as expected, we do the same with a signal from a local weather station (alive signal).
Make a resident / scheduled script at like this:
lastupdate = grp.find('1/1/1').updatetime
difference = os.time() - lastupdate
if difference > then 3600 then -- 1 hour not changed
alert('No new value received from online weather service')
-- or mail / push / sms etcetera
What is recommendation for local weather station?
BR, Alexander
Not sure what KNX weather station you have, but our KNX weather station has this alarming in the application and there is no scripting required.. have you checked the ETS application already for possible settings? From this alarm object you can simply trigger your email script or trigger the alert manager.
Thank you Erwin, will check again possibility of my weather station.
Alexander
Hi @all,
I want to get the snow fall forecast for the next 24h unfortunately I struggling to address the table position right.
What would be the right address for the snow value?
table:
[1]
  * table:
   ["feels_like"]
    * number: -4.82
   ["dew_point"]
    * number: 0.53
   ["snow"]
    * table:
     ["1h"]
      * number: 0.1
   ["pop"]
    * number: 0.34
   ["humidity"]
    * number: 95
   ["weather"]
    * table:
     [1]
      * table:
       ["main"]
        * string: Snow
       ["description"]
        * string: Mäßiger Schnee
       ["icon"]
        * string: 13d
       ["id"]
        * number: 600
   ["uvi"]
    * number: 0
   ["wind_gust"]
    * number: 13.94
   ["wind_deg"]
    * number: 266
   ["pressure"]
    * number: 993
   ["wind_speed"]
    * number: 8.29
   ["temp"]
    * number: 1.24
   ["visibility"]
    * number: 10000
   ["clouds"]
    * number: 98
   ["dt"]
    * number: 1705305600
[2]
  * table:
   ["feels_like"]
    * number: -4.51
   ["dew_point"]
    * number: 0.5
   ["snow"]
    * table:
     ["1h"]
      * number: 0.13
   ["pop"]
    * number: 0.49
   ["humidity"]
    * number: 94
   ["weather"]
    * table:
     [1]
      * table:
       ["main"]
        * string: Snow
       ["description"]
       ["icon"]
        * string: 13d
       ["id"]
        * number: 600
   ["uvi"]
    * number: 0.2
   ["wind_gust"]
    * number: 13.92
   ["wind_deg"]
    * number: 264
   ["pressure"]
    * number: 992
   ["wind_speed"]
    * number: 7.88
   ["temp"]
    * number: 1.36
   ["visibility"]
    * number: 277
   ["clouds"]
    * number: 100
   ["dt"]
    * number: 1705309200
I‘ve tried the following:
data.hourly[i].snow.1h
But getting the failure:
Lua syntax error at line 79: malformed number near '.1h'
Best Regards
Steffen
Use this:
data.hourly[i].snow['1h']
(15.01.2024, 09:14)admin Wrote: Use this:
Many thanks! This idea work, but I have a problem in the case of The value doesn’t exist because there is no snow forecasted = nil.
I tried this one:
repeat
    i=i+1
        if data.hourly[i].snow['1h'] == nil
        then
        data.hourly[i].snow['1h'] = 0
    log(data.hourly[i].snow['1h'])
    snowsum = data.hourly[i].snow['1h'] + snowsum
until
    i>24
but it doesn’t work.
User script:83: attempt to index field 'snow' (a nil value)
stack traceback:
Do you have an idea please?
Many thanks!
