Threads: 80
16.01.2019, 18:05
(This post was last modified: 16.01.2019, 18:09 by gdimaria .)
Hi, I would like to put a button on plan to let the user to shift between fullscreen to windowed vision of his browser.
Usually you can do it with F11 on your keyboard, but on a tablet would be better with a button.
How can I do? Can you provide me the correct javascript code?
Thanks in advance
Peppe
Threads: 7
17.01.2019, 11:22
(This post was last modified: 17.01.2019, 11:23 by Erwin van der Zwart .)
I use this custom JS to set the visu to fullscreen on first user input (if it is not already full screen mode):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
function (){
Fullscreen function
function fullScreen () {
if (!
document.fullscreenElement &&
document.mozFullScreenElement && !
document.webkitFullscreenElement && !
document.msFullscreenElement ) {
if (
document.documentElement.requestFullscreen ) {
document.documentElement.requestFullscreen ();
else if (
document.documentElement.msRequestFullscreen ) {
document.documentElement.msRequestFullscreen ();
else if (
document.documentElement.mozRequestFullScreen ) {
document.documentElement.mozRequestFullScreen ();
else if (
document.documentElement.webkitRequestFullscreen ) {
document.documentElement.webkitRequestFullscreen (
Element.ALLOW_KEYBOARD_INPUT );
function () {
var StartUserInput =
function (
e ) {
fullScreen ();
Check if document is loaded in iframe
if (
window.frameElement ){
Remove event listeners from parent
var thisparent =
window.parent ;
thisparent.document.removeEventListener (
'touchstart' ,
StartUserInput );
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Remove events
'touchstart' ,
StartUserInput );
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
if (
Add event listeners to parent
var thisparent =
window.parent ;
Event listener for iOS 6 -
8 (
was previous touchstart event )
thisparent.document.addEventListener (
'touchstart' ,
StartUserInput );
Event listener for iOS 9 + (
is now touchend event )
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
8 (
'touchstart' ,
StartUserInput );
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Threads: 80
For some reason it works on PC, but not on tablet (android, same browser chrome)...
Threads: 7
Somehow Android is having issues with the touchstart parameter, removed it in the sample below:
function (){
Fullscreen function
if (!
if (
else if (
else if (
else if (
document.documentElement.webkitRequestFullscreen ();
function () {
function (
e ) {
fullScreen ();
if (
var thisparent =
window.parent ;
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Remove events
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
if (
var thisparent =
window.parent ;
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Threads: 80
Ok, now it's working, but sometimes (as before) when you get in fullscreen mode with the first user input, then you can't input nothing anymore. Same happens if you click on a link button. It's like the screen was frozen. Then you have to press esc or F11 to get back to normal mode to input something.
Threads: 12
(19.01.2019, 20:08) Erwin van der Zwart Wrote: Hi,
function (){
Fullscreen function
if (!
if (
else if (
else if (
else if (
function () {
function (
e ) {
fullScreen ();
if (
var thisparent =
window.parent ;
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Remove events
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
if (
var thisparent =
window.parent ;
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
'touchend' ,
StartUserInput );
'click' ,
StartUserInput );
Is there any way to use it on Mosaic visu? I'm testing it on a Hikvision Android intercom monitor (Logicmachine app doesn't work on it, I don't know why), so I'm using the web browser, but there is no option to keep the app totally fullscreen.
Threads: 28
It is probably old Android version. Do you know what it is?
Threads: 12
(26.11.2021, 15:03) Daniel Wrote: It is probably old Android version. Do you know what it is?
Android 5.1.1 customized.
Threads: 28
Go to mosaic Extensions and add new widget. Select this file.
Once you go to Mosaic and when you click on anything it will go full screen.
Threads: 12
(26.11.2021, 15:31) Daniel Wrote: Go to mosaic Extensions and add new widget. Select this file.
Great! It works flawlessly, but when I change to another app, it returns to normal mode again until I refresh the page.
Any idea of how to execute this script again without refreshing?
Thank you very much.
Threads: 43
See if this works. You will have to delete the current fullscreen custom widget before uploading script.js.
Threads: 12
(29.11.2021, 08:13) admin Wrote: See if this works. You will have to delete the current fullscreen custom widget before uploading script.js.
Simply perfect! Thank you very much!
