Threads: 28
Set it to send on change of value.
Value send delta: - change from 0 to a value
Threads: 8
Thank you Daniel!
I can not find this setting.
Can you help me?
Threads: 28
Threads: 28
Upload your profile here
Threads: 28
Change "bus_datatype": "temperature", to "bus_datatype": "float16",
This should work but seems there is little bug.
Threads: 8
Thank you Daniel!
What is value send Delta?
So it means that if i change it from 0 to 1, it will sends values only if it changes by one degree Celsius?
Threads: 28
yes
Threads: 20
can you tell me what exactly this mean?
it just update the value to the groepadres if there is a change of 1,0 or when there is a changing of 0,1 or less?
Threads: 28
If you put 1 then value will be sent if the change will be at last 1 or higher.
Threads: 20
Thanks for reply , Daniel
