Bacnet - Script error
I am getting an error when trying to run a script for changing the set. temp.
See uploaded image.
I want to change the set. temp. But this code doesn't work. Any suggestions?
Use the command like this:
bacnet.write(2, 'analog input', 126, value, 13)
(19.12.2021, 10:50)Erwin van der Zwart Wrote: Use the command like this:
Yes, that was the case.
Thank you Erwin.
