Pause an event script
Please tell me if there is a way to interrupt the execution of an event script if this script is already running but has not finished executing. The problem is that when you repeatedly press the light switch, the LM processor starts to load. Since the script execution has not yet completed, and the user presses the same switch several times
Below is an example of one of the scripts
12345678910111213141516171819202122232425262728293031
value = event.getvalue() local rgbw_color_zal = storage.get('active_rule_3', 3739391)                     obj_ligth = grp.tag('master_led') if (value==true) then     for id, obj in ipairs(obj_ligth) do     if (obj.datatype==1) then                 grp.write(obj.address, true)                                  elseif(obj.datatype==5001) then             grp.write(obj.address, 100)                                   elseif(obj.datatype==12600) then             grp.write(obj.address, rgbw_color_zal)                  elseif(obj.datatype==5) then       grp.write(obj.address, 0)                     end         os.sleep(0.3)     end else     for id, obj in ipairs(obj_ligth) do     if (obj.datatype==1) then                 grp.write(obj.address, false)                              elseif(obj.datatype==5001) then             grp.write(obj.address, 0)                                           elseif(obj.datatype==12600) then             grp.write(obj.address, 0)                                           elseif(obj.datatype==5) then             grp.write(obj.address, 0)                                             end         os.sleep(0.3)     end end
scripts are different depending on what, where and when should be included. This is one of those scripts.
https://forum.logicmachine.net/showthrea...1#pid19051
(23.02.2022, 11:55)Daniel Wrote: https://forum.logicmachine.net/showthrea...1#pid19051
Maybe I didn't explain the situation well. The script that is being executed does not need to be stopped, it must be completed to the end, I need that at this moment when this script is being executed, the second instance does not start for execution when a repeated event arrives at the group address
Then you talking about semaphore
https://openrb.com/docs/semaphore.htm
Consider also using this
https://forum.logicmachine.net/showthrea...4#pid11774
(23.02.2022, 12:08)Daniel Wrote: Then you talking about semaphore
