Threads: 21
21.09.2016, 16:47
(This post was last modified: 21.09.2016, 17:03 by JMM .)
HI,
Since the last update (20160714), which is the path of the file backup ?
With that :
[*]--Create attachment
[*]src = '/tmp/lm-backup.tar.gz'
Error log is:
* string: /tmp/lm-backup.tar.gz: No such file or directory
Thank you .
[*]Solved problem
[*]JMM.
Jean-Marc
Threads: 43
(21.09.2016, 16:47) HiI cant make this work. Will it work in latest firmware? Could somebody paste working code?Im using Reactor v2 Thanks in advanceJMM Wrote: HI,
With that :
Error log is:
Thank you .
[*]Solved problem
[*]JMM.
Threads: 7
19.10.2016, 09:39
(This post was last modified: 19.10.2016, 09:39 by Erwin van der Zwart .)
This should work on latest FW:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111
user =
'YOUR GMAIL ADDRESS'
password =
'YOURPASSWORD'
from =
'<me@whoismailingyou.com>'
alias_from =
'From me'
to =
'<someone@youwanttomail.com>'
alias_to =
'To you'
subjectpart1 =
'Back-up file'
subjectpart2 =
'automaticly send by homeLYnk'
epilogue =
'End of message'
local settings = {
from =
from ,
rcpt =
to ,
user =
user ,
password =
password ,
server =
'smtp.gmail.com' ,
port =
465 ,
secure =
'sslv23' ,
src =
'backup-' ..
os.date (
'%Y.%m.%d' ) ..
'.tar.gz'
dst =
'/home/ftp/' ..
src
os.execute (
'sh /lib/genohm-scada/web/general/backup.sh' )
os.execute (
'cd /lib/genohm-scada/storage && tar -c -z -f ' ..
dst ..
subject =
subjectpart1 ..
src ..
subjectpart2
local smtp =
require (
"socket.smtp" )
local mime =
require (
"mime" )
local ltn12 =
require (
"ltn12" )
settings.source =
smtp.message {
headers = {
from =
alias_from ..
from ..
to =
alias_to ..
to ..
subject =
subject
body = {
preamble =
1 ] = {
headers = {
"content-type" ] =
'application/x-7z-compressed' ,
"content-disposition" ] =
'attachment; filename="' ..
src.. '"' ,
"content-description" ] =
'.. src ..' ,
"content-transfer-encoding" ] =
"BASE64" ,
body =
ltn12.source.chain (
ltn12.source.file (
io.open (
dst ,
"rb" )),
ltn12.filter.chain (
mime.encode (
"base64" ),
mime.wrap ()
epilogue =
epilogue
r ,
e =
smtp.send (
settings )
if (
e )
then
log (
e )
log (
r )
alert (
"Could not send email: " ,
e ,
"\n" )
log (
"Send Mail" )
os.execute (
'cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*' )
script.disable (
_SCRIPTNAME )
Erwin van der Zwart
Threads: 43
I get the following log
*String send mail
*nil
*string revcd alert fatal error
Another way to run this script would be to upload to ftp server.
Threads: 7
Have you enabled less secure apps inside your gmail account?
https://www.google.com/settings/security/lesssecureapps
Threads: 43
I have done this and tested two different Gmail accounts. Ang oter idag?
Threads: 41
(19.10.2016, 17:58) PassivPluss Wrote: I get the following log
*String send mail
*nil
Hi PassivPluss,
This is an example (for LM4 firmware 20160714) of how to upload to a ftp server:
src =
'backup-' ..
os.date (
'%Y.%m.%d_%H-%M' ) ..
'.tar.gz'
dst =
'/home/ftp/' ..
src
target =
'<ftpdir>' ..
src
os.execute (
os.execute (
dst ..
local ftp =
require (
"socket.ftp" )
local ltn12 =
require (
"ltn12" )
f ,
e =
ftp.put {
host =
"<ip_address_of_ftp_server>" ,
user =
"<ftp_user>" ,
password =
"<ftp_user_pwd>" ,
type =
"i" ,
argument =
target ,
source =
ltn12.source.file (
io.open (
dst ,
"rb" ))
if (
e )
then
log (
e )
log (
f )
alert (
"Could not ftp: " ,
e ,
"\n" )
log (
"ftp_backup" )
os.execute (
'cd /home/ftp && rm -rf backup_*' )
os.execute (
Threads: 13
I still have the last stable firmware but after some tweaks I got it working.
I notice however that the backup does not make a backup of the scripts and mosaic configuration
How could I create a backup of these files that are easy to restore afterwards ?
Nicky
Threads: 43
Scripts are always included in the backup, Mosaic 1.0 configuration is stored separately. On the other hand, Mosaic 2.0 uses global storage for its configuration, so it's included in the backup automatically.
Threads: 41
(16.11.2016, 07:30) admin Wrote: Scripts are always included in the backup, Mosaic 1.0 configuration is stored separately. On the other hand, Mosaic 2.0 uses global storage for its configuration, so it's included in the backup automatically.
I also took a look in the .tar file and could not find the scripts either. I have also taken a manual backup and had the same result.
The only items in the backup are ./modbus, ./current.db, ./fonts, ./trends, ./icons, ./img, ./blocky.json, ./ekey.db, ./current.md5, ./blocky.luas, ./helper.js, ./backup.md5, ./filter.sh, ./id_rsa, ./user, ./initscript.lua, ./userlib.luas, ./custom.css, ./custom.js, ./backup.db, ./redis.rdb, ./genohm-scada.config
Threads: 43
Scripts and most other things are stored in the main database.
Threads: 13
(16.11.2016, 09:11) admin Wrote: Scripts and most other things are stored in the main database.
Thanks for clearing that up
I would still prefer to backup the scripts in readable format just in case new firmware versions do not support the old backups.
Maybe to include in a future release?
Threads: 43
You can always use Backup scripts in Scripting or Print script listing. We will always have compatibility for old backups. In worse case scenario we will provide a fixup patch for really old versions like we did in the past.
Threads: 21
27.07.2017, 15:40
(This post was last modified: 27.07.2017, 16:19 by JMM .)
For some time it is impossible to send the backup by Gmail .
Error message: ( * string: 552-5.7.0 This message was blocked because its content presents a potential
552-5.7.0 security issue. Please visit
552-5.7.0
https://support.google.com/mail/?p=BlockedMessage to review our
552 5.7.0 message content and attachment content guidelines. 9sm17387246wmo.35 - gsmtp).
Jean-Marc.
Having renamed .tar.gz in .bck the sending is possible
Jean-Marc.
Jean-Marc
Threads: 3
Yes google is not allowing archive files in attachment... you just need to either change the extention to another like .txt, .bck, ... or remove it.
Threads: 31
I´ve tried to send a backup file by email using this example "http://openrb.com/e-mail-backup-file-once-a-month-from-lm/" but i get this error: 555 5.5.2 Syntax error. x139-v6sm44009148wme.3 - gsmtp.
I,ve tried changing the extention to .bck but i get the same error.
Any idea?
Threads: 28
As mentioned above google is blocking any archives. Apparently deleting the extension or changing it seems to work. You can also try another email provider.
Threads: 31
16.10.2018, 07:37
(This post was last modified: 16.10.2018, 08:06 by DGrandes .)
I´ve tried changing the extension to bck and it doesn´t work, but with .pdf it work perfectly.
Thank you
I´ve a question.
The size of my logic machine backup take 22mb. And when i tried to send it by email, the logic machine restart and doesn´t send it.
With a smaller backup it work.
Why?
Threads: 43
You are probably hitting memory limits. What is your device memory usage during normal operation?
Threads: 31
