Problem with firmware update LM 2020.07 RC3
Good morning:
I just updated the firmware of my LM5p-DW1 and now the Dali ignitions do not work in the LM, I have several Scripts for the Dali configuration of the LM and none of the ignitions work, not even forcing them from Objects, can someone help me please ?
Thank you
In the forum I just read that:
- If using user.dali library you need to delete the current library and reboot your device. This way a new library version will be installed. Otherwise dalicmd function will not work.
How do I remove the current library so that a new version of the library is installed?
Thank you
When I scan, no Gatewey Dali appears and there should be two ...
Are you sure you selected correct firmware? You can install dali package manually https://dl.openrb.com/lm-20-imx6/pkg/gen...2_imx6.ipk and make sure to clear browser cache.
(07.11.2020, 10:11)Daniel. Wrote: Are you sure you selected correct firmware? You can install dali package manually https://dl.openrb.com/lm-20-imx6/pkg/gen...2_imx6.ipk and make sure to clear browser cache.
I think so, is what I read in the forum
Excuse the ignorance, how can I install dali package manually?
Is this that you send me a file or a link?
After looking in the manual, where are the packages, the Dali package existed, even so I have added it again, even so the two Dali gateways do not appear in my LM, I am very lost.
Thanks for everything
Run this once and post what you get in Logs tab. It will read the extension type that is connected to your LM.
m1, m2, m3 = require('i2c').read(0, 0x50, 0x70, 3) if m1 and m2 and m3 then   readid = string.char(m1, m2, m3)   log(readid) else   log('id read failed') end
(09.11.2020, 08:35)admin Wrote: Run this once and post what you get in Logs tab. It will read the extension type that is connected to your LM.
Good morning:
Thanks for the answer, this is the log that I get when executing the Script
Looks like the extension is missing ID.
Try writing it via a script once and then reboot your LM and see if Dali gateways appear.
id = 'dw2' -- dw2 is a newer version of dw1 b1, b2, b3 = id:byte(1, 3) res = require('i2c').write(0, 0x50, 0x70, b1, b2, b3)
I have an LM "LogicMachine5 Power DW1" with 2017 firmware and I'm trying to update last firmware but doesn´t update.
Is "LM5 Lite + Ext (4 or 6 DIN units)" right firmware?
Drop what you have in System logs.
(06.04.2022, 11:49)Daniel Wrote: Drop what you have in System logs.
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950
Apr 6 13:02:05 LogicMachine kern.info kernel: [ 8596.226870] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Apr 6 13:01:42 LogicMachine kern.info kernel: [ 8573.371484] fec 2188000.ethernet eth0: Link is Down Apr 6 10:39:14 LogicMachine kern.notice kernel: [ 25.536864] random: nonblocking pool is initialized Apr 6 10:30:59 LogicMachine kern.info kernel: [ 9.646049] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off Apr 6 10:30:53 LogicMachine user.info sysinit: /lib/genohm-scada/storage/current.db: OK Apr 6 10:30:53 LogicMachine authpriv.info dropbear[917]: Running in background Apr 6 10:30:52 LogicMachine kern.info kernel: [ 2.741289] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc Apr 6 10:30:52 LogicMachine user.info sysinit: /dev/mmcblk0p3: clean, 786/958464 files, 105851/3830528 blocks Apr 6 10:30:52 LogicMachine user.info sysinit: e2fsck 1.43.4 (31-Jan-2017) Apr 6 10:30:52 LogicMachine kern.info kernel: [ 2.568776] fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 1.492984] fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.900595] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.464603] Freeing unused kernel memory: 160K (c03ba000 - c03e2000) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.464036] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.463936] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.377818] mmcblk0: p1 p2 p3 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.376252] mmcblk0: mmc0:59b4 USDU1 14.9 GiB Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.375303] mmc0: new high speed SDHC card at address 59b4 Apr 6 10:30:51 LogicMachine kern.warn kernel: [ 0.369220] mmc0: host does not support reading read-only switch, assuming write-enable Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.352043] Waiting for root device /dev/mmcblk0p2... Apr 6 10:30:51 LogicMachine kern.err kernel: [ 0.351970] Warning: unable to open an initial console. Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.351556] vdd3p0: disabling Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.350813] rtc-pcf85263a 0-0051: setting system clock to 2022-04-06 10:30:50 UTC (1649241050) Apr 6 10:30:51 LogicMachine kern.err kernel: [ 0.347326] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.345958] can: raw protocol (rev 20120528) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.345906] NET: Registered protocol family 29 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.345555] can: controller area network core (rev 20120528 abi 9) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.345490] NET: Registered protocol family 17 Apr 6 10:30:51 LogicMachine kern.warn kernel: [ 0.329679] 2198000.adc supply vref not found, using dummy regulator Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.313668] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.277028] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.276997] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.276808] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.275040] sdhci-pltfm: SDHCI platform and OF driver helper Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.275023] sdhci: Copyright(c) Pierre Ossman Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.275002] sdhci: Secure Digital Host Controller Interface driver Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.274471] usbcore: registered new interface driver btusb Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.273721] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0) Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.272045] i2c /dev entries driver Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.271815] rtc-pcf85263a 0-0051: rtc core: registered rtc-pcf85263a as rtc0 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.267519] hub 2-0:1.0: 1 port detected Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.267413] hub 2-0:1.0: USB hub found Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.266106] usb usb2: SerialNumber: ci_hdrc.1 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.266084] usb usb2: Manufacturer: Linux 4.4.73 ehci_hcd Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.266059] usb usb2: Product: EHCI Host Controller Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.266034] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.265998] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.265638] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.256368] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2 Apr 6 10:30:51 LogicMachine kern.info kernel: [ 0.256248] ci_hdrc ci_hdrc.1: EHCI Host Controller
What is the CPU? System Status
(06.04.2022, 14:32)Daniel Wrote: What is the CPU? System Status
Ok then if you used fw for imx6 then I think the card is in read only mode. Try changing something like add object, sync project and reboot. If the object is missing then this is the card issue.
(07.04.2022, 07:31)Daniel Wrote: Ok then if you used fw for imx6 then I think the card is in read only mode. Try changing something like add object, sync project and reboot. If the object is missing then this is the card issue.
We have updated with "LM 4M" firmware but the two dali channels have disappeared.
You've probably installed LM5 M4. You need this firmware: https://dl.openrb.com/lm-21-imx6/lm5m3ex-20211215.img
