Scripting
Hello
I have used the scripts below and I have also turned off the 2 step verification in google account
function Email(to, subject, message)
  ---------------BEGINNING OF USER EDITABLE AREA-------------------
  local settings = {
        from = 'XXXXXX@gmail.com',
    -- smtp username
    user = 'XXXXXX@gmail.com',
    -- smtp password
    password = 'XXXXXXX',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    secure = 'tlsv1_2',
  -------------------END OF USER EDITABLE AREA---------------------
  local escape = function(v)
    return '<' .. tostring(v) .. '>'
  -- message headers and body
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
  settings.from = escape(settings.from)
  settings.rcpt = { escape(to) }
  return smtp.send(settings)
require('user.Email')
Email("XXXXXX@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
Email("DDDDDD@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
log(mail("XXXXXX@gmail.com") )
it can't send an email and I have the error below
User script 5: attempt to call global 'mail' (a nil value)
stack traceback
er
Log the results like this:
res1, err1 = Email("XXXXXX@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
res2, err2 = Email("DDDDDD@gmail.com", "Alarm", "Παραβίαση Σπιτιού")
log(res1, err1)
log(res2, err2)
Sorry can't understand.
Where should I add this code?
In send email script?
Yes, add it to the sending script. The original error is from calling function named mail instead of Email. It is also called without subject/message body.
log(res1, err1)
log(res2, err2)
I have added, but nothing.
I get not an error in the log screen of Wiser but also I don't receive any email.
What do you get in Logs tab (not Error logs)? There must be something otherwise the script didn't run at all.
Please see the picture
Due to recent security policy changes Gmail SMTP won't work from scripts. You need to use different email provider.
And which is the code for the different email provider?
Hello
can you tell me what should I change?
Script is the same only you must setup email function with details from other email provider.
Have a look here, gmail might actually work
https://forum.logicmachine.net/showthrea...1#pid26361
