Trends API
Is there an API for a new trends mechanism? e.g. for using some average values in scripts?
Hi buuuudzik,
I think it must be possible for own values made them via script to write them in new "virtual" GA's, which you can log for trends. So I made it with custom values.
Hi buuuudzik,
Try this:
require('trends')
name = 'my trend name'
dates = {}
dates['start'] = { year = 2016, month = 4, day = 12 }
dates['end'] = { year = 2016, month = 4, day = 13 }
-- resolution (in seconds) is optional
-- default trend resolution is used when not set
resolution = nil
res = trends.fetch(name, dates, resolution)
log(res)
Docs:
http://openrb.com/docs/trends-new.htm
(29.05.2016, 06:12)admin Wrote: Docs:
Thank you everyone, especially you admin, because this is exactly what I was looking forWink
Here is a script to create trends as batch from start address until end address for new (and relaese candidate) FW.
-- Batch adding trends - Created by Erwin van der Zwart - Schneider Electric Netherlands ----------- -- For spaceLYnk FW 1.2.1 or higher and homeLYnk FW 1.5.1 or higher -------------------------------- -- Refresh browser after creation to show the trends ----------------------------------------------- ----------------------------------------- Start Parameters ----------------------------------------- -- Start address of objects start_objectaddress = '1/1/1' -- Trends for all objects between these range are created -- End address of objects end_objectaddress = '1/1/3' -- Set username and password for access to HL username = 'admin' password = 'admin' -- Select trend type to create (or multiple types on same object) create_trendtype_counter = true create_trendtype_counter_with_negative_delta = true create_trendtype_absolute_value = true -- Set trend precicion (!Important! Can only be these values: 0 to 8) trendprecision = 2 -- Set trend resolution (!Important! Can only be these values: 5 / 10 / 15 / 20 / 30 / 60 minutes)) trendresolution = 5 -- Set trend count resolution (!Important! Can only be these values: '30' = 30 days, '180' = 180 days, '365' = 1 year, '730' = 2 years, '1825' = 5 years trendcountresolution = 365 -- Set trend count days (!Important! Can only be these values: '1' = 1 year / '2' = 2 years / '5' = 5 years / '10' = 10 years) trendcountdaily = 10 -- Set show always 0 base line trendshowzero = 0 -- 0 = disabled 1 = enabled ------------------------------------------ End Parameters ------------------------------------------ ------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE ------------------------------- -- Load modules require('json') require('socket.url') require('socket.http') -- Set HL ip address as localhost ip = '127.0.0.1' -- Calculate start address to DB format start_objectaddress = knxlib.encodega(start_objectaddress) -- Calculate end address to DB format end_objectaddress = knxlib.encodega(end_objectaddress) -- Create url for trend creation url = 'http://' .. username .. ':' .. password .. '@' .. ip .. '/scada-main/trends/save' -- Function to send request to create trend function url_send(trend_object, trend_name, trend_type, trend_resolution, trend_precision, trend_count_resolution, trend_count_daily, trend_show_zero, trend_id)  local trend = {      object = trend_object,      name = trend_name,      type = trend_type,      resolution = trend_resolution,      precision = trend_precision,    count_resolution = trend_count_resolution * 12 * 24, -- nr of days * nr of points in a hour at min resolution (60/5 = 12) * hours per day    count_daily = trend_count_daily * 365, -- nr of days * 365 days a year      show_zero = trend_show_zero,      id = trend_id,     }  data = json.encode(trend)     form_data = 'data=' .. socket.url.escape(data)     socket.http.TIMEOUT = 15       local res, code, response_header = socket.http.request(url, form_data)  return res, code, response_header end -- Set counters for creation log number_of_trends = 0 number_failed = 0 -- Loop from startadres to end address to create trends for i = start_objectaddress, end_objectaddress, 1 do    -- Get current group address from loop  current_GA = knxlib.decodega(i)    -- Get current object info  objectinfo = grp.find(current_GA)       -- Check if object excists  if objectinfo ~= nil then          -- Set parameters for request    trendobject = objectinfo.id    trendname = objectinfo.name    trendid = ''        -- Check if trend type 'Counter' should be created    if create_trendtype_counter == true then            -- Call function to send create request      result, code, response_header = url_send(trendobject, trendname, 'C', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)            -- Calculate results for creation results log        if result == '{"success":true}' then          number_of_trends = number_of_trends + 1        else          number_failed = number_failed + 1        end          end        -- Check if trend type 'Counter with negative delta' should be created    if create_trendtype_counter_with_negative_delta == true then                   -- Call function to send create request      result, code, response_header = url_send(trendobject, trendname, 'D', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                -- Calculate results for creation results log        if result == '{"success":true}' then          number_of_trends = number_of_trends + 1        else          number_failed = number_failed + 1        end          end        -- Check if trend type 'Absolute value' should be created    if create_trendtype_absolute_value == true then                   -- Call function to send create request      result, code, response_header = url_send(trendobject, trendname, 'G', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                -- Calculate results for creation results log        if result == '{"success":true}' then          number_of_trends = number_of_trends + 1        else          number_failed = number_failed + 1        end          end      end   end     if number_failed == 0 then     log ("Created " .. number_of_trends .. " trends succesfully") else     log ("Created " .. number_of_trends .. " trends succesfully and creation of " .. number_failed .. " trends failed") end -- Disable script when done automaticly script.disable(_SCRIPTNAME)
Here is a script to batch export last month trend data as csv and send by mail (with trend selection) for new (and relaese candidate) FW.
--**************************************************************************-- --** Email trendlog data as CSV attachment created by Erwin van der Zwart **-- --************ For HL from FW 1.5 and SL from FW 1.2 with NGINX ************-- --**************************************************************************-- --*************************** Start of parameters **************************-- -- Version 1.1 *************************************************************-- --Gmail (smtp) username !IMPORTANT! user = 'YOUR EMAIL ADRESS' --Gmail (smtp) password !IMPORTANT! password = 'YOUR PASSWORD' --Sender for e-mail from = '<' .. user .. '>' alias_from = 'YOUR ALIAS' --Recipient for e-mail to = '<receiver@domain.com>' alias_to = 'receiver' --Subject for e-mail subjectpart1 = 'Trend export file' subjectpart2 = 'automaticly send by homeLYnk' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' --Set export mode (selected trend(s) or all trends) export_all = true --Set trend names if not all trends need to be exported (only used when export_all = false) trendnames = {  "Total Electric Usage",  "Total Water Usage",  "Total Gas Usage", } --**************************************************************************-- --**************************** End of parameters ***************************-- --**************************************************************************-- --****************** DON'T CHANGE ANYTHING UNDER THIS LINE *****************-- --**************************************************************************-- require('trends') -- Get all trend names from DB trends_table = db:getall('SELECT name FROM trends ORDER BY name DESC') -- Check if all trends or selection neeed to be exported if export_all == false then  -- Loop through trends_table  i = 1 for _, trend_names in ipairs(trends_table) do    delete_from_table = true    -- Loop through trendnames    for _, trendname in ipairs(trendnames) do      if trendname == trend_names.name then    delete_from_table = false      end    end    if delete_from_table == true then      table.remove(trends_table, i)  end  i = i + 1  end end -- Check if the is at least 1 trend to be exported if #trends_table < 1 then  log("No trends available, Could not export trends")  return end -- csv buffer buffer = {} -- Add to buffer table.insert(buffer, '"This file contains the export data of ' .. #trends_table .. ' trend(s) and is automaticly created on ' .. os.date("%A",os.time()) .. ' ' .. os.date("%d-%m-%y at %H:%M") .. '"') -- Add empty line table.insert(buffer, '""') -- months local months = { "Januari", "Februari", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December" } -- Loop through trends_table for _, trend_names in ipairs(trends_table) do  -- Grab trend name from DB table  trend_name = trend_names.name    -- Add to buffer  table.insert(buffer, '"##### START OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')  -- Add empty line  table.insert(buffer, '""') -- Get current timestamp  timestamp = os.time() startpoint = os.date('*t', timestamp) endpoint = os.date('*t') -- Reset to first of month startpoint.sec = 0 startpoint.min = 0 startpoint.hour = 0 startpoint.yday = startpoint.yday - (startpoint.day -1) startpoint.day = 1 startpoint.wday = 1 endpoint.sec = 0 endpoint.min = 0 endpoint.hour = 0 endpoint.yday = endpoint.yday - (endpoint.day -1) endpoint.day = 1 endpoint.wday = 1 -- Get data for the past month dates = {}  dates['start'] = startpoint    if dates['start'].month == 1 then  dates['start'].month = 12    dates['start'].year = dates['start'].year - 1  else    dates['start'].month = dates['start'].month - 1  end    dates['end'] = endpoint  dates['end'].month = dates['start'].month + 1    -- Set resolution to dayly data  resolution = 86400    -- Get last month for data by each days in this month  trenddatamonth = trends.fetch(trend_name, dates, resolution)    -- Get last month total avarage data  trenddatamonthavg = trends.fetchone(trend_name, dates, resolution)    -- Add to buffer  table.insert(buffer, '"Export of the average usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')  -- Add empty line  table.insert(buffer, '""')  -- Add header  table.insert(buffer, '"Start date","End Date","Average month value"')  -- Add to buffer  table.insert(buffer, '"01-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. #trenddatamonth .. '-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. trenddatamonthavg .. '"')  -- Add empty line  table.insert(buffer, '""')  -- Add to buffer  table.insert(buffer, '"Detailed export of the daily usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')  -- Add empty line  table.insert(buffer, '""')  -- Add header  table.insert(buffer, '"Weekday","Date","Average day value"')  for _, row in ipairs(trenddatamonth) do    stamp = dates['start'].year .. '-' .. dates['start'].month .. '-' .. string.format("%02d", _) local y, m, d = stamp:match("(%d+)%-(%d+)%-(%d+)") local t = { year = y, month = m, day = d}      -- format csv row    csv = string.format('%q,%q,%q', os.date("%A",os.time(t)), "" .. string.format("%02d", _) .. "-" .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year, row)    -- add to buffer    table.insert(buffer, csv)  end  -- Add empty line  table.insert(buffer, '""')  -- Add header  table.insert(buffer, '"##### END OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')  -- Add empty line  table.insert(buffer, '""') end --Create table to include mail settings local settings = {    from = from,    rcpt = to,    user = user,    password = password,    server = 'smtp.gmail.com',    port = 465,    secure = 'sslv23', } --Create attachment inside FTP server src = 'Trend Export '.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer) --Create subject subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2 --Load required modules to send email with attachment local smtp = require("socket.smtp") local mime = require("mime") local ltn12 = require("ltn12") --Create e-mail header settings.source = smtp.message{ headers = {          from = '' .. alias_from .. ' ' .. from .. '',          to = '' .. alias_to .. ' ' .. to .. '',          subject = subject }, --Load attachment inside body     body = { preamble = "", [1] = {          headers = {           ["content-type"] = 'text/plain',           ["content-disposition"] = 'attachment; filename="'..src..'"',           ["content-description"] = '.. src ..',           ["content-transfer-encoding"] = "BASE64",        },        body = ltn12.source.chain(          ltn12.source.file(io.open(dst, "rb")),          ltn12.filter.chain(          mime.encode("base64"),          mime.wrap()        )      )    },      epilogue = epilogue  } } --Send the email r, e = smtp.send(settings) --Create alert when sending gives an error with error message if (e) then  log (e)  log (r)  alert("Could not send email: ", e, "\n") end --Delete created temp csv file from ftp folder inside HL os.remove(dst)
Erwin van der Zwart
Nice work Erwin, in your first script you can replace IP with 127.0.0.1 and remove "if-json" call.
(05.09.2016, 06:01)admin Wrote: Nice work Erwin, in your first script you can replace IP with 127.0.0.1 and remove "if-json" call.
Thanks for the tip, i changed it in the sample script (;
Thanks Erwin, those scripts save me a lot of time. I made a small change and all objects with specific tag will have own trend:
-- Batch adding trends - Created by Erwin van der Zwart - Schneider Electric Netherlands ----------- -- For spaceLYnk FW 1.2.1 or higher and homeLYnk FW 1.5.1 or higher -------------------------------- -- Refresh browser after creation to show the trends ----------------------------------------------- ----------------------------------------- Start Parameters ----------------------------------------- -- Create trend to object with this tag  tag_name = "make_trend" -- Set username and password for access to HL username = 'admin' password = 'admin' -- Select trend type to create (or multiple types on same object) create_trendtype_counter = true create_trendtype_counter_with_negative_delta = true create_trendtype_absolute_value = true -- Set trend precicion (!Important! Can only be these values: 0 to 8) trendprecision = 0 -- Set trend resolution (!Important! Can only be these values: 5 / 10 / 15 / 20 / 30 / 60 minutes)) trendresolution = 15 -- Set trend count resolution (!Important! Can only be these values: '30' = 30 days, '180' = 180 days, '365' = 1 year, '730' = 2 years, '1825' = 5 years trendcountresolution = 365 -- Set trend count days (!Important! Can only be these values: '1' = 1 year / '2' = 2 years / '5' = 5 years / '10' = 10 years) trendcountdaily = 10 -- Set show always 0 base line  trendshowzero = 0 -- 0 = disabled 1 = enabled ------------------------------------------ End Parameters ------------------------------------------ ------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE ------------------------------- -- Load modules require('json') require('socket.url') require('socket.http') -- Set HL ip address as localhost ip = '127.0.0.1' -- Create url for trend creation url = 'http://' .. username .. ':' .. password .. '@' .. ip .. '/scada-main/trends/save' -- Function to send request to create trend function url_send(trend_object, trend_name, trend_type, trend_resolution, trend_precision, trend_count_resolution, trend_count_daily, trend_show_zero, trend_id)   local trend = {       object = trend_object,       name = trend_name,       type = trend_type,       resolution = trend_resolution,       precision = trend_precision,     count_resolution = trend_count_resolution * 12 * 24, -- nr of days * nr of points in a hour at min resolution (60/5 = 12) * hours per day     count_daily = trend_count_daily * 365, -- nr of days * 365 days a year       show_zero = trend_show_zero,       id = trend_id,     }   data = json.encode(trend)     form_data = 'data=' .. socket.url.escape(data)     socket.http.TIMEOUT = 15        local res, code, response_header = socket.http.request(url, form_data)   return res, code, response_header end -- Set counters for creation log number_of_trends = 0 number_failed = 0 objectwithtag = grp.tag(tag_name) -- Loop for each group adress with specific tag  for key, value in pairs(objectwithtag) do      -- Get current group address from loop    current_GA = knxlib.decodega(value.id)      -- Get current object info   objectinfo = grp.find(current_GA)        -- Check if object excists   if objectinfo ~= nil then            -- Set parameters for request     trendobject = objectinfo.id     trendname = objectinfo.name     trendid = ''          -- Check if trend type 'Counter' should be created     if create_trendtype_counter == true then              -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'C', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)              -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end          -- Check if trend type 'Counter with negative delta' should be created     if create_trendtype_counter_with_negative_delta == true then                    -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'D', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                  -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end          -- Check if trend type 'Absolute value' should be created     if create_trendtype_absolute_value == true then                    -- Call function to send create request       result, code, response_header = url_send(trendobject, trendname, 'G', trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)                  -- Calculate results for creation results log         if result == '{"success":true}' then           number_of_trends = number_of_trends + 1         else           number_failed = number_failed + 1         end            end        end    end      if number_failed == 0 then     log ("Created " .. number_of_trends .. " trends succesfully") else     log ("Created " .. number_of_trends .. " trends succesfully and creation of " .. number_failed .. " trends failed") end -- Disable script when done automaticly script.disable(_SCRIPTNAME)
What kind of script is this? User library?
(13.02.2018, 16:52)Domoticatorino Wrote: What kind of script is this? User library?
Any kind of script. You just have to run it once.
(07.12.2016, 20:15)Pawel Wrote: Thanks Erwin, those scripts save me a lot of time. I made a small change and all objects with specific tag will have own trend:
Hi Pawel,
in this case don't you create .csv file?
No this script creates automaticaly trends attached to objects, way faster then creating them by hand (:
Got it! Thanks.
This script lacks the aggregate function. Could you update the script? Is there a function to delete all trends via script?
You can add aggregation parameter to the function arguments and trend parameter table. Possible values are MIN, MAX, LAST and AVERAGE.
To delete a certain trend, replace "save" with "delete" in URL and pass trend ID like this, where 123 is the ID you want to delete.
data = json.encode({ id = 123 })
I am using a somewhat minimized version of this script. I have used it many times before, but today it wont work. I get the error 'Host not found'. I was thinking it was because I had set the IP address and password wrong in my first attempt, but no... still after changing, it did not work. Any idea where to look for errors?
I have the script in a Wiser FW 2.7.0 it that is important...
My script is this one:
require('json') require('socket.url') require('socket.http') -- parameters daily = 365*24*60 -- 1 day daily1year = 365*24*12 -- 365 day daily2year = 2*365*24*12 -- 365 day year5_d = 5*365 -- 5 year tag = 'nyNyTrend' obj = grp.tag(tag) for _, addr in ipairs(obj) do   object = addr.address   alias = addr.name   trend = {     object = knxlib.encodega(object), -- object id in db     name = alias, -- trend name     type = trend_type,     resolution = 5, -- every 5 minute     precision = 2, -- floating point precision     count_resolution = 365*24*12, -- 1 year     count_daily = 5*365 -- 5 years   }   data = json.encode(trend)   post = 'data=' .. socket.url.escape(data)   grp.removetags(addr.name, tag)   res, err = socket.http.request('http://admin:qSHs5FAcfY@HRdn@192.168.68.249/scada-main/trends/save', post)   log(res, err) end script.disable(_SCRIPTNAME)
Host not found is usually a DNS error. Are you trying to do a request to a remove device or to a local one? For local requests you should use 127.0.0.1 as the IP address.
(17.06.2022, 13:20)admin Wrote: Host not found is usually a DNS error. Are you trying to do a request to a remove device or to a local one? For local requests you should use 127.0.0.1 as the IP address.
I did use the IP address of the device. I have changed it to 120.0.0.1, and now the error is timeout.
Not 120 but 127.0.0.1
