Weather Info from API
Please, I hope you could help me in my issue
However, I was trying to get the weather infomation from apixu.com and write them on the KNX bus.
I just followed the exemple on the openrb.com this one (https://openrb.com/featch-weather-forecast-from-apixu), I only changed the key variable as it's mentioned in the exemple.
This is the scheduled script that I used.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778
require('json') https = require('ssl.https') escape = require('socket.url').escape key = '737ad147e5be532e3d78995a68f4a160' location = 'Norway' url = 'https://api.apixu.com/v1/forecast.json?key=%s&q=%s&days=2' url = string.format(url, key, escape(location)) res = https.request(url) data = json.pdecode(res) if type(data) ~= 'table' then   alert('failed to load weather data')   return end if data.error then   log('error', data.error)   return end current = data.current today = data.forecast.forecastday[ 1 ].day tomorrow = data.forecast.forecastday[ 2 ].day -- log(current, today, tomorrow) -- temperature in C grp.write('32/1/1', current.temp_c) -- "feels like" temperature in C grp.write('32/1/2', current.feelslike_c) -- humidity as percentage grp.write('32/1/3', current.humidity) -- wind speed in kilometers per hour grp.write('32/1/4', current.wind_kph) -- uv index grp.write('32/1/5', current.uv) -- weather condition text grp.write('32/1/6', current.condition.text) -- pressure in millibars grp.write('32/1/7', current.pressure_mb) -- precipitation amount in millimeters grp.write('32/1/8', current.precip_mm) -- minimum temperature in celsius for the day grp.write('32/2/1', today.mintemp_c) -- maximum temperature in celsius for the day grp.write('32/2/2', today.maxtemp_c) -- average temperature in celsius for the day grp.write('32/2/3', today.avgtemp_c) -- average humidity as percentage grp.write('32/2/4', today.avghumidity) -- maximum wind speed in kilometers per hour grp.write('32/2/5', today.maxwind_kph) -- uv index grp.write('32/2/6', today.uv) -- weather condition text grp.write('32/2/7', today.condition.text) -- total precipitation in millimeters grp.write('32/2/8', today.totalprecip_mm) -- minimum temperature in celsius for the day grp.write('32/3/1', tomorrow.mintemp_c) -- maximum temperature in celsius for the day grp.write('32/3/2', tomorrow.maxtemp_c) -- average temperature in celsius for the day grp.write('32/3/3', tomorrow.avgtemp_c) -- average humidity as percentage grp.write('32/3/4', tomorrow.avghumidity) -- maximum wind speed in kilometers per hour grp.write('32/3/5', tomorrow.maxwind_kph) -- uv index grp.write('32/3/6', tomorrow.uv) -- weather condition text grp.write('32/3/7', tomorrow.condition.text) -- total precipitation in millimeters grp.write('32/3/8', tomorrow.totalprecip_mm)
No data was found on those groupe addresses,
Or if you could give me any other solution, I only wants to write 1 on the KNX bus if there's a snow tomorrow, the place is Bergen in Norway
Very grateful in advance
yr.no provides free detailed forecast API.
This example will check if there will be snow in the next day. You only need to adjust your location (latitude/longitude) and the status object address. There might be some limits on how often the API can be accessed so create a scheduled script that runs every 3 hours or so.
latitude = 60.3894 longitude = 5.33 status = '1/1/1' json = require('json') http = require('socket.http') args = 'lat=' .. latitude .. '&lon=' .. longitude url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http.USERAGENT = 'LM ' .. mac res, err = http.request(url) data = json.pdecode(res) if type(data) == 'table' then   date = os.date('*t')   date.day = date.day + 1   time = os.time(date)   timestamp = os.date('%Y-%m-%d', time)   snow = false   for i, entry in ipairs(data.properties.timeseries) do     if entry.time:sub(1, #timestamp) == timestamp then       next1h = entry.data.next_1_hours       code = ''       if type(next1h) == 'table' and type(next1h.summary) == 'table' then         code = next1h.summary.symbol_code or ''       end       if code:find('snow') then         snow = true         break       end     end   end   grp.checkwrite(status, snow) end
Hi Admin,
May I ask for a little bit of help also?
Do you experience problems with the setup explained here: https://openrb.com/featch-weather-forecast-from-apixu
Have and account and key but I get the following message:
1 "#        #"
2 "# IMPORTANT - PLEASE UPDATE YOUR API ENDPOINT        #"
3 "#        #"
4 "# This API endpoint is deprecated and has now been shut down. To keep using the apixu API, please update your integration      #"
5 "# to use the new weatherstack API endpoint, designed as a simple drop-in replacement.                                          #"
6 "# You will be required to create an account at https://weatherstack.com and obtain an API access key.                          #"
7 "#        #"
8 "# For more information on how to upgrade please visit our Github Tutorial at: https://github.com/apilayer/weatherstack#readme  #"
9 "#        #"
a "#################################################################################################################################"
Thank you in advance!
The free tier in weatherstack does not provide forecast data, only current conditions. Consider using yr.no instead. We will publish an updated integration script for yr.no next week.
Thank you for your replay!
I've been using YR until recently but it stopped. Looking forward to your YR script update Smile
may be some news about new yr.no weather script? Looks like one of the best free weather informers now..
Alex
Hi, here is new yr weather script.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193194195196197198199200201202203204205206207208209210211212213214215216217218219220221222223224225226227228229230231232233234235236237238239240241242243244245246247248249250251252253254255256257258259260261262263264265266267268269270271272273274275276277278279280281282283284285286287288289290291292293294295296297298299300301302303304305306307308309310311312313314315316317318319320321322323324325326327328329330331332333334335336337338339340341342343344345346347348349350351352353354355356357358359360361362363364365366
-- Please comment objects which you are not using, comment also grp.write() at the bottom of script --latitude = 60.3894 -- Bergen --longitude = 5.33   -- Bergen latitude = 56.9496  -- Riga longitude = 24.1052 -- Riga --latitude = 51.5072 -- London --longitude = 0.1276 -- London --[[ status_temp = '32/1/13'           -- group address of temperature, should be float status_pressure = '32/1/14'       -- air pressure, should be float status_humidity = '32/1/15'       -- relative humidity, should be float status_wind_direction = '32/1/16' -- wind direction, should be float status_wind_speed = '32/1/17'     -- wind speed, should be float status_uv_index = '32/2/4'        -- UV index, should be float status_feelslike_temp = '32/2/3'  -- feels like temperature, should be float status_rain_today = '32/1/11'     -- today's rain object, should be boolean status_snow_today = '32/1/12'     -- today's snow object, should be boolean status_min_temp_today = '32/1/20'       -- today's minimum air temperature, float status_max_temp_today = '32/1/21'       -- today's maximum air temperature, float status_min_pressure_today = '32/1/22'   -- minimum air pressure, float status_max_pressure_today = '32/1/23'   -- maximum air pressure, float status_min_wind_speed_today = '32/1/24' -- minimum wind speed, float status_max_wind_speed_today = '32/1/25' -- maximum wind speed, float status_min_uv_today = '32/2/5'          -- minimum UV today, float status_max_uv_today = '32/2/6'          -- maximum UV today, float status_rain_tomor = '32/1/9'   -- tomorrow's rain object status_snow_tomor = '32/1/10'  -- tomorrow's snow object status_min_temp_tomor = '32/1/26' status_max_temp_tomor = '32/1/27' status_min_pressure_tomor = '32/1/28' status_max_pressure_tomor = '32/1/29' status_min_wind_speed_tomor = '32/1/30' status_max_wind_speed_tomor = '32/1/31' status_min_uv_tomor = '32/2/7' status_max_uv_tomor = '32/2/8' --]] --[[]] status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',}) status_pressure = grp.create({ datatype = dt.float16, address = '33/1/2', name = 'current_press',}) status_humidity = grp.create({ datatype = dt.float16, address = '33/1/3', name = 'current_humid',}) status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',}) status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',}) status_uv_index = grp.create({ datatype = dt.float16, address = '33/1/6', name = 'current_uv_index',}) status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',}) status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',}) status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',}) status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',}) status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',}) status_min_pressure_today = grp.create({ datatype = dt.float16, address = '33/1/12', name = 'today_press_min',}) status_max_pressure_today = grp.create({ datatype = dt.float16, address = '33/1/13', name = 'today_press_max',}) status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',}) status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_press_max',}) status_min_uv_today = grp.create({ datatype = dt.float16, address = '33/1/16', name = 'today_uv_min',}) status_max_uv_today = grp.create({ datatype = dt.float16, address = '33/1/17', name = 'today_uv_max',}) status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',}) status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',}) status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',}) status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',}) status_min_pressure_tomor = grp.create({ datatype = dt.float16, address = '33/1/22', name = 'tomor_press_min',}) status_max_pressure_tomor = grp.create({ datatype = dt.float16, address = '33/1/23', name = 'tomor_press_max',}) status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',}) status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',}) status_min_uv_tomor = grp.create({ datatype = dt.float16, address = '33/1/26', name = 'tomor_uv_min',}) status_max_uv_tomor = grp.create({ datatype = dt.float16, address = '33/1/27', name = 'tomor_uv_max',}) --]] rain_tod_YR = false        -- is rainy or not (for today) snow_tod_YR = false        -- is snowy or not (for today) rain_tom_YR = false        -- is rainy or not (for tomorrow) snow_tom_YR = false        -- is snowy or not (for tomorrow) -- current temperature, air pressure, humidity, wind direction and speed temperature_YR = -273    -- temperature in degree Celsius air_pressure_YR = -1     -- air pressure in hPa humidity_YR = -1         -- air humidity in % wind_direction_YR = -1   -- wind direction in degrees [0; 360) wind_speed_YR = -1       -- wind speed in m/s uv_index_YR = -1         -- UV index feelslike_temp_YR = -273 -- feels like temperature in degree Celsius function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed   local min_max = {}   min_max.min_t = 8000 -- minimum temperature for today   min_max.max_t = -273 -- maximum temperature for today   min_max.min_p = 8000 -- minimum pressure for today   min_max.max_p = -1   -- maximum pressure for today   min_max.min_w = 8000 -- minimum wind speed for today   min_max.max_w = -1   -- maximum wind speed for today   min_max.min_uv = 8000 -- minimum UV index   min_max.max_uv = -1   -- maximum UV index     return min_max end function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow     local date = os.date('*t')   date.day = date.day + day   local time = os.time(date)   return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour end -- minimum maximum values of temperature, pressure and windspeed function min_max_temp_press_wind(dat_tab, min_max_tab)   min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)   min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)   min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)   min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)   min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)   min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)   min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)   min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)     return min_max_tab end function check_for_rain(next1h)     local is_rainy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('rain') then     is_rainy = true   end     return is_rainy end function check_for_snow(next1h)     local is_snowy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('snow') then     is_snowy = true   end   return is_snowy end function calc_heat_index(temperature, humidity)   if temperature < 26.7 then     log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')     return -273   end     if humidity < 0 or humidity > 100 then     log('humidity should be in a range from 0 ... 100%')     return -273   end     local T = temperature   local H = humidity   local c_1 = -8.785   local c_2 = 1.611   local c_3 = 2.339   local c_4 = -0.146   local c_5 = -0.0123   local c_6 = -0.0164   local c_7 = 0.00221   local c_8 = 0.000725   local c_9 = -0.00000358   local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H       return heat_index end function calc_wind_chill(temperature, wind_speed)   if temperature > 10 then     log('temperature should be less than +10.0 Celsius degree')       return -273   end       if wind_speed < 0 or wind_speed > 49.2 then       log('wind speed should be in a range 0 ... 49.2 m/s')     return -273   end     local T_air = temperature -- air temperature Celsius degree     local a = 0.62 -- coef   local b = 0.51 -- coef   local T_1 = 13.1 -- Celsius degree   local T_2 = 14.6 -- Celsius degree     local M_0 = 1.3333 -- m/s   local M = wind_speed -- m/s     local T_wind_chill     if M > M_0 then     T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16   else     T_wind_chill = T_air   end     return T_wind_chill end function calc_feelslike(temperature, wind_speed, humidity)   local T_feelslike       if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill     T_feelslike = calc_wind_chill(temperature, wind_speed)   elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index     T_feelslike = calc_heat_index(temperature, humidity)   else -- other cases just return temperature     T_feelslike = temperature   end   return T_feelslike end min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction json = require('json') http = require('socket.http') args = 'lat=' .. latitude .. '&lon=' .. longitude --url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http.USERAGENT = 'LM ' .. mac res, err = http.request(url) data = json.pdecode(res) if type(data) == 'table' then   timestamp, hour = set_timestamp(0) -- current day     if hour < 10 then     timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour   else     timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z'  -- time stamp for current hour   end     --log('timestamp = ' .. timestamp)     timestamp_next = set_timestamp(1) -- timestamp for tomorrow   --log('timestamp_next = ' .. timestamp_next)     --timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow   --log('timestamp_after_next = ' .. timestamp_after_next)     --timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow   --log('timestamp_after_after = ' .. timestamp_after_after)     for i, entry in ipairs(data.properties.timeseries) do          -- for weather now     if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)       current_data = entry.data.instant.details       if type(current_data) == 'table' then         temperature_YR = current_data.air_temperature or -273           -- temperature in Celsius degree         air_pressure_YR = current_data.air_pressure_at_sea_level or -1  -- air pressure in hPa         humidity_YR = current_data.relative_humidity or -1              -- air humidity in %         wind_direction_YR = current_data.wind_from_direction or -1      -- wind direction in degrees [0;360)         wind_speed_YR = current_data.wind_speed or -1                   -- wind speed in m/s         uv_index_YR = current_data.ultraviolet_index_clear_sky or -1    -- uv index         feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree       end     end         if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day         current_data = entry.data.instant.details       if type(current_data) == 'table' then         min_max_today = min_max_temp_press_wind(current_data, min_max_today)       end             if rain_tod_YR == false then -- if detected rain does not check for rain         rain_tod_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tod_YR == false then -- if detected snow does not check for snow         snow_tod_YR = check_for_snow(entry.data.next_1_hours)       end     end         if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day       tomor_data = entry.data.instant.details       if type(tomor_data) == 'table' then         min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)       end             if rain_tom_YR == false then -- if detected rain does not check for rain         rain_tom_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tom_YR == false then -- if detected snow does not check for snow         snow_tom_YR = check_for_snow(entry.data.next_1_hours)       end     end     end     -- data for current hour   grp.write(status_temp, temperature_YR)   grp.write(status_pressure, air_pressure_YR)   grp.write(status_humidity, humidity_YR)   grp.write(status_wind_direction, wind_direction_YR)   grp.write(status_wind_speed, wind_speed_YR)   grp.write(status_uv_index, uv_index_YR)   grp.write(status_feelslike_temp, feelslike_temp_YR)       -- data for today: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_today, rain_tod_YR)   grp.write(status_snow_today, snow_tod_YR)     grp.write(status_min_temp_today, min_max_today.min_t)   grp.write(status_max_temp_today, min_max_today.max_t)   grp.write(status_min_pressure_today, min_max_today.min_p)   grp.write(status_max_pressure_today, min_max_today.max_p)   grp.write(status_min_wind_speed_today, min_max_today.min_w)   grp.write(status_max_wind_speed_today, min_max_today.max_w)   grp.write(status_min_uv_today, min_max_today.min_uv)   grp.write(status_max_uv_today, min_max_today.max_uv)       -- data for tomorrow: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_tomor, rain_tom_YR)   grp.write(status_snow_tomor, snow_tom_YR)     grp.write(status_min_temp_tomor, min_max_tomor.min_t)   grp.write(status_max_temp_tomor, min_max_tomor.max_t)   grp.write(status_min_pressure_tomor, min_max_tomor.min_p)   grp.write(status_max_pressure_tomor, min_max_tomor.max_p)   grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)   grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)   grp.write(status_min_uv_tomor, min_max_tomor.min_uv)   grp.write(status_max_uv_tomor, min_max_tomor.max_uv)   end
.lua   my_script_v12.lua (Size: 14.97 KB / Downloads: 22)
Hi, super job is done!. Will test it in nearest time.
Some ideas for improvements/additional possibilities:
1. If weather info is needed for place where device is located - possible not to show coordinates directly in script but take them from system:
require('uci')
latitude = uci.get('genohm-scada.core.latitude')
latitude = tonumber(latitude) or 0
longitude = uci.get('genohm-scada.core.longitude')
longitude = tonumber(longitude) or 0
If 0 - no coordinates - should be entered than..;
2. Would be great if we can show group addresses for weather conditions in the beginning of script, because these groups will be created later in this script (addresses showed natively, not by names). I see it was planned to do so, but was commented.. For me groups 33/1/XX are used, For test I will manually change them in script;
3. In my existing weather script I use weather condition icons. So condition is taken from informer, than condition's icon is showed at visu...
May be ''symbol code'' info from yr.no we can add to script and use with icons?
4. how often we can start this script? Once a day? Some informers not allowed very often requests and can block them, or allows for additional payment..
Alex
I have found out that, there was wrong name for object of maximum wind speed
was
should be
status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',})
The updated version of weather script.
1.) Added possibility to read coordinates (latitude and longitude) from system.
2.) Changed data types of objects:
        a.) for humidity dt.scale
        b.) for uv_index dt.uint8
        c.) for pressure dt.uint16
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193194195196197198199200201202203204205206207208209210211212213214215216217218219220221222223224225226227228229230231232233234235236237238239240241242243244245246247248249250251252253254255256257258259260261262263264265266267268269270271272273274275276277278279280281282283284285286287288289290291292293294295296297298299300301302303304305306307308309310311312313314315316317318319320321322323324325326327328329330331332333334335336337338339340341342343344345346347348349350351352353354355356357358359360361362363364365366367368369370371372373374375376377378379380381382383384385386387388389
-- Please comment objects which you are not using, comment also grp.write() at the bottom of script --[[ -- You can set latitude and longitude in "Date time" option -- go to LogicMachine->Utilities->Date and time require('uci') latitude = uci.get('genohm-scada.core.latitude') -- read latitude from system latitude = tonumber(latitude) or 0 longitude = uci.get('genohm-scada.core.longitude') -- read longitude from system longitude = tonumber(longitude) or 0 if(latitude == 0 and longitude == 0) then -- if cooridinates were not set in the system   latitude = 51.5072 -- London   longitude = 0.1276 -- London end --]] -- you can set latitude and longitude manualy -- (if you set coordinates using "Date time" do not forget to comment these two lines latitude = 56.9496  -- Riga longitude = 24.1052 -- Riga --log('latitude = ' .. latitude) --log('longitude = ' .. longitude) --[[ status_temp = '32/1/13'           -- group address of temperature, should be float status_pressure = '32/1/14'       -- air pressure, should be float status_humidity = '32/1/15'       -- relative humidity, should be float status_wind_direction = '32/1/16' -- wind direction, should be float status_wind_speed = '32/1/17'     -- wind speed, should be float status_uv_index = '32/2/4'        -- UV index, should be float status_feelslike_temp = '32/2/3'  -- feels like temperature, should be float status_rain_today = '32/1/11'     -- today's rain object, should be boolean status_snow_today = '32/1/12'     -- today's snow object, should be boolean status_min_temp_today = '32/1/20'       -- today's minimum air temperature, float status_max_temp_today = '32/1/21'       -- today's maximum air temperature, float status_min_pressure_today = '32/1/22'   -- minimum air pressure, float status_max_pressure_today = '32/1/23'   -- maximum air pressure, float status_min_wind_speed_today = '32/1/24' -- minimum wind speed, float status_max_wind_speed_today = '32/1/25' -- maximum wind speed, float status_min_uv_today = '32/2/5'          -- minimum UV today, float status_max_uv_today = '32/2/6'          -- maximum UV today, float status_rain_tomor = '32/1/9'   -- tomorrow's rain object status_snow_tomor = '32/1/10'  -- tomorrow's snow object status_min_temp_tomor = '32/1/26' status_max_temp_tomor = '32/1/27' status_min_pressure_tomor = '32/1/28' status_max_pressure_tomor = '32/1/29' status_min_wind_speed_tomor = '32/1/30' status_max_wind_speed_tomor = '32/1/31' status_min_uv_tomor = '32/2/7' status_max_uv_tomor = '32/2/8' --]] --[[]] status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',}) status_pressure = grp.create({ datatype = dt.uint16, address = '33/1/2', name = 'current_press',}) status_humidity = grp.create({ datatype = dt.scale, address = '33/1/3', name = 'current_humid',}) status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',}) status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',}) status_uv_index = grp.create({ datatype = dt.uint8, address = '33/1/6', name = 'current_uv_index',}) status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',}) status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',}) status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',}) status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',}) status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',}) status_min_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/12', name = 'today_press_min',}) status_max_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/13', name = 'today_press_max',}) status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',}) status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',}) status_min_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/16', name = 'today_uv_min',}) status_max_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/17', name = 'today_uv_max',}) status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',}) status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',}) status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',}) status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',}) status_min_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/22', name = 'tomor_press_min',}) status_max_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/23', name = 'tomor_press_max',}) status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',}) status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',}) status_min_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/26', name = 'tomor_uv_min',}) status_max_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/27', name = 'tomor_uv_max',}) --]] rain_tod_YR = false        -- is rainy or not (for today) snow_tod_YR = false        -- is snowy or not (for today) rain_tom_YR = false        -- is rainy or not (for tomorrow) snow_tom_YR = false        -- is snowy or not (for tomorrow) -- current temperature, air pressure, humidity, wind direction and speed temperature_YR = -273    -- temperature in degree Celsius air_pressure_YR = -1     -- air pressure in hPa humidity_YR = -1         -- air humidity in % wind_direction_YR = -1   -- wind direction in degrees [0; 360) wind_speed_YR = -1       -- wind speed in m/s uv_index_YR = -1         -- UV index feelslike_temp_YR = -273 -- feels like temperature in degree Celsius function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed   local min_max = {}   min_max.min_t = 8000 -- minimum temperature for today   min_max.max_t = -273 -- maximum temperature for today   min_max.min_p = 8000 -- minimum pressure for today   min_max.max_p = -1   -- maximum pressure for today   min_max.min_w = 8000 -- minimum wind speed for today   min_max.max_w = -1   -- maximum wind speed for today   min_max.min_uv = 8000 -- minimum UV index   min_max.max_uv = -1   -- maximum UV index     return min_max end function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow   local date = os.date('*t')   date.day = date.day + day   local time = os.time(date)   return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour end -- minimum maximum values of temperature, pressure and windspeed function min_max_temp_press_wind(dat_tab, min_max_tab)   min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)   min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)   min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)   min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)   min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)   min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)   min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)   min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)     return min_max_tab end function check_for_rain(next1h)   local is_rainy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('rain') then     is_rainy = true   end     return is_rainy end function check_for_snow(next1h)   local is_snowy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('snow') then     is_snowy = true   end   return is_snowy end function calc_heat_index(temperature, humidity)   if temperature < 26.7 then     log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')     return -273   end     if humidity < 0 or humidity > 100 then     log('humidity should be in a range from 0 ... 100%')     return -273   end     local T = temperature   local H = humidity   local c_1 = -8.785   local c_2 = 1.611   local c_3 = 2.339   local c_4 = -0.146   local c_5 = -0.0123   local c_6 = -0.0164   local c_7 = 0.00221   local c_8 = 0.000725   local c_9 = -0.00000358   local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H       return heat_index end function calc_wind_chill(temperature, wind_speed)   if temperature > 10 then     log('temperature should be less than +10.0 Celsius degree')       return -273   end       if wind_speed < 0 or wind_speed > 49.2 then       log('wind speed should be in a range 0 ... 49.2 m/s')     return -273   end     local T_air = temperature -- air temperature Celsius degree     local a = 0.62 -- coef   local b = 0.51 -- coef   local T_1 = 13.1 -- Celsius degree   local T_2 = 14.6 -- Celsius degree     local M_0 = 1.3333 -- m/s   local M = wind_speed -- m/s     local T_wind_chill     if M > M_0 then     T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16   else     T_wind_chill = T_air   end     return T_wind_chill end function calc_feelslike(temperature, wind_speed, humidity)   local T_feelslike     if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill     T_feelslike = calc_wind_chill(temperature, wind_speed)   elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index     T_feelslike = calc_heat_index(temperature, humidity)   else -- other cases just return temperature     T_feelslike = temperature   end   return T_feelslike end min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction json = require('json') http = require('socket.http') args = 'lat=' .. latitude .. '&lon=' .. longitude --url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http.USERAGENT = 'LM ' .. mac res, err = http.request(url) data = json.pdecode(res) if type(data) == 'table' then   timestamp, hour = set_timestamp(0) -- current day     if hour < 10 then     timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour   else     timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z'  -- time stamp for current hour   end     --log('timestamp = ' .. timestamp)     timestamp_next = set_timestamp(1) -- timestamp for tomorrow   --log('timestamp_next = ' .. timestamp_next)     --timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow   --log('timestamp_after_next = ' .. timestamp_after_next)     --timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow   --log('timestamp_after_after = ' .. timestamp_after_after)     for i, entry in ipairs(data.properties.timeseries) do          -- for weather now     if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)       current_data = entry.data.instant.details       if type(current_data) == 'table' then         temperature_YR = current_data.air_temperature or -273           -- temperature in Celsius degree         air_pressure_YR = current_data.air_pressure_at_sea_level or -1  -- air pressure in hPa         humidity_YR = current_data.relative_humidity or -1              -- air humidity in %         wind_direction_YR = current_data.wind_from_direction or -1      -- wind direction in degrees [0;360)         wind_speed_YR = current_data.wind_speed or -1                   -- wind speed in m/s         uv_index_YR = current_data.ultraviolet_index_clear_sky or -1    -- uv index         feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree       end     end         if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day         current_data = entry.data.instant.details       if type(current_data) == 'table' then         min_max_today = min_max_temp_press_wind(current_data, min_max_today)       end             if rain_tod_YR == false then -- if detected rain does not check for rain         rain_tod_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tod_YR == false then -- if detected snow does not check for snow         snow_tod_YR = check_for_snow(entry.data.next_1_hours)       end     end         if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day       tomor_data = entry.data.instant.details       if type(tomor_data) == 'table' then         min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)       end             if rain_tom_YR == false then -- if detected rain does not check for rain         rain_tom_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tom_YR == false then -- if detected snow does not check for snow         snow_tom_YR = check_for_snow(entry.data.next_1_hours)       end     end     end     -- data for current hour   grp.write(status_temp, temperature_YR)   grp.write(status_pressure, air_pressure_YR)   grp.write(status_humidity, humidity_YR)   grp.write(status_wind_direction, wind_direction_YR)   grp.write(status_wind_speed, wind_speed_YR)   grp.write(status_uv_index, uv_index_YR)   grp.write(status_feelslike_temp, feelslike_temp_YR)       -- data for today: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_today, rain_tod_YR)   grp.write(status_snow_today, snow_tod_YR)     grp.write(status_min_temp_today, min_max_today.min_t)   grp.write(status_max_temp_today, min_max_today.max_t)   grp.write(status_min_pressure_today, min_max_today.min_p)   grp.write(status_max_pressure_today, min_max_today.max_p)   grp.write(status_min_wind_speed_today, min_max_today.min_w)   grp.write(status_max_wind_speed_today, min_max_today.max_w)   grp.write(status_min_uv_today, min_max_today.min_uv)   grp.write(status_max_uv_today, min_max_today.max_uv)       -- data for tomorrow: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_tomor, rain_tom_YR)   grp.write(status_snow_tomor, snow_tom_YR)     grp.write(status_min_temp_tomor, min_max_tomor.min_t)   grp.write(status_max_temp_tomor, min_max_tomor.max_t)   grp.write(status_min_pressure_tomor, min_max_tomor.min_p)   grp.write(status_max_pressure_tomor, min_max_tomor.max_p)   grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)   grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)   grp.write(status_min_uv_tomor, min_max_tomor.min_uv)   grp.write(status_max_uv_tomor, min_max_tomor.max_uv)   end
4. How often we can start this script?
You can run the script every four hours, should work fine.
.lua   my_script_v13.lua (Size: 15.57 KB / Downloads: 17)
Thank you for the script RomansP!
Have tested, but I get no data coming to addresses 33/1/*. All stay at 0.
Although I receive a link with data when I log (url) at line 272.
Is it still working with you?
Hi, Mrinj!
Yes it is still working for me. Can you attach your script, so I will try to figure out what could gone wrong.
The updated version for script.
Added check for http.request , so there will be a log if something gone wrong.
res, code = http.request(url) if res and code == 200 then   data = json.pdecode(res) else   log('request error', res, code) end
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193194195196197198199200201202203204205206207208209210211212213214215216217218219220221222223224225226227228229230231232233234235236237238239240241242243244245246247248249250251252253254255256257258259260261262263264265266267268269270271272273274275276277278279280281282283284285286287288289290291292293294295296297298299300301302303304305306307308309310311312313314315316317318319320321322323324325326327328329330331332333334335336337338339340341342343344345346347348349350351352353354355356357358359360361362363364365366367368369370371372373374375376377378379380381382383384385386387388389390391392393394395
-- Please comment objects which you are not using, comment also grp.write() at the bottom of script --[[ -- You can set latitude and longitude in "Date time" option -- go to LogicMachine->Utilities->Date and time require('uci') latitude = uci.get('genohm-scada.core.latitude') -- read latitude from system latitude = tonumber(latitude) or 0 longitude = uci.get('genohm-scada.core.longitude') -- read longitude from system longitude = tonumber(longitude) or 0 if(latitude == 0 and longitude == 0) then -- if cooridinates were not set in the system   latitude = 51.5072 -- London   longitude = 0.1276 -- London end --]] -- you can set latitude and longitude manualy -- (if you set coordinates using "Date time" do not forget to comment these two lines latitude = 56.9496  -- Riga longitude = 24.1052 -- Riga --log('latitude = ' .. latitude) --log('longitude = ' .. longitude) --[[ status_temp = '32/1/13'           -- group address of temperature, should be float status_pressure = '32/1/14'       -- air pressure, should be float status_humidity = '32/1/15'       -- relative humidity, should be float status_wind_direction = '32/1/16' -- wind direction, should be float status_wind_speed = '32/1/17'     -- wind speed, should be float status_uv_index = '32/2/4'        -- UV index, should be float status_feelslike_temp = '32/2/3'  -- feels like temperature, should be float status_rain_today = '32/1/11'     -- today's rain object, should be boolean status_snow_today = '32/1/12'     -- today's snow object, should be boolean status_min_temp_today = '32/1/20'       -- today's minimum air temperature, float status_max_temp_today = '32/1/21'       -- today's maximum air temperature, float status_min_pressure_today = '32/1/22'   -- minimum air pressure, float status_max_pressure_today = '32/1/23'   -- maximum air pressure, float status_min_wind_speed_today = '32/1/24' -- minimum wind speed, float status_max_wind_speed_today = '32/1/25' -- maximum wind speed, float status_min_uv_today = '32/2/5'          -- minimum UV today, float status_max_uv_today = '32/2/6'          -- maximum UV today, float status_rain_tomor = '32/1/9'   -- tomorrow's rain object status_snow_tomor = '32/1/10'  -- tomorrow's snow object status_min_temp_tomor = '32/1/26' status_max_temp_tomor = '32/1/27' status_min_pressure_tomor = '32/1/28' status_max_pressure_tomor = '32/1/29' status_min_wind_speed_tomor = '32/1/30' status_max_wind_speed_tomor = '32/1/31' status_min_uv_tomor = '32/2/7' status_max_uv_tomor = '32/2/8' --]] --[[]] status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',}) status_pressure = grp.create({ datatype = dt.uint16, address = '33/1/2', name = 'current_press',}) status_humidity = grp.create({ datatype = dt.scale, address = '33/1/3', name = 'current_humid',}) status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',}) status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',}) status_uv_index = grp.create({ datatype = dt.uint8, address = '33/1/6', name = 'current_uv_index',}) status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',}) status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',}) status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',}) status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',}) status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',}) status_min_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/12', name = 'today_press_min',}) status_max_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/13', name = 'today_press_max',}) status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',}) status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',}) status_min_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/16', name = 'today_uv_min',}) status_max_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/17', name = 'today_uv_max',}) status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',}) status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',}) status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',}) status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',}) status_min_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/22', name = 'tomor_press_min',}) status_max_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/23', name = 'tomor_press_max',}) status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',}) status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',}) status_min_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/26', name = 'tomor_uv_min',}) status_max_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/27', name = 'tomor_uv_max',}) --]] rain_tod_YR = false        -- is rainy or not (for today) snow_tod_YR = false        -- is snowy or not (for today) rain_tom_YR = false        -- is rainy or not (for tomorrow) snow_tom_YR = false        -- is snowy or not (for tomorrow) -- current temperature, air pressure, humidity, wind direction and speed temperature_YR = -273    -- temperature in degree Celsius air_pressure_YR = -1     -- air pressure in hPa humidity_YR = -1         -- air humidity in % wind_direction_YR = -1   -- wind direction in degrees [0; 360) wind_speed_YR = -1       -- wind speed in m/s uv_index_YR = -1         -- UV index feelslike_temp_YR = -273 -- feels like temperature in degree Celsius function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed   local min_max = {}   min_max.min_t = 8000 -- minimum temperature for today   min_max.max_t = -273 -- maximum temperature for today   min_max.min_p = 8000 -- minimum pressure for today   min_max.max_p = -1   -- maximum pressure for today   min_max.min_w = 8000 -- minimum wind speed for today   min_max.max_w = -1   -- maximum wind speed for today   min_max.min_uv = 8000 -- minimum UV index   min_max.max_uv = -1   -- maximum UV index     return min_max end function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow   local date = os.date('*t')   date.day = date.day + day   local time = os.time(date)   return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour end -- minimum maximum values of temperature, pressure and windspeed function min_max_temp_press_wind(dat_tab, min_max_tab)   min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)   min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)   min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)   min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)   min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)   min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)   min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)   min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)     return min_max_tab end function check_for_rain(next1h)   local is_rainy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('rain') then     is_rainy = true   end     return is_rainy end function check_for_snow(next1h)   local is_snowy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('snow') then     is_snowy = true   end   return is_snowy end function calc_heat_index(temperature, humidity)   if temperature < 26.7 then     log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')     return -273   end     if humidity < 0 or humidity > 100 then     log('humidity should be in a range from 0 ... 100%')     return -273   end     local T = temperature   local H = humidity   local c_1 = -8.785   local c_2 = 1.611   local c_3 = 2.339   local c_4 = -0.146   local c_5 = -0.0123   local c_6 = -0.0164   local c_7 = 0.00221   local c_8 = 0.000725   local c_9 = -0.00000358   local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H       return heat_index end function calc_wind_chill(temperature, wind_speed)   if temperature > 10 then     log('temperature should be less than +10.0 Celsius degree')       return -273   end       if wind_speed < 0 or wind_speed > 49.2 then       log('wind speed should be in a range 0 ... 49.2 m/s')     return -273   end     local T_air = temperature -- air temperature Celsius degree     local a = 0.62 -- coef   local b = 0.51 -- coef   local T_1 = 13.1 -- Celsius degree   local T_2 = 14.6 -- Celsius degree     local M_0 = 1.3333 -- m/s   local M = wind_speed -- m/s     local T_wind_chill     if M > M_0 then     T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16   else     T_wind_chill = T_air   end     return T_wind_chill end function calc_feelslike(temperature, wind_speed, humidity)   local T_feelslike     if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill     T_feelslike = calc_wind_chill(temperature, wind_speed)   elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index     T_feelslike = calc_heat_index(temperature, humidity)   else -- other cases just return temperature     T_feelslike = temperature   end   return T_feelslike end min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction json = require('json') http = require('socket.http') args = 'lat=' .. latitude .. '&lon=' .. longitude --url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http.USERAGENT = 'LM ' .. mac res, code = http.request(url) if res and code == 200 then   data = json.pdecode(res) else   log('request error', res, code) end if type(data) == 'table' then   timestamp, hour = set_timestamp(0) -- current day     if hour < 10 then     timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour   else     timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z'  -- time stamp for current hour   end     --log('timestamp = ' .. timestamp)     timestamp_next = set_timestamp(1) -- timestamp for tomorrow   --log('timestamp_next = ' .. timestamp_next)     --timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow   --log('timestamp_after_next = ' .. timestamp_after_next)     --timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow   --log('timestamp_after_after = ' .. timestamp_after_after)     for i, entry in ipairs(data.properties.timeseries) do          -- for weather now     if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)       current_data = entry.data.instant.details       if type(current_data) == 'table' then         temperature_YR = current_data.air_temperature or -273           -- temperature in Celsius degree         air_pressure_YR = current_data.air_pressure_at_sea_level or -1  -- air pressure in hPa         humidity_YR = current_data.relative_humidity or -1              -- air humidity in %         wind_direction_YR = current_data.wind_from_direction or -1      -- wind direction in degrees [0;360)         wind_speed_YR = current_data.wind_speed or -1                   -- wind speed in m/s         uv_index_YR = current_data.ultraviolet_index_clear_sky or -1    -- uv index         feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree       end     end         if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day         current_data = entry.data.instant.details       if type(current_data) == 'table' then         min_max_today = min_max_temp_press_wind(current_data, min_max_today)       end             if rain_tod_YR == false then -- if detected rain does not check for rain         rain_tod_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tod_YR == false then -- if detected snow does not check for snow         snow_tod_YR = check_for_snow(entry.data.next_1_hours)       end     end         if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day       tomor_data = entry.data.instant.details       if type(tomor_data) == 'table' then         min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)       end             if rain_tom_YR == false then -- if detected rain does not check for rain         rain_tom_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tom_YR == false then -- if detected snow does not check for snow         snow_tom_YR = check_for_snow(entry.data.next_1_hours)       end     end     end     -- data for current hour   grp.write(status_temp, temperature_YR)   grp.write(status_pressure, air_pressure_YR)   grp.write(status_humidity, humidity_YR)   grp.write(status_wind_direction, wind_direction_YR)   grp.write(status_wind_speed, wind_speed_YR)   grp.write(status_uv_index, uv_index_YR)   grp.write(status_feelslike_temp, feelslike_temp_YR)       -- data for today: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_today, rain_tod_YR)   grp.write(status_snow_today, snow_tod_YR)     grp.write(status_min_temp_today, min_max_today.min_t)   grp.write(status_max_temp_today, min_max_today.max_t)   grp.write(status_min_pressure_today, min_max_today.min_p)   grp.write(status_max_pressure_today, min_max_today.max_p)   grp.write(status_min_wind_speed_today, min_max_today.min_w)   grp.write(status_max_wind_speed_today, min_max_today.max_w)   grp.write(status_min_uv_today, min_max_today.min_uv)   grp.write(status_max_uv_today, min_max_today.max_uv)       -- data for tomorrow: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_tomor, rain_tom_YR)   grp.write(status_snow_tomor, snow_tom_YR)     grp.write(status_min_temp_tomor, min_max_tomor.min_t)   grp.write(status_max_temp_tomor, min_max_tomor.max_t)   grp.write(status_min_pressure_tomor, min_max_tomor.min_p)   grp.write(status_max_pressure_tomor, min_max_tomor.max_p)   grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)   grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)   grp.write(status_min_uv_tomor, min_max_tomor.min_uv)   grp.write(status_max_uv_tomor, min_max_tomor.max_uv)   end
.lua   my_script_v14.lua (Size: 15.65 KB / Downloads: 15)
(22.06.2022, 08:00)Mrinj Wrote: Thank you for the script RomansP!
Great script,
Thank you for sharing it.
(22.06.2022, 08:17)Thank you RomansP! Very kind of you! Wrote: Testing with your V14 script I get the following error in the log:
* arg: 1
  * string: request error
* arg: 2
  * nil
* arg: 3
  * string: error:1409442E:lib(20):func(148):reason(1070)
As sad earlier, from your script I only change the addresses to 53/1/* from your script cause my 33/*/* once are busy Smile
Script is attached.
Thanks!
Mrinj
RomansPHi, Mrinj!
.lua   my_script_mrinj_v14.lua (Size: 15.65 KB / Downloads: 16)
This lib/func/reason error is due to an outdated firmware.
(23.06.2022, 06:24)admin Wrote: This lib/func/reason error is due to an outdated firmware.
Thank you admin!
I will update and test Smile
However, Until now i had script work fine , but now i cant obtain weather dates,
I can see on log :
* arg: 1
* string: <html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
latitude = 40.4538899 longitude = -3.6211718 json = require('json') http2 = require('socket.http') log (http2) --http = require('ssl.https') --log ( http) args = 'lat=' .. latitude .. '&lon=' .. longitude url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args --url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http2.USERAGENT = 'LM ' .. mac res, err = http2.request(url) log ( res, err) data = json.pdecode(res) log (data) if type(data) == 'table' then   date = os.date('*t')   date.day = date.day + 1   time = os.time(date)   timestamp = os.date('%Y-%m-%d', time)   log(data)
You have an old firmware which does not support HTTPS directly in socket.http. ssl.https must be used instead.
The request part can be rewritten like this to work with older firmware:
latitude = 40.4538899 longitude = -3.6211718 https = require('ssl.https') json = require('json') ltn12 = require('ltn12') args = 'lat=' .. latitude .. '&lon=' .. longitude url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) response = {} res, code = https.request({   url = url,   protocol = 'tlsv12',   headers = {     ['user-agent'] = 'LM ' .. mac   },   sink = ltn12.sink.table(response) }) if res and code == 200 then   data = json.pdecode(table.concat(response)) end if type(data) == 'table' then   log(data) else   log('request failed', res, code) end
Thaks a lot!!
If I use the script above , I have no data , I receive :
table:
[data]
* table:
[next_6_hours]
* table:
[summary]
* table:
nesting too deep
[details]
* table:
nesting too deep
[next_12_hours]
* table:
[summary]
* table:
nesting too deep
[next_1_hours]
* table:
[summary]
* table:
nesting too deep
Hi, Acla, it is correct, you need to parse all the data. You can use this script.
status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',}) status_pressure = grp.create({ datatype = dt.uint16, address = '33/1/2', name = 'current_press',}) status_humidity = grp.create({ datatype = dt.scale, address = '33/1/3', name = 'current_humid',}) status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',}) status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',}) status_uv_index = grp.create({ datatype = dt.uint8, address = '33/1/6', name = 'current_uv_index',}) status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',}) status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',}) status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',}) status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',}) status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',}) status_min_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/12', name = 'today_press_min',}) status_max_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/13', name = 'today_press_max',}) status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',}) status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',}) status_min_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/16', name = 'today_uv_min',}) status_max_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/17', name = 'today_uv_max',}) status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',}) status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',}) status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',}) status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',}) status_min_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/22', name = 'tomor_press_min',}) status_max_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/23', name = 'tomor_press_max',}) status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',}) status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',}) status_min_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/26', name = 'tomor_uv_min',}) status_max_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/27', name = 'tomor_uv_max',}) rain_tod_YR = false        -- is rainy or not (for today) snow_tod_YR = false        -- is snowy or not (for today) rain_tom_YR = false        -- is rainy or not (for tomorrow) snow_tom_YR = false        -- is snowy or not (for tomorrow) -- current temperature, air pressure, humidity, wind direction and speed temperature_YR = -273    -- temperature in degree Celsius air_pressure_YR = -1     -- air pressure in hPa humidity_YR = -1         -- air humidity in % wind_direction_YR = -1   -- wind direction in degrees [0; 360) wind_speed_YR = -1       -- wind speed in m/s uv_index_YR = -1         -- UV index feelslike_temp_YR = -273 -- feels like temperature in degree Celsius function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed   local min_max = {}   min_max.min_t = 8000 -- minimum temperature for today   min_max.max_t = -273 -- maximum temperature for today   min_max.min_p = 8000 -- minimum pressure for today   min_max.max_p = -1   -- maximum pressure for today   min_max.min_w = 8000 -- minimum wind speed for today   min_max.max_w = -1   -- maximum wind speed for today   min_max.min_uv = 8000 -- minimum UV index   min_max.max_uv = -1   -- maximum UV index     return min_max end function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow   local date = os.date('*t')   date.day = date.day + day   local time = os.time(date)   return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour end -- minimum maximum values of temperature, pressure and windspeed function min_max_temp_press_wind(dat_tab, min_max_tab)   min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)   min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)   min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)   min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)   min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)   min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)   min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)   min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)     return min_max_tab end function check_for_rain(next1h)   local is_rainy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('rain') then     is_rainy = true   end     return is_rainy end function check_for_snow(next1h)   local is_snowy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('snow') then     is_snowy = true   end   return is_snowy end function calc_heat_index(temperature, humidity)   if temperature < 26.7 then     log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')     return -273   end     if humidity < 0 or humidity > 100 then     log('humidity should be in a range from 0 ... 100%')     return -273   end     local T = temperature   local H = humidity   local c_1 = -8.785   local c_2 = 1.611   local c_3 = 2.339   local c_4 = -0.146   local c_5 = -0.0123   local c_6 = -0.0164   local c_7 = 0.00221   local c_8 = 0.000725   local c_9 = -0.00000358   local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H       return heat_index end function calc_wind_chill(temperature, wind_speed)   if temperature > 10 then     log('temperature should be less than +10.0 Celsius degree')       return -273   end       if wind_speed < 0 or wind_speed > 49.2 then       log('wind speed should be in a range 0 ... 49.2 m/s')     return -273   end     local T_air = temperature -- air temperature Celsius degree     local a = 0.62 -- coef   local b = 0.51 -- coef   local T_1 = 13.1 -- Celsius degree   local T_2 = 14.6 -- Celsius degree     local M_0 = 1.3333 -- m/s   local M = wind_speed -- m/s     local T_wind_chill     if M > M_0 then     T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16   else     T_wind_chill = T_air   end     return T_wind_chill end function calc_feelslike(temperature, wind_speed, humidity)   local T_feelslike     if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill     T_feelslike = calc_wind_chill(temperature, wind_speed)   elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index     T_feelslike = calc_heat_index(temperature, humidity)   else -- other cases just return temperature     T_feelslike = temperature   end   return T_feelslike end min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction latitude = 40.4538899 longitude = -3.6211718 https = require('ssl.https') json = require('json') ltn12 = require('ltn12') args = 'lat=' .. latitude .. '&lon=' .. longitude url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) response = {} res, code = https.request({   url = url,   protocol = 'tlsv12',   headers = {     ['user-agent'] = 'LM ' .. mac   },   sink = ltn12.sink.table(response) }) if res and code == 200 then   data = json.pdecode(table.concat(response)) else   log('request error', res, code) end if type(data) == 'table' then   timestamp, hour = set_timestamp(0) -- current day     if hour < 10 then     timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour   else     timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z'  -- time stamp for current hour   end     --log('timestamp = ' .. timestamp)     timestamp_next = set_timestamp(1) -- timestamp for tomorrow   --log('timestamp_next = ' .. timestamp_next)     --timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow   --log('timestamp_after_next = ' .. timestamp_after_next)     --timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow   --log('timestamp_after_after = ' .. timestamp_after_after)     for i, entry in ipairs(data.properties.timeseries) do          -- for weather now     if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)       current_data = entry.data.instant.details       if type(current_data) == 'table' then         temperature_YR = current_data.air_temperature or -273           -- temperature in Celsius degree         air_pressure_YR = current_data.air_pressure_at_sea_level or -1  -- air pressure in hPa         humidity_YR = current_data.relative_humidity or -1              -- air humidity in %         wind_direction_YR = current_data.wind_from_direction or -1      -- wind direction in degrees [0;360)         wind_speed_YR = current_data.wind_speed or -1                   -- wind speed in m/s         uv_index_YR = current_data.ultraviolet_index_clear_sky or -1    -- uv index         feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree       end     end         if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day         current_data = entry.data.instant.details       if type(current_data) == 'table' then         min_max_today = min_max_temp_press_wind(current_data, min_max_today)       end             if rain_tod_YR == false then -- if detected rain does not check for rain         rain_tod_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tod_YR == false then -- if detected snow does not check for snow         snow_tod_YR = check_for_snow(entry.data.next_1_hours)       end     end         if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day       tomor_data = entry.data.instant.details       if type(tomor_data) == 'table' then         min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)       end             if rain_tom_YR == false then -- if detected rain does not check for rain         rain_tom_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tom_YR == false then -- if detected snow does not check for snow         snow_tom_YR = check_for_snow(entry.data.next_1_hours)       end     end     end     -- data for current hour   grp.write(status_temp, temperature_YR)   grp.write(status_pressure, air_pressure_YR)   grp.write(status_humidity, humidity_YR)   grp.write(status_wind_direction, wind_direction_YR)   grp.write(status_wind_speed, wind_speed_YR)   grp.write(status_uv_index, uv_index_YR)   grp.write(status_feelslike_temp, feelslike_temp_YR)       -- data for today: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_today, rain_tod_YR)   grp.write(status_snow_today, snow_tod_YR)     grp.write(status_min_temp_today, min_max_today.min_t)   grp.write(status_max_temp_today, min_max_today.max_t)   grp.write(status_min_pressure_today, min_max_today.min_p)   grp.write(status_max_pressure_today, min_max_today.max_p)   grp.write(status_min_wind_speed_today, min_max_today.min_w)   grp.write(status_max_wind_speed_today, min_max_today.max_w)   grp.write(status_min_uv_today, min_max_today.min_uv)   grp.write(status_max_uv_today, min_max_today.max_uv)       -- data for tomorrow: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_tomor, rain_tom_YR)   grp.write(status_snow_tomor, snow_tom_YR)     grp.write(status_min_temp_tomor, min_max_tomor.min_t)   grp.write(status_max_temp_tomor, min_max_tomor.max_t)   grp.write(status_min_pressure_tomor, min_max_tomor.min_p)   grp.write(status_max_pressure_tomor, min_max_tomor.max_p)   grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)   grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)   grp.write(status_min_uv_tomor, min_max_tomor.min_uv)   grp.write(status_max_uv_tomor, min_max_tomor.max_uv)   end
