	Threads: 17
		Hello everyone
is it possible to have a CSV file with all curves with this method?
	Threads: 161
		For sure but you must change a script because there are 2 things:
1) how connect 2 trends with different resolution
2) be aware about the size of generated .csv (because of email limits and because of LM CPU power and memory)
This is why I'm not created the script for doing all trends in one .csv.
I think that better is create such script which generate all trends one by one with some pause between each email. And then you have all scripts and e.g. you can connect them via excel(if they are not too big) or via nodejs script or some windows program for such things.
Done is better than perfect
	Threads: 17
		 (29.08.2018, 08:49)buuuudzik Wrote:  For sure but you must change a script because there are 2 things:
Indeed the CPU can be used too much.
After making a backup there is no possibility to recover all of this data in a file?
I would like to retrieve all the data on 65 curves (same resolution) for 6 months ... it's really a lot by mail
Thank you for Reply.
	Threads: 161
		06.07.2022, 11:07
(This post was last modified: 06.07.2022, 18:38 by buuuudzik.)
		I've updated a  trends_pro library to allow simple modifying its data and adding more calculated column.
 Code: -- This function prepare csv table content from data and passed headers
function generateCSVTable(rows, headers)
  if #rows > 0 then
    if #rows[1] > #headers then
      error("There should be " .. tostring(#rows[1]) .. " header columns!")
  -- Prepare .csv file
  for k,v in ipairs(rows) do
      rows[k] = table.concat(v, ",")
  csv = table.concat(headers, ",") .. "\r\n" .. table.concat(rows, "\r\n")
  return csv
-- Allows to add columns based on a current row or a previous one to current row
function addColumnsToRow(row, prevRow, columnGetters)
  for k,getter in ipairs(columnGetters) do
    table.insert(row, getter(row, prevRow))
  return row
-- Allows to add columns based on a current row or a previous one to every row
function addColumnsToRows(rows, columnGetters)
  local prev = nil
  for k,row in ipairs(rows) do
    rows[k] = addColumnsToRow(row, prevRow, columnGetters)
    prev = row
  return rows
function copyObject(obj)
  return json.decode(json.encode(obj))
-- This function prepare export table and .csv file from defined range
function trend_export(name, dates, mode, timestampType)
  require('trends')
  -- detect timeShift
  function detectTimeShift(t0, t1)
  t0_isdst, t1_isdst = os.date('*t', t0).isdst, os.date('*t', t1).isdst
    if (t0_isdst ~= t1_isdst) then
      if (t1_isdst) then
        -- change to summertime
        return 1
        -- change to wintertime
        return 2
      return false
  require("json")
  dates = copyObject(dates)
  -- Convert word "now" in "start" to data table
  if type(dates['start']) == "string" then
    if dates['start'] == "now" then dates['start'] = os.date("*t", os.time())
    elseif dates['start'] == "yesterday" then dates['start'] = os.date("*t", os.time()-24*3600)
    elseif dates['start'] == "week_ago" then dates['start'] = os.date("*t", os.time()-7*24*3600)
    elseif dates['start'] == "month_ago" then dates['start'] = os.date("*t", os.time()-30*24*3600)
    elseif dates['start'] == "year_ago" then dates['start'] = os.date("*t", os.time()-365*24*3600)
  -- Convert word "now" in "end" to data table
  if type(dates['end']) == "string" then
    if dates['end'] == "now" then dates['end'] = os.date("*t", os.time())
    elseif dates['end'] == "yesterday" then dates['end'] = os.date("*t", os.time()-24*3600)
    elseif dates['end'] == "week_ago" then dates['end'] = os.date("*t", os.time()-7*24*3600)
    elseif dates['end'] == "month_ago" then dates['end'] = os.date("*t", os.time()-30*24*3600)
    elseif dates['end'] == "year_ago" then dates['end'] = os.date("*t", os.time()-365*24*3600)
  -- Start and end in unix time
  starttime = os.time(dates['start'])
  endtime = os.time(dates['end'])
  -- Invert "start" and "end" when "end" is smaller than "start"
  if starttime > endtime then
    _ = dates['start']
    dates['start'] = dates['end']
    dates['end'] = _
  -- Read trend resolution from DB
  resolution = db:getlist("SELECT resolution*60 FROM trends WHERE name='" .. name .. "'")[1]
  -- Prepare a table with the data which include the whole data from specified range
  if resolution then
      -- Expand a range with a one more day if there is some data in the last day
    if (os.date("%H", endtime)*3600 + os.date("%M", endtime)*60) >= resolution then
      dates['end'].day = dates['end'].day + 1
      raw_data = trends.fetch(name, dates, resolution)
    start = 1
    data = {}
    start_timestamp = os.time(dates['start']) + resolution
    -- Cut the data and prepare a table with the data only from specified range
    offset = 0
    skip = 0
    k = 1
    while k <= #raw_data do
      v = raw_data[k]
      if k == 1 then last_timestamp = start_timestamp else last_timestamp = current_timestamp end
      current_timestamp = start_timestamp + (k-1) * resolution + offset
      timeShiftStatus = detectTimeShift(last_timestamp, current_timestamp)
      if timeShiftStatus then
        if timeShiftStatus == 1 then -- winter->summer
          skip = 6 -- skip 1 hour empty data
          offset = offset - 3600
        elseif timeShiftStatus == 2 then -- summer->winter
          offset = offset + 3600
      -- Add to new table only records from specified range
      if current_timestamp >= starttime and current_timestamp <= endtime then
        if timestampType == 'unixepoch' then data[start] = {current_timestamp, v}
        else data[start] = {os.date('%Y.%m.%d %H:%M:%S', current_timestamp), v} end
        start = start+1
      k = k + 1 + skip
      skip = 0
    if mode == 'csv' then
      csv = generateCSVTable(data, { "timestamp", "value" })
      return name, csv, resolution
    elseif mode == 'table' then
      return name, data, resolution
      alert('There is no trend with such a name')
-- Merge values from multiple trends in one table
function mergeRows(baseRows, rows)
  for k,row in ipairs(baseRows) do
    if k < 3 then log(k, "base", row) end
    table.insert(baseRows[k], rows[k][2])
    if k < 3 then log(k, "next", rows[k]) end
  return baseRows
function getMultipleColumnHeader(names)
  local columns = { "timestamp" }
  for k,name in ipairs(names) do
    table.insert(columns, name)
  return columns
function multiple_trend_export(names, dates, mode, timestampType)
  local baseRows = {}
    local trend_name, rows = trend_export(name, dates, 'table', timestampType)
    if #baseRows == 0 then
      baseRows = rows
      baseRows = mergeRows(baseRows, rows)
    csv = generateCSVTable(baseRows, getMultipleColumnHeader(names))
    return names, csv, resolution
    return names, baseRows, resolution
What's changed:
I've added these function:
 addColumnsToRows(rows, columnGetters) - which will allow to add more columns and calculate values based on current row and a previous one
 generateCSVTable(rows, headers) - which will produce a csv table content with named headers which should have same length as data rows
 multiple_trend_export(names, dates, mode, timestampType) - which can be used for generating a table with multiple trends
Usage example:
 Code: require('user.trends_pro')
dates = {}
dates['start'] = 'yesterday'
dates['end'] = 'now'
name, rows = trend_export("Salon_Temperatura", dates, 'table', 'unixepoch')
addColumnsToRows(rows, {
    function(row, prevRow)
      local value = row[2]
      local prevValue = 0
      if prevRow then prevValue = prevRow[2] end
      if value > 3 or prevValue > 3 then
        return "YES"
        return "NO"
csv = generateCSVTable(rows, { 'timestamp', 'value', 'isBiggerThan3' })
log(name, csv)
-- Generating a table with multiple trends in same rows
names, rows = multiple_trend_export({"Kitchen_Temp", "Outdoor_Temp"}, dates, 'csv', 'unixepoch')
log(names, rows)
	Threads: 19
		Hi!
Thanks for your effort with this Lib ! I is very useful !
I have tried it and noticed a small difference from the Export from Visualization and the Export from the Script.
The resolution for this trends I have tested are 30min.
There is an offset of 30 minutes in the timestamp:
 Code: -- This the timewindow I have used to test
dates = {}
dates['start'] = { year = 2022, month = 6, day = 1,  hour = 0, min = 0, sec = 0}
dates['end']   = { year = 2022, month = 7, day = 1,  hour = 0, min = 0, sec = 0}
