Schnieder Meter 64-bit register from 16-bit Register
I am looking to generate a 64-bit register from individual 16 bit registers from Schnieder meters,  See attached info sheet.
We are having to read the meters from a different KNX device which can only read the 16-bit registers and do the conversion in the logic machine.  This will then display the total on a visual interface.
I would also like it to send the valve back to the KNX bus.
Any help would be much apricated.
Which meter exactly do you need?
We use the PM31 and PM51 Meters,
Just looking at the modbus commands.  I think i could i use modbus address 2700 instead of breaking down the 64bit 3204 address?
See this profile.
.json   PM-PM5110.json (Size: 8.32 KB / Downloads: 15)
