Send Hex Values to an ser2net device
I want to control my samsung smart TV via Visu/KNX. For that I setuped a Linux device with ser2net (local serial RS232 to TV) and connected them to my TV.
The debug console from TV over ser2net works perfectly, but I can't send some hex values to control functions.
How can I send via telnet from spaceLYnk some hex values like "082200000001d5 " or in this syntax "\x08h\x22h\x00h\x00h\x00h\x01h\xd5h"
Can somebody give me one example?
with this command I get an connection:
telnet 192.168.100.55 4001
Thx forwards
Regards
Habib
Try this:
require('socket') ip = '192.168.1.11' port = 1234 data = string.char(0x08, 0x22, 0x00, 0x00, 0x00, 0x01, 0xd5) sock = socket.tcp() sock:settimeout(5) res, err = sock:connect(ip, port) if res then   res, err = sock:send(data)   if not res then     alert('send error ' .. tostring(err))   end else   alert('connect error ' .. tostring(err)) end sock:close()
