Threads: 81
Hi, I need to trend log about 250/300 KNX objects.
I know that's over LM possibilities due the 21 Mb archive limit.
Can you suggest an appropriate device to do this job?
I already knows BAB TECHNOLOGIE GmbH DATALOGGER V2 (
https://bab-technologie.com/datalogger-v2/?lang=en ), it could be ok.
But I trust in your experience and I would receive a suggest.
Peppe
Threads: 43
With low resolution / retention settings you could fit 300 trends into LM. An alternative solution is to use Grafana - either cloud-hosted or by installing it locally on a small PC. Installation can be a bit tricky but it's a very flexible solution for storing time-series data.
Threads: 81
Grafana seems to be very cool! And how to connect LM to it, sending telegrams via remote access?
Threads: 43
Threads: 81
(07.09.2022, 07:47) admin Wrote: LM is sending data to InfluxDB using HTTP. This thread has working examples: https://forum.logicmachine.net/showthread.php?tid=1531
Another option is MQTT: https://grafana.com/blog/2021/08/12/stre...fana-live/
Things are little changed on InfluxDB:
https://docs.influxdata.com/influxdb/clo...fluxdb-api
it seems a little too complicated to me... no shorter ways to implement a massive data logging?
Peppe
Threads: 43
You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
The setup part is a bit complicated but you only have to do it once
Threads: 81
(14.09.2022, 11:33) admin Wrote: You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
I accepted the challenge!
But right now I get error messages:
* arg: 1
* string: error sending to influx
* arg: 2
* string: {"code":"invalid","message":"at line 1:36: cannot parse value for field key \"value\": invalid float value syntax (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
* number: 400
* arg: 4
* string: rawdata,name=ora,addr=33/1/9 value=10:57
and
* arg: 1
* arg: 2
* string: {"code":"invalid","message":"at line 1:47: cannot parse value for field key \"value\": invalid bool value \"Thu\" (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
* number: 400
* arg: 4
* string: rawdata,name=giornomeseanno,addr=33/1/8 value=Thu 15-09-2022
the script I used is the following, can you help me?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
local socket =
require (
'socket' )
local http =
require (
'socket.http' )
http.TIMEOUT =
5
local dt_cache = {}
function get_value (
addr ,
datahex )
local dt =
dt_cache [
addr ]
if (
not dt )
then
dt =
grp.find (
addr )
dt_cache [
addr ] =
dt
return knxdatatype.decode (
datahex ,
dt.datatype ),
dt
function knx_callback (
event )
local addr =
event.dst
local value ,
dt =
get_value (
addr ,
event.datahex )
send_metric (
'rawdata' ,
dt.name ,
addr ,
value )
function send_metric (
table ,
name ,
addr ,
value )
if name ==
nil or name ==
'' then
return
name =
string.gsub (
name ,
local url =
'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'
local body
if type (
value ) ==
'boolean' then
body =
string.format (
'%s,name=%s,addr=%s state=%s' ,
table ,
name ,
addr ,
value )
body =
string.format (
'%s,name=%s,addr=%s value=%s' ,
table ,
name ,
addr ,
value )
local res ,
code =
http.request ({
url =
url ,
method =
'POST' ,
body =
body ,
headers = {
Authorization =
'Token XXXXXXXXXXXXXXXXXXX'
if code ~=
204 then
log (
'error sending to influx' ,
res ,
code ,
body )
function run_loop ()
local bus =
require (
'localbus' ).
new (
1 )
bus :
sethandler (
'groupwrite' ,
knx_callback )
local busfd =
socket.fdmaskset (
bus :
getfd (),
'r' )
while (
true )
do
res ,
fbus =
socket.selectfds (
10 ,
busfd )
if (
fbus )
then
bus :
step ()
run_loop ()
Threads: 43
You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
Try replacing lines 35..42 with this:
local body
if type (
value ) ==
'boolean' or type (
value ) ==
'number' then
body =
string.format (
table ,
name ,
addr ,
value )
elseif type (
value ) ==
'string' then
body =
string.format (
'%s,name=%s,addr=%s value=%q' ,
table ,
name ,
addr ,
value )
log (
'invalid data type' ,
addr ,
type (
value ))
return
Currently this script sends values for all objects. There should be some filtering implemented so only the required data is pushed.
Threads: 81
(15.09.2022, 09:23) admin Wrote: You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
local body
if type (
value ) ==
'boolean' or type (
value ) ==
'number' then
body =
string.format (
table ,
name ,
addr ,
value )
elseif type (
value ) ==
'string' then
body =
string.format (
table ,
name ,
addr ,
value )
log (
addr ,
type (
value ))
return
ok, now it's collecting data.... and yes, I need to filter them.
I guess I have to modify the function knx_callback(event), but my object addresses are not in a specific range, so I need to implement a sort of list of addresses to send.
Threads: 43
This example will push only objects that have influx tag attached.
local http =
require (
'socket.http' )
http.TIMEOUT =
5
local objs = {}
local tagobjs =
grp.tag (
'influx' )
for _ ,
obj in ipairs (
tagobjs )
do
objs [
obj.address ] = {
name =
obj.name :
gsub (
datatype =
obj.datatype ,
function callback (
event )
local addr =
event.dst
local obj =
objs [
addr ]
if obj then
local value =
event.datahex ,
obj.datatype )
sendmetric (
'rawdata' ,
obj.name ,
addr ,
value )
function sendmetric (
table ,
name ,
addr ,
value )
local url =
local body
if type (
value ) ==
'boolean' or type (
value ) ==
'number' then
body =
string.format (
table ,
name ,
addr ,
value )
elseif type (
value ) ==
'string' then
body =
string.format (
table ,
name ,
addr ,
value )
log (
addr ,
type (
value ))
return
local res ,
code =
http.request ({
url =
url ,
method =
'POST' ,
body =
body ,
headers = {
Authorization =
if code ~=
204 then
log (
res ,
code ,
body )
local busclient =
require (
'localbus' ).
new ()
busclient :
sethandler (
'groupwrite' ,
callback )
while true do
busclient :
loop (
1 )
Threads: 81
(15.09.2022, 12:55) admin Wrote: This example will push only objects that have influx tag attached.
local http =
require (
'socket.http' )
http.TIMEOUT =
5
local objs = {}
local tagobjs =
grp.tag (
'influx' )
for _ ,
obj in ipairs (
tagobjs )
do
objs [
obj.address ] = {
name =
obj.name :
gsub (
datatype =
obj.datatype ,
function callback (
event )
local addr =
event.dst
local obj =
objs [
addr ]
if obj then
local value =
event.datahex ,
obj.datatype )
sendmetric (
'rawdata' ,
obj.name ,
addr ,
value )
table ,
name ,
addr ,
value )
local url =
local body
if type (
value ) ==
'boolean' or type (
value ) ==
'number' then
body =
string.format (
table ,
name ,
addr ,
value )
elseif type (
value ) ==
'string' then
body =
string.format (
table ,
name ,
addr ,
value )
log (
addr ,
type (
value ))
return
local res ,
code =
http.request ({
url =
url ,
method =
'POST' ,
body =
body ,
headers = {
Authorization =
if code ~=
204 then
log (
res ,
code ,
body )
local busclient =
require (
'localbus' ).
new ()
busclient :
sethandler (
'groupwrite' ,
callback )
while true do
busclient :
loop (
1 )
Everything is fine (although I still have to learn how to handle the data to create a decent report
Now I have the final step: to connect influxdb to Grafana.
I don't know how to choose the right authentication metod to connect it. Where to put the token and org name??!
Threads: 43
If you switch to Flux query language then you can specify access token, org and bucket.
This might be helpful:
https://medium.com/@nanditasahu031/integ...b4aebb3368
https://blog.devgenius.io/grafana-influx...561e89b207
