16.10.2022, 07:39
i have some irrigation to controll with feedback from som moisture sensor,
i want to run a scheduled script in the am at say 5:00 to check if moisture is below a setpoint then switch on irrigation for 2 hour if required each day
at 5am when script runs
if is dry then switch on 0/5/1 (bool)
how is the best way to manage the switch off later?, make another scheduled script for 7:00am with switch off?
i also need a way to include some offset so i don't over water etc
or maybe there is a better way like make the off command an event script form the moisture sensor?
