Object write with
Hi, can You help me, the red part of script doesnt work to me. I need if STAV==1, to wait 5times x 10sec if it change to 0.
STAV=grp.getvalue("10/1/181")
pocet=5
if (event.getvalue()==true)
  then
  if(STAV==0)
    then
    grp.write("10/0/0", true)
  repeat
    os.sleep(10)
    pocet=pocet-1
    if(STAV==0)
      then
  until (pocet==0)
I think the script will not work because of your 2nd IF statement and the declaration of STAV at the beginning.
if STAV = 0 then do something, but if STAV is not zero do something ELSE.
Then in that ELSE statement you check in your REPEAT loop if STAV is 0 again, but you ended there because STAV was something else than zero and you don't re-poll the STAV value, so you'll never meet that condition. I guess...
(19.01.2023, 20:07)tigi Wrote: I think the script will not work because of your 2nd IF statement and the declaration of STAV at the beginning.
I think so this is problem with update object, but how to do update of STAV during repeat?
You need to add another grp.getvalue call before checking the value.
