05.01.2017, 11:00
Hello!
I was wondering if anyone could help me with scripting a 1-pushbutton dimming.
The idea is to control an in-wall switchdim with an EnOcean 2-channel relay. The button will only be controlled from the LM visualization.
Output 1 (O1) will switch the light on/off (Short push) and Output 2 will dim the light up/down (Long Push only).
I want to be able to know if the light is turned ON or OFF in the visualization, that's why I've chosen to use 2 outputs. See the attached drawing.
Is there a way to also implement a push button in the touch visualization instead of the toggle-switch?
Thanks!
Thanks!
