Application Store documentation and sample app
#21
Can I apply too for these packaging instructions?
Thanks in advance.
https://forum.logicmachine.net/showthread.php?tid=85
I wondered how to make .ipk file for installation from GUI. Can I have packaging guide too?
Thanks in advance!
You can't, once you have the app working we can compile it.
I'm not sure if this is the best place to ask, but I have an app that I now wish to package as an IPK. I know how to create an IPK file, but if I try and install this I get an error. Do I need to send the code etc to you guys?
Many thanks
Darren
hi please can you help me to make an api that takes json data and save it in to csv file
thanks in advance.
Use this to get raw POST JSON in your .lp file:
require('apps')
-- read POST data
body = ngx.req.get_body_data()
if body then
  -- decode data as JSON
  data = json.pdecode(body)
  -- check that data is a table
  if type(data) == 'table' then
    log(data)
    -- add data to CSV
Hello!
Here is very simple app (for people who only start their experience in app development).
App includes:
1.) Example of form validity on client's side.
2.) Example of form validity on server's side.
3.) Usage of storage.
4.) Usage of redis.
5.) Example of selecting KNX objects by it's data type.
6.) Example of displaying KNX objects and it's values as an editable list.
The app should be located in /data/apps/store/data/
.zip   template.zip (Size: 406.75 KB / Downloads: 63)
How we can create an ipk package file to upload new device ?
Check PM
If I store the data via ftp in /data, do I have to pay attention to anything else? Because the app is then not displayed. Or do I have to make an .ipk out of it?
Do you have index.lp and icon.png or icon.svg in your app directory?
Yes i have
Path should be /data/template not /data/template/template
Hi Dev,
I 've decided to improve my knowledge in LM working on Apps development. I ve download the Sample.zip study them and start with my first app. I'm facing a problem, as in Lua using the log() it is very simple make debug of the code, in the other language it is pretty hard (for me). I have a problem in the jQuery/js file and I thought that insert the line console.log(my variable) or console.log('im here') can help me. But in the Chrome console doesn't appear nothing. Where m'I wronging? Is there some other tricks for debug?
Thanks and best regards @all
Cristian
(25.01.2025, 06:34)CristianAgata Wrote: Hi Dev,
Cristian
I reply to myself..... console.log() works on Firefox.
BR Cristian
Dear,
We are experiencing an issue with the LogicMachine5 Lite Power in the Google application.
We have created multiple ON/OFF commands for the lights, and they all work correctly. However, we are facing a problem with one specific light. When using the button in Google Home, the light responds correctly to both ON and OFF commands. However, when using a voice command, it only allows turning the light ON but does not execute the OFF command.
The light's name is "Piscina." We suspected the issue might be related to the name, so we changed it to "Pool," but the problem persists.
We also checked the ETS configuration, and everything appears to be correct.
Could you please help us understand the cause of this issue?
Massimo
If the light works in google home app then our implementation is correct. Issue is on Google side.
