Threads: 41
Make sure that you have correct gateway and DNS settings in LM. Then check if you are using script for the correct CPU model that you have. After that install the system load app in LM and check that you have /usr/sbin/kamailio in the process list.
There's no UI of any kind, just the default configuration that allows SIP clients to call each other.
Threads: 9
Hi. I have several LM with running SIP servers working flawlessly. I was wondering if it would be possible to detect a SIP call in order to enable a bit in a group address. Thank you!
Threads: 41
Possible in theory but the current SIP server build does not have a required module to execute a script on a call event.
Threads: 41
Username should be a unique numeric value, no password. Clients can make calls between each other using username as a phone number.
Threads: 41
You can put anything in the password field.
