Local connection to powerwall API
Hello everyone,
I am trying to connect to my Tesla Powerwall gateway through local network. I can get the authorization token with the following code:
When I try to get the charge percentage, I use the following code:
function getAccessToken()
    IP = '10.51.10.224'
    data = '{"username":"customer","password":"XXXXX","email":"my.adderss@gmail.com","force_sm_off":false}'
    socket = require('socket')
    ssl = require('ssl')
    json = require('json')
    params = {
        mode = 'client',
        protocol = 'tlsv1_2',
        verify = 'none'
    client = socket.tcp()
    client:settimeout(1)
    res, err = client:connect(IP, 443)
    ctx = ssl.newcontext(params)
    client = ssl.wrap(client, ctx)
    res, err = client:dohandshake()
    req =
        'POST /api/login/Basic HTTP/1.1' .. '\r\n' .. 'Host: ' .. IP .. '\r\n' .. 'User-Agent: curl/7.64.1' .. '\r\n' ..
            'Accept: */*' .. '\r\n' .. 'Connection: close' .. '\r\n' .. 'Content-Type: application/json' .. '\r\n' ..
            'Content-Length: ' .. #data .. '\r\n\r\n' .. data
    res, err = client:send(req)
    res, err, partial = client:receive('*a')
    local headers, response_body = res:match("^(.-)\r\n\r\n(.*)$")
    local token = json.decode(response_body)['token']
    client:close()
     return token
When I try to use the token with this function:
function getSoe()
    IP = '10.51.10.224'
    params = {
        mode = 'client',
        verify = 'none'
    token = getAccessToken()
    req = 'GET /api/system_status/soe HTTP/1.1' .. '\r\n' .. 'Host: ' .. IP .. '\r\n' .. 'User-Agent: curl/7.64.1' ..
              '\r\n' .. 'Accept: */*' .. '\r\n' .. 'Connection: close' .. '\r\n' .. 'Authorization: Bearer ' .. token ..
              '\r\n'
    log('send', res, err)
    if res == nil then
        return nil
I get the following result in the logs:
* arg: 1
  * string: send
* arg: 2
  * nil
* arg: 3
  * string: wantread
I cannot understand what is that wantread error, how can I solve this issue? I tried in postman and it works.
Your second script has an incorrect IP address - 1.1.1.1 instead of 10.51.10.224
(08.05.2023, 06:18)admin Wrote: Your second script has an incorrect IP address - 1.1.1.1 instead of 10.51.10.224
Ahem my bad, I wanted to obfuscate that as well but I didn't do the first one.   Rolleyes
Should have used the right one from the start, it's in a private network anyways
