Threads: 5
I want to create a csv file for the last 30 days.
I have a script as below, but it creates not that many days. What has to be changed?
/Fredrik
Code: 123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126 require( 'trends')
dates = {}
dates[ 'start'] = os.date( '*t')
dates[ 'start']. day = dates[ 'start']. day - 1
dates[ 'end'] = os.date( '*t')
now = os.time()
function fetch( tname)
local res = {}
local values = trends.fetch( tname, dates)
local count = # values
local step = 86400 / count
for i, value in ipairs( values) do
table.insert( res, {
now - ( count - i) * step,
value
return res
buf = {
fetch( 'LUFTTEMPERATUR W'),
fetch( 'NEDERBÖRDSMÄNGD W'),
fetch( 'VINDRIKTNING W'),
fetch( 'NEDERBÖRD INTENSITET W'),
fetch( 'GENOMSNITTLIG VINDHASTIGHET W'),
fetch( 'RELATIV LUFTFUKTIGHET W'),
fetch( 'MAX VINDHASTIGHET W'),
fetch( 'ABSOLUT LUFTTRYCK W')
csv = { 'Id,Site Id,Site Authentication Key,Report Date / Time,Temperature,Precipitation accumulated,Wind direction,Precipitation intensity,Average wind, Humidity,Downwind,Air pressure at station' }
for i, row1 in ipairs( buf[ 1 ]) do
date = os.date( '%d/%m/%y %H:%M', row1[ 1 ])
value1 = row1[ 2 ]
row2 = buf[ 2 ][ i ] or {}
value2 = row2[ 2 ] or 0
row3 = buf[ 3 ][ i ] or {}
value3 = row3[ 2 ] or 0
row4 = buf[ 4 ][ i ] or {}
value4 = row4[ 2 ] or 0
row5 = buf[ 5 ][ i ] or {}
value5 = row5[ 2 ] or 0
row6 = buf[ 6 ][ i ] or {}
value6 = row6[ 2 ] or 0
row7 = buf[ 7 ][ i ] or {}
value7 = row7[ 2 ] or 0
row8 = buf[ 8 ][ i ] or {}
value8 = row8[ 2 ] or 0
csv[ # csv + 1 ] = string.format( ' fb6ca12c-3106-ee11-913a-201642ba599e,20230608tey3apeggae67rj4rymrfqtn3c,Grimeljer2023!,%s,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f',
date, value1, value2, value3, value4, value5, value6, value7, value8)
csv = table.concat( csv, '\n')
log( csv)
to = 'email@email.com'
settings = {
from = ' email@email.com ',
user = ' email@email.com ',
password = 'Password',
server = 'smtp.gmail.com',
port = 465,
secure = 'sslv23',
subject = 'CSV väder'
smtp = require( 'socket.smtp')
mime = require( 'mime')
ltn12 = require( 'ltn12')
function escape( v)
return '<' .. tostring( v) .. '>'
to = escape( to)
msgt = {
headers = {
to = to,
[ 'content-type'] = 'text/csv',
[ 'content-disposition'] = 'attachment; filename="logs.csv"',
[ 'content-transfer-encoding'] = 'BASE64',
subject = subject,
body = ltn12.source.chain(
ltn12.source.string( csv),
ltn12.filter.chain( mime.encode( 'base64'), mime.wrap( 'base64'))
settings.source = smtp.message( msgt)
settings.from = escape( settings.from)
settings.rcpt = { to }
res, err = smtp.send( settings)
log( res, err)
Threads: 43
Replace:
Code: 1 dates[ 'start']. day = dates[ 'start']. day - 1
With:
Code: 1 dates[ 'start']. day = dates[ 'start']. day - 30
Threads: 5
(06.10.2023, 08:48)admin Wrote: Replace:
With:
Thank you!
But it seems to be only the last 24 hours in the csv file. What can be wrong?
/Fredrik
Threads: 43
Line 14 should be:
Code: 1 local step = 30 * 86400 / count
Threads: 5
Thank you!
It seems to work, but the time and date does not match.
if i look at csv from script, date, time and values come like this.
" 23/10/06 14:30" 1010.56
" 23/10/06 14:45" 1011.20
" 23/10/06 15:00" 1011.20
" 23/10/06 15:15" 1011.20
" 23/10/06 15:30" 1011.20
" 23/10/06 15:45" 1011.20
" 23/10/06 16:00" 1011.20
" 23/10/06 16:15" 1011.20
" 23/10/06 16:30" 1011.20
" 23/10/06 16:45" 1011.20
" 23/10/06 17:00" 1011.20
" 23/10/06 17:15" 1011.20
And if i download a csv file from the day before 23/10/05 it shows this.
21:15,"1010.56"
21:30,"1011.2"
21:45,"1011.2"
22:00,"1011.2"
22:15,"1011.2"
22:30,"1011.2"
22:45,"1011.2"
23:00,"1011.2"
23:15,"1011.2"
23:30,"1011.2"
23:45,"1011.2"
24:00,"1011.2"
It means that the last value i was testing to send from script, is the last value from the day before.
How can i correct this?
/Fredrik
Threads: 43
Try replacing fetch function with this:
Code: 123 function fetch( tname)
return trends.fetch( tname, dates, nil, true)
endMake sure you have 2023 firmware.
Threads: 5
Thank you!
Now it's 1h 45m difference.
2023-10-08 22:45,7.90,0.00,291.20,0.00,2.40,52.00,2.80,1013.76"
2023-10-08 23:00,7.70,0.00,269.60,0.00,1.80,52.60,1.80,1013.12"
2023-10-08 23:15,7.50,0.00,287.36,0.00,2.30,52.88,2.40,1013.12"
2023-10-08 23:30,7.30,0.00,272.80,0.00,1.80,53.68,1.90,1013.12"
2023-10-08 23:45,7.20,0.00,302.72,0.00,1.10,55.00,1.10,1013.12"
2023-10-09 00:00,7.10,0.00,275.68,0.00,0.90,55.20,1.10,1013.12"
2023-10-09 00:15,7.00,0.00,299.20,0.00,1.40,55.00,2.50,1013.12"
2023-10-09 00:30,6.80,0.00,298.72,0.00,3.40,55.60,3.80,1013.12"
2023-10-09 00:45,6.60,0.00,291.36,0.00,3.40,56.28,3.60,1013.12"
2023-10-09 01:00,6.50,0.00,256.16,0.00,0.80,57.08,0.80,1013.12"
2023-10-09 01:15,6.40,0.00,296.64,0.00,1.40,58.80,1.50,1013.12"
2023-10-09 01:30,6.10,0.00,276.80,0.00,1.50,59.40,2.00,1013.12"
2023-10-09 01:45,6.00,0.00,350.40,0.00,0.50,59.68,0.60,1012.48"
And if i download a csv file from the day before 23/10/08 it shows this.
21:00,"1013.76"
21:15,"1013.12"
21:30,"1013.12"
21:45,"1013.12"
22:00,"1013.12"
22:15,"1013.12"
22:30,"1013.12"
22:45,"1013.12"
23:00,"1013.12"
23:15,"1013.12"
23:30,"1013.12"
23:45,"1013.12"
24:00,"1012.48"
/Fredrik
Threads: 43
Timestamps are in UTC which conversion to date string does not take into account.
Replace this:
Code: 1 date = os.date( '%d/%m/%y %H:%M', row1[ 1 ])
With this:
Code: 1 date = os.date( '!%d/%m/%y %H:%M', row1[ 1 ])
There's bug in CSV export in Trends UI where data is shifted by one step (15 minutes in your case).
Threads: 5
Ok, thank you!
Now the result is this. It's 15 min difference...
Best!
/Fredrik
2023-10-09 20:45,7.70,0.00,251.84,0.00,1.00,63.00,1.10,1009.92"
2023-10-09 21:00,7.80,0.00,276.80,0.00,1.20,63.20,1.40,1009.28"
2023-10-09 21:15,7.50,0.00,268.16,0.00,1.30,65.00,1.50,1009.92"
2023-10-09 21:30,7.10,0.00,255.36,0.00,1.30,67.40,1.30,1009.92"
2023-10-09 21:45,7.10,0.00,240.48,0.00,0.50,67.40,0.60,1009.92"
2023-10-09 22:00,6.90,0.00,260.00,0.00,1.20,67.80,1.20,1009.92"
2023-10-09 22:15,6.60,0.00,263.04,0.00,0.60,71.60,0.80,1009.92"
2023-10-09 22:30,6.60,0.00,243.36,0.00,1.00,75.40,1.00,1009.92"
2023-10-09 22:45,6.60,0.00,239.52,0.00,1.20,76.40,1.40,1009.92"
2023-10-09 23:00,6.50,0.00,258.08,0.00,0.90,76.40,0.90,1009.92"
2023-10-09 23:15,6.30,0.00,197.12,0.00,0.60,76.60,0.60,1009.92"
2023-10-09 23:30,6.10,0.00,216.00,0.00,0.50,75.68,0.70,1009.92"
2023-10-09 23:45,5.90,0.00,199.68,0.00,1.70,75.20,2.10,1009.92"
20:45,"1009.28"
21:00,"1009.92"
21:15,"1009.28"
21:30,"1009.92"
21:45,"1009.92"
22:00,"1009.92"
22:15,"1009.92"
22:30,"1009.92"
22:45,"1009.92"
23:00,"1009.92"
23:15,"1009.92"
23:30,"1009.92"
23:45,"1009.92"
24:00,"1009.92"
Threads: 43
I've already mentioned this:
Switch to Data when viewing trends, you will get the same 15 minutes difference with exported data.
