sending data to thingsboard.io
hi, I would use the platform Thingsboard.io to send and collect value data from LM objects.
they allows to do it by 2 ways:
HTTP request ( es.  curl -v -X POST http://demo.thingsboard.io/api/v1/eoKkkZ.../telemetry --header Content-Type:application/json --data "{temperature:25}")    or
MQTT (es. curl -v -X POST http://demo.thingsboard.io/api/v1/eoKkkZ.../telemetry --header Content-Type:application/json --data "{temperature:25}")
how could I implement everything on LM?
Thanks in advance
Peppe
For HTTP use this:
require('json') require('ltn12') require('socket.http') body = json.encode({ temperature = 25 }) response = {} res, code = socket.http.request({   url = 'http://demo.thingsboard.io/api/v1/eoKkkZ6JL7UbmyOHGX9L/telemetry',   method = 'POST',   headers = {     ['Content-Type'] = 'application/json',     ['Content-Length'] = #body,   },   source = ltn12.source.string(body),   sink = ltn12.sink.table(response), }) if res and code == 200 then   log('request ok') else   log('request error', code, table.concat(response)) end
For MQTT search the forum, there are many examples of how to use it. The data must be encoded using JSON, same as for HTTP requests.
(22.11.2023, 11:12)admin Wrote: For HTTP use this:
Thank you. How to pass a object value?
value = grp.getvalue('4/1/11') body = json.encode({ temperature = value })
That way doesn't work. What is correct syntax?
The syntax is correct, for event scripts use event.getvalue() instead of grp.getvalue().
What kind of error are you getting?
(22.11.2023, 13:38)admin Wrote: The syntax is correct, for event scripts use event.getvalue() instead of grp.getvalue().
No errors, sorry. It's all right now.
Peppe
I am trying to provision an object in mqtt. Thingsboard says me to execute the command:
mosquitto_pub -d -q 1 -h demo.thingsboard.io -p 1883 -t v1/devices/me/telemetry -u "gximaxia" -P "12345678" -m "{temperature:25}"
How I can arrange it via script?
I need send data of dozen of knx objects, how I can do it without give different username and password? What is the short/best way to do it?
Peppe
See this example: https://kb.logicmachine.net/integration/mqtt-client/
I would like to implement the so-called Thingsboard.io Server-side RPC (https://thingsboard.io/docs/pe/user-guide/rpc/)  to send simple commands to KNX objects (e.g. on/off, set temperature, etc.).
is it possible? How I can do?
Thanks in advance
Peppe
They support MQTT so you should be good to go. You will need a broker somewhere, if it is locally then you can use LM broker app.
(15.05.2024, 10:03)Daniel Wrote: They support MQTT so you should be good to go. You will need a broker somewhere, if it is locally then you can use LM broker app.
What do you mean for "locally"? Thingsboard is on a VM in the cloud... is LM Broker app ok for this? Can you give me please some basic advice how to use it?
If it is in the cloud then you need broker in the cloud. Our broker app wont work.
If I put LM and Thingsboard VM under the same Zerotier network, can I use LM MQTT Broker app?
In that case, how I can let TB to send write commands to LM?
Right now I only use a script to send values to TB:
indirizzo = event.dst tagEvento = event.tag --log (event) --broker = "demo.thingsboard.io" broker = "xxx.xxx.xxx.xxx" port = 1883 token = "xxxxxxxxxxxxxxxxxxxxx" topic = "v1/devices/me/telemetry" value = event.getvalue() if value == true then     value = 1 elseif value == false then     value = 0 else     numero = tonumber(value)     if numero ~= nil and numero % 1 ~= 0 then         value = string.format("%.1f", numero)     end   end value = tostring(value) old_value = storage.get(indirizzo,"") if value == old_value then     --log("return")     return   end storage.set(indirizzo, value) payload = '{"('..indirizzo..')":' .. value .. '}' mqtt = require("mosquitto") client = mqtt.new() client.ON_CONNECT = function(status, rc, msg)   if status then     --log("mqtt connected: "..payload)     client:publish(topic, tostring(payload))   else     log("mqtt connect failed " .. tostring(msg))     client:disconnect()   end end client.ON_PUBLISH = function()   client:disconnect() end -- client:login_set(username, password) client:login_set(token, nil) status, rc, msg = client:connect(broker, port) if status then   client:loop_forever() else   log('connect failed: ' .. tostring(msg)) end
How should be to receive commands?
Thanks a lot!
Peppe
It should work. See here for LM MQTT client script.
There are many more examples on the forum.
